less lung capacity = sad.
Quoted: 722 Post(s)
Liked 353 Times
my lung capacity i fear has diminished to were it is now obvious and that makes me sad. not sure if it is allergic reaction or poor air quality but the past few weeks I have struggled. was feeling strong a month ago.
riding in the crazy heat maybe why but I fear maybe mother nature got me.
Quoted: 5888 Post(s)
Liked 3,471 Times
I think it's all about dealing positively with the changes as we get older. I find that as I became older, I had to raise my handlebars so they are now that more or less level with my seat. Fatter tires became a beautiful thing as my speed went down. I also keep an eye on my intensity level. I still like to go hard but I know my recovery times are longer and I keep any eye on my sleep.
Likes For bikemig:
Quoted: 1069 Post(s)
Liked 788 Times
There are advantages to going slower; all those things you sped by without noticing before are now there to be gawked at. As Monty Python said: "Always look at the bright side of life." 😎 With the 30+ lb tank I ride, going fast has never been an option for me. Just doing 40 miles yesterday took me 4 and a half hours, but it was a fun 4.5 hours, with many white-tailed deer, squirrels, rabbits, chipmunks, one groundhog, flowers (where one would least expect them), horseshoe lake, and several interesting characters out on the trail (I know, I'm one of 'em!)
Quoted: 427 Post(s)
Liked 700 Times
We've had what the weather folks in this area describe as "Amazon air" or "the air you wear". Dew point has been way up, making it feel lots hotter that the temp would indicate. Air quality has been poor off and on. There have been days where I was really feeling it, even without a lot of exertion. Hopefully, it's the air, and not your lungs. I don't think it's my lungs, but I've felt it more this year that I ever remember in the past. Looking forward to fall.
Quoted: 663 Post(s)
Liked 496 Times
The slower you go the more you will see. Heat and humidity have their effect but you will inevitably reach a point in your life where going a bit slower will seem a good idea.
Quoted: 3241 Post(s)
Liked 2,512 Times
I thought the same thing 3 weeks ago when marathon training started back up and I had to start running again. That first weekend run I couldn't go more than 100 yards trying to hold a pace before I was gasping/couldn't breathe. I starting actively concentrating on my breathing trying to make it as efficient as possible, even exaggerating it to move as much air as possible. I sounded/sound like a fool going down the road, but the problem went away. In fact, once I started doing that, the difference in heart rate was noticeable. The heart rate starts dropping when I step up the breathing efforts. It wasn't that my lung capacity had decreased, it was that I wasn't using it properly. Not even close. I had gotten lazy. Give it a try before you give up.
Edit: I missed the 2nd weekend run. Evidently the first run was so bad, some people thought I needed to see a doctor. At the start of Saturday's run, some of the other runner's ask about my condition. They thought I was having problems on that first run. I'm glad they cared enough to ask.
Quoted: 8286 Post(s)
Liked 9,055 Times
Have you been checked for asthma or other lung issues? They (docs) say I have asthma and/or COPD. I used the Treligy inhaler for a while 2 years ago and now I use Albuterol before a longer ride and it helps my breathing.
Likes For big john:
just another gosling
Quoted: 3889 Post(s)
Liked 1,939 Times
Results matter
Results matter
Quoted: 6196 Post(s)
Liked 4,811 Times
I've always felt limited by my lungs. They simply don't blow off enough CO2 and take in enough O2.
It's pretty much the limiting thing for many of the pros too.
I do try on a daily basis to take as deep a breath as I can and then expel as much as I can, slowly. If it makes you cough, then you definitely need to do them regularly. A handful of reps each day does wonders.
I've sometimes tried to see if deep breathing helps while riding for things like climbing at short high efforts. But I get mixed results. Problem usually, I think, is that for me real deep breaths happen at too slow a rate.
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
I just ride with my phone to record it to Strava and don't bother with a Garmin device (not that those are much help now!!!). The most important thing is get out and ride, no mind blowing epiphany there. Some days I feel charged and take on the hills and any rider that goes past me and other days I don't feel it so I just ride and enjoy the scenery. As I saw in a previous post, you never regret going for a ride but you regret not going. I do find the environment has an impact - hot days really drain me, if not during the ride, then the rest of the day after. High pollen time and my sinuses are stuffed up so that also has an impact. Nothing better than a perfect temperature, no humidity and no wind.
I guess if you are training for a triathlon or race then you are constantly monitoring your effort but that's not for me. Just follow a consistent pattern of getting out and getting exercise and fresh air and keeping the brain sharp by focusing on the road. I'm finding lately that some days my brain is a little slower then it should be but it clears up once I start riding.
Quoted: 722 Post(s)
Liked 353 Times
I checked o2 pulse ox. 97 so that's good I guess.
Liked 4,811 Times
If you got a O2 checker that is portable, then it might be interesting to check it at various efforts while riding. Not sure about the physiology of what that'll tell us or at what level it's bad and what is great. But it'd be interesting to see if the number is lower when at high effort.
But it definitely would not hurt to ask a doctor about your lungs health. A pulmonologist if you can.
Liked 9,055 Times
I don't know but what happens to me is my chest feels tight or it feels hard to take deep breaths. It's not terrible but annoying and when I use the Albuterol inhaler I can cough up some crud and then I can breathe easier. I don't use it all the time but it does help. If I'm riding and I have symptoms I can still ride but I don't feel like my lungs are working well, like you described.
Quoted: 4560 Post(s)
Liked 2,802 Times
Yeah, my immunologist has done respiratory capacity tests on me this year, two or three times, and says my capacity is good for a 60something y/o. The new nasal and asthma inhalers help some. But I know I can't do what I used to. VO2 Max declines no matter what. I can still manage a good sprint and hard effort for a few minutes, but I can't sustain it for an hour or more now. On group rides with younger folks I fade after about 20 minutes and let 'em go.
I can't do back to back workout rides anymore, but can still manage one good hard ride a week. The rest of the time I ease up and don't worry about turning every ride into a workout.
Likes For canklecat:
Let's do a Century
Quoted: 651 Post(s)
Liked 879 Times
Heat + Humidity + Older= Lower VO2 & Power.
Just keep your HR down a little lower and keep pedaling!
Ride your Ride!!
Ride your Ride!!
Bikes: '06 Bianchi Pista; '57 Maclean; '10 Scott CR1 Pro; 2005 Trek 2000 Tandem; '09 Comotion Macchiato Tandem; 199? Novara Road; '17 Circe Helios e-tandem:1994 Trek 2300
Quoted: 147 Post(s)
Liked 93 Times
Likes For Artmo:
Even after recovering from CV 19, the resultant scar tissue means permanent loss of lung capacity..
Liked 1,939 Times
97 isn't that great. My asthmatic wife is at 99, as am I. Pulmonologist appointment. My wife uses a peak flow meter. A toot on that thing keeps you knowledgeable about your current ability to move the air in and out.
Results matter
Results matter
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
I would suggest you get yourself a simple spirometer from Walmart or Amazon. With this you can measure your lung function see what is considered normal for your age. I’ve suffered from asthma since age 4 and am now 80, with mild COPD. My lung function is about 70 per cent of what it should be for my age and height, so I know how you feel. These days it takes me two or more Albuterol puffs, 10 miles at 80rpm and 13 mph before my lungs are really working at their optimal level. Frustrating, but there it is.
Great tool with limitations.
Make sure you have a good professional diagnosis.
My buddy's "asthma" on rides, proved to be advanced 4 vessel obstruction and atypical angina.
He did much better after he got a "full metal jacket"
Likes For bikebikebike:
