Deore vs MT520 brakes
I've just bought a bike that came with MT400 brakes. My previous bike had excellent SLX brakes. I wanted to reuse the SLX brakes, but needed new hoses and pads and it all was too expensive to mount those 7 y/o brakes on a new bike, so I decided to sell the bike with them.
I have weak hands (and a history of tendinitis) and appreciate a lot having brakes that are powerful with as little force as possible.
Right now I'm considering replacing the MT400 with the following options:
- Deore M6000 brakes for 89€.
- MT501 2 piston brakes for 87€.
- Dual MT520 4 piston brakes for 112€.
- MT520 4 piston front brake and MT501 2 piston rear brake for 100€.
All levers have Servowave (which I like) and are almost identical (some branded Deore and others MT500). Is this really the case? or are the Deore better brakes? I'm really leaning towards last option, as I'm pretty sure I don't need 4 pistons in the rear, but will probably appreciate them in the front.
Thanks!
Thanks!
The nice thing is that the wife's bike is going to be upgraded from Avid BB7 chinese clones (yes, that was risky), to MT400
Likes For Amt0571:
I'm going to break the scale though... I was used to an 11.5kg bike, and now I'm riding a 13kg one and adding heavy brakes to it. Although to be honest, this one has a dropper post and 29x2.35 tires instead of "flimsy" 26x2.00.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Pay attention to what pads you’re getting.
Genesis 49:16-17
Genesis 49:16-17
Organic pads. They're the ones I wanted as I don't want to replace the rotors (yet).
I really can't understand how it's possible that a, otherwise well equipped 1400€ bike, can come with such a crappy brakes and rotors though. I've seen that it's common in all brands though. A friend of mine has a 1500€ Orbea with MT200 brakes 🤦♂️
Quoted: 1088 Post(s)
Liked 1,024 Times
Wife's $1900 Cannondale also came with mt200, so far she isn't complaining but her other bike she was using off-road was a cross with cable discs so I'm sure its better. While I know higher end shimano brakes work better even a basic shimano hydraulic disc is an impressive thing. I upgraded both kids' bikes from cable to MT396 which are Alivio level and they stop quite well and the kids went from four finger squeezes to 1 finger slow downs and 2 finger stops. All depends what you're used to.
IMHO, if the bike has a dropper, it's expected that the user is going to ride over difficult terrain, and that deserves something more substantial than a couple of cheap MT400.
Disco Infiltrator
Liked 2,105 Times
I really feel like the interface of pad to rotor is the most important thing, and everything else is a matter of adding adjustments and durability. They also don’t seem to change very fast. The new brakes that come with new group sets are usually a matter of matching the styling.
Genesis 49:16-17
Genesis 49:16-17
Slx or XT work great.
I agree, as I said, I've been running SLX on my previous bike. I'm not sure I'd buy them again though. This is why I only considered Deore and MT520, as they have the same braking power and only lack tool-free adjustment (I can live with that) and use different (and cheaper) materials on some parts.
I have finally assembled the brakes. The bike came with low end rt10 rotors which I'm going to change them in the future, but didn't intend to do so right now.
On the shimano website they're listed as compatible with mt520 calipers as long as you use organic pads. However, the rotors are wide tipe, while the caliper uses narrow pads. This means that part of the rotor track, on the inside, is unused by the pads. Will this cause any problem?
EDIT: finally managed to ride with the new brakes. No problems with the rotors as far as I was able to notice. Excellent brakes for 112€, gone back to effortless one finger braking which is really nice.
