Calculating watts per kilogram
No Pain, No Pizza
Bikes: 2015 Tarmac Pro Disc, '99 Burley Duet, '10 Velo Vie Vitesse 300R, '94 Trek 2120, '90 Cannondale SR 600, '79 Ross Super Gran Tour, '76 Raleigh Record
Quoted: 31 Post(s)
Liked 40 Times
When one calculates watts per kilogram. Is the mass only the weight of the rider without clothing, etc.? Or is it the combined weight of rider, their clothing, bicycle, tools, water bottles, etc.?
Quoted: 4416 Post(s)
Liked 4,872 Times
If you are using it for measuring your fitness then I would just take your undressed weight.
Likes For PeteHski:
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,872 Times
Before or after pooping?
Liked 8,928 Times
Likes For datlas:
Bikes: Shmikes
Liked 5,872 Times
Likes For MoAlpha:
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2640 Post(s)
Liked 3,153 Times
Wake up, coffee + banana (maybe a small pastry portion), bowel movement, scale, kit up, then on the bike!
"Your beauty is an aeroplane;
Likes For TMonk:
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
For supply side, just you, nekkid, post-poop.
For demand side, you, all your kit including water bottles, and your bike.
I would say that most people most of the time mean supply side.
Likes For blacknbluebikes:
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
I usually think of it as a trait of the rider, so it's just the rider. Your W/kg doesn't change when you change bikes. And as mentioned, since most bikes are only marginally different in weight when accounting for the bike + rider system, it only matters in very narrow circumstances.
Likes For Bah Humbug:
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
If you're trying to estimate how fast you can climb a steep road, you'll be looking at the W/kg of the whole package (rider + bike + accessories).
Likes For terrymorse:
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Right, but my point is that in that case, the difference between a mid-range and high-end road bike is still very small compared to even a 60kg cyclist, and with two 60kg cyclists the FTP difference is likely larger than the bike weight.
Liked 4,872 Times
Models that estimate how fast you can climb usually have separate parameters for bike and rider weights. If someone says they have a 4 W/kg FTP they are not including the weight of their bike and kit. Your power in terms of W/kg should be independent of what bike you are riding if you are comparing the performance of riders.
Likes For PeteHski:
Quoted: 682 Post(s)
Liked 453 Times
Soooo I don’t mean to be controversial but isn’t w/kg usually a measure of strength and fitness? If you make your bike lighter or leave a bidon at home, did you get stronger or fitter?
Likes For choddo:
climber has-been
Liked 3,567 Times
The weight difference between a high-end climbing bike and a mid-range road bike is not very small. A decent climbing bike is easily 2 kg lighter than a mid-range bike.
Liked 4,872 Times
Exactly. When discussing W/kg as a measure of human performance it is literally Watts per kg of bodyweight. The weight of the bike and kit is only relevant in cycling simulation models.
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
Fat bottom girls make the rockin world…
You could get lost and die.
You could hit a tree and die.
Super Modest
Quoted: 10963 Post(s)
Liked 4,621 Times
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2586 Post(s)
Liked 5,648 Times
Quoted: 2488 Post(s)
Liked 2,957 Times
Super Modest
Liked 4,621 Times
