For the love of English 3 speeds...
#9876
Bikes: 1969 schwinn sting ray 3 speed stick ...1974 raleigh sports
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
#9878
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times
Well, it can be ridden now. But though I have the headlamp temporary installed it all works good enough until I find the correct light bracket. I still am mulling over the saddle and my new aluminum rims are on their way. Will need to get some spokes, but in any case, it can be ridden as is while waiting to amass the parts for Phase II.
The Miller dynamo:
The light set I already had in a junk box from an earlier project bike. The hub still will not go into first either, but, all is good in time I am sure or if not more money will make it so.
Sooo, on the spokes, one more question and I will leave y'all alone, for the CR18 rims, exactly what sizes spokes do I order (36 spoked wheels) and spoke washers?
J
The Miller dynamo:
J
#9879
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
#9880
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
The Miller dynamo:
J
I've never used washers on the CR18s and never had a problem. I've likely built about 12 wheels using them and DT Swiss spokes. It seems to me they are slightly shorter than the original spokes on account of the construction of the CR-18 itself.
#9881
Liked 443 Times
#9882
Quoted: 478 Post(s)
Liked 634 Times
PS. I haven't used washers but that doesn't mean its right, it means I was lazy.
PPS. Is the shift wire completely taut when you are trying to get into 1st? Are you sure you aren't *in* first? The wire simply moves a cross shaped clutch from place to place inside the hub, and there should not be much that can get in the way of that....
#9884
So does this count?
It's got an English 3 speed hub, AW, even if the bike might not quite be English At least it's very fast, geared at 40-18 for 45, 60 and 80 gear inches. Not so much in the snow, unfortunately it just keeps snowing and snowing
#9885
Quoted: 278 Post(s)
Liked 71 Times
Best bet is to look up a spoke length calculator....some have the common rims and hubs already in their database. Assume you will use Cross-3, plug in your numbers and it will tell you what length to use. If you don't find your hub or rims in the database, I like this one Spoke length calculator for wheel building because it tells you how to measure the various dimensions of the hub, and you can get the ERD (Effective Rim Diameter) of the CR18 rims from their site. Use these numbers and the tool will calculate the spoke length for you. I used this on on my last set of wheels and they were nigh on perfect.
I am sorry but to ask more questions unfortunately:
1. Spoke washers, uh, like I see no room, especially on the front hub, to put any washers that the washers would not be over ridden by the crossing spoke?
2. The new CR18 rims, 650A are much more narrow than the rims on the bike. I had expected they might be somewhat more narrow but this is considerable. What is the collective wisdom here?
Thanks.
J
#9886
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
#9887
Quoted: 278 Post(s)
Liked 71 Times
Not sure what your concern is here. The washers go between the spoke head and the hub flange, to compensate for the thinness of the steel hub flange versus the thicker aluminum flange the spokes were designed to work with.
Yes, the 590mm ERD 590 CR-18 rims are much narrower than the OEM rims, but I have had no problem using ETRTO 38-590 tires on CR-18 rims.
https://www.suncomponents.com/produc...y/classic-l20/
And on the spokes, here is what I mean. I see the brass washers on several spoke sites and they do not look like they would fit here:
#9888
Old fart
Liked 3,400 Times
Why do we prefer the 22mm outside width CR18 vs this with a 20mm inside width for English 3 speeds?
#9890
Quoted: 1610 Post(s)
Liked 2,592 Times
For removing grips, I prefer water or something slimy like soapy water. You can spray Fantastik or something similar. This stuff dries a lot faster than WD40.
You can attach dynamo wire with silicon glue. Secure it temporarily with zip ties until the glue dries. This way, you can put the wire on the inside of the fork and make it nearly invisible.
#9891
Quoted: 478 Post(s)
Liked 634 Times
Are you sure about that - I believe they go under the head of the spokes at the hub end - after all they are there to make up for the extra space today's spokes have for fitting to thicker flanges. Of course, I don't know for sure as I don't use spoke washers, but I cannot image why you would need them under the nipples....
#9892
Old fart
Liked 3,400 Times
Nipple washers go between the nipple and the rim, and are used on rims that lack ferruled spoke holes. Spoke washers go under the head of the spoke and are used to either compensate for a thin hub flange or an oversize spoke hole in the hub.
#9893
Quoted: 359 Post(s)
Liked 265 Times
#9894
Quoted: 478 Post(s)
Liked 634 Times
Looks like we were both right - different washers for different purposes. I haven't used them at either end, but do know that when taking apart some old rusted italian wheels I did find some oval washers under the nipples....
#9895
Quoted: 278 Post(s)
Liked 71 Times
DT Swiss Proline Spoke Head Washers, Box of 1000 - for 1.8 to 2.0 Spokes
This is what I thought you guys were telling me I needed to get. Thus my question, I see how these would work on the rear SA hub but on the front hub I am not so sure they would work?
The Sun CR18 wheels have a ferrule.
What are those large saddle satchels I see in many photos/
Is there a replacement seat post (alloy)?
Is there a replacement steering stem with greater offset?
Handlebars that are appropriate in alloy with more forward sweep?
Yes, I am looking, all over the web but being new to English 3 speeds this is all very confusing. Woe upon me .
J
J
#9896
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
J
J
This is one of those things that have a long, gradual learning curve. Just as the bikes themselves are suited to slow, steady progress; so are most of us who love them. So we gather the wisdom and lore of those who went before us, sometimes by actual face-to-face conversation (!) - then acquire the special tools and the skills to use them, and we spend long, winter nights in shed or shop learning by doing. If you are patient and persistent enough, perhaps Saint Sheldon will smile down upon you when you wheel that Sturmey-Archer steel out into the Spring sunshine for your first test ride.
At least, that's what I read on the internets somewhere...
#9897
Old fart
Liked 3,400 Times
#9898
Quoted: 278 Post(s)
Liked 71 Times
Today, I had opportunity to ride a 23 inch Sports. Yes, I adjusted the seat and bars. My current 21 inch Sports feels completely different. The 21 is taught yet stable and the 23 felt sort of mushy and complacent. I was also nearly bolt upright on the 23 inch frame and even with the bars/stem pushed way down I just could not get myself comfortable. I was about to buy the 23 and still may but for somebody, >me<, who is still a somewhat (mildly) aggressive rider and in decent physical fitness (swim, bike, run) I am just not liking sitting so upright. That said, I have dropped the saddle a wee bit on my 21 after fiddling with the bike and it is very comfortable save for one thing, I could use a longer stem.
Anyway, my point being, I was surprised at how different the two bikes felt, and I admit, I am not an expert on Raleigh 3 speeds. But I felt a huge difference. The 23 just felt huge under me, the 21 feel right. And I have no saddle time in either so it is not that I am just used to the smaller frame 21 inch Sports.
I did see in a catalog that Raleigh recommended the 21 for 5'6" and under and the 23 for upward of that. I suspect they had a more leisurely riding style in mind sitting straight up on their British posteriors. And despite having an 86cm cycling inseam (PBH with bare feet) I felt a little bit crowded by the top tube. I think my Surly CC with its low top tube height has me spoiled in that regard .
I am a swimmer and a runner, cycling is just something I do when I am to beat up for anything but cycling . Or is it the other way around, hmmmm.
#9899
Quoted: 1299 Post(s)
Liked 103 Times
J
J
Inflate Hard
Inflate Hard
#9900
Are there any vintage 3-speeds that a "sportier"/ different ride than Raleigh's Sports model? I know they made racing and geared bikes that might likely have different riding characteristics. Or are their more nimble frames all geared?
