Dealing with SI joint issues?
Bikes: 2001 Waterford RST-22, 2002 Gunnar Sport, 1999 Trek 520 gravel grinder
Quoted: 35 Post(s)
Liked 5 Times
I'd be doing longer distances and climbing more hills if it weren't for an ongoing problem with my left sacroiliac joint. I've been to a physical therapist, who said the joint is hypermobile and gave me an SI belt to hold things in place. And then I went to a chiropractor, who said the joint is HYPOmobile and needs to be adjusted/stretched to regain some movement. Talk about your conflicting feedback! The problem isn't bad while I'm spinning easily. It gets worse when I try to climb seated and put a lot of torque on the pedals.
Has anyone else experienced this? And, if so, were you able to have it treated (or self-treat it) successfully? Thanks in advance for your input!
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Don't take this wrong, but my guess is that you're just weak in that area. Most folks are, especially the 50+. Those lower back muscles and tendons are all part of the posterior chain. When you push down hard on the pedals, the chain of force and therefore strain goes all the way up to your shoulder blades Google "posterior chain exercises" and start doing them, like all of them. Gym membership should be in your immediate future. It'll take a year to make substantial progress. Start light with high reps and slowly increase the weight or effort. Turning back the clock takes effort and concentration but it works.
Results matter
Results matter
Quoted: 35 Post(s)
Liked 5 Times
Thank you for the input. I'll definitely check out the posterior chain exercises. For the record, I have been in the gym, working mostly on core strength and aerobic capacity, since last Sept. 21. I've made significant gains, but apparently still have a way to go. Thanks again.
Bikes: Shmikes
Quoted: 10175 Post(s)
Liked 5,871 Times
Anecdotally and with no knowledge of your situation, I agree with CFB. I started a program of core strengthening with emphasis on the posterior chain (and the posterior) after a serious lumbar disk situation and it really helped me with position on the bike, strength, and standing up and walking pain free like an athlete again. Cyclists typically have weak glutes and you can crack an egg on my ass now.
Real SI arthroses are rare, according to conventional medicine, and pain from quadratus lumborum strain, which is common, locates near the SI joint. The QL is part of that posterior chain and is protected and supported by the glutes.
Good luck!
Good luck!
Physical therapist >>> chiropractor.
Momento mori, amor fati.
Bikes: Shmikes
Liked 5,871 Times
Bikes: 1986 KHS Fiero, 1989 Trek 950, 1990 Trek 7000, 1991 Gary Fisher Hoo Koo E Koo, 1992 Trek 1400, 1997 Cannondale CAD2 R300, 1998 Cannondale CAD2 R200, 2002 Marin San Rafael, 2006 Cannondale CAAD8 R1000, 2010 Performance Access XCL9R
Quoted: 284 Post(s)
Liked 385 Times
I had a severe issue with my SI out of whack last year. I had spent 6 weeks no weight bearing on my right foot due to achilles tendon repair. I borrowed one of those cool knee carts. But, never one to do things normal, I was moving quickly through the stores, or anywhere I was using it. At speed, all my weight was on the one side, and over time, that got me twisted. Ultimately, I wound up in the ER with sever cramping from the backs of both knees all the way to my shoulders... And then, things cramped my sciatica nerves... Anyway, my favorite Physical Therapist, had me rotating my hips, laying down in a number of different exercises, complete with breathing exercises coordinated to the rest... No trouble since.
