Rotation Limiting Headset Hunt.
Old 03-19-17, 03:16 PM
Deaner
Quoted: 5 Post(s)
Originally Posted by tombc
After the strap it seems the spring stabilizer is the next most simple, time tested, classic and easy to implement solution. You could remove the plastic sheath.
Ive given it consideration, and may well braze another bottle boss to avoid the clamp. I am thinking that to improve it I ought to run a braided steel cable through the inside of the spring, thereby giving me a hard stop as well as the tension provided by the spring. THough a project such as this will have to wait until I am ready for a new paint job...
Deaner is offline
Old 03-19-17, 03:30 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Alan (# 23) is there, in DC.* IDK Where You Are..
*one wall is black granite with the names of thousands of people who did not get to be my age, now..
fietsbob is offline
Likes For fietsbob:
Old 03-19-17, 03:36 PM
fietsbob
Bikes: 8
I have a One Off Bike with a unique fork crown that bumps against a Nylon Block on the Down Tube, when the wheel swings,
that is also my Front Derailleur cable stop.
Its a different one than the Koga .
fietsbob is offline
Old 03-19-17, 04:23 PM
J.Higgins
2-Wheeled Fool
J.Higgins's Avatar
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times in 457 Posts
Originally Posted by Doug64
I suspect front wheel flop is more of a problem when using a kick stand.
I suspect that you are correct, sir!
J.Higgins is offline
Old 03-19-17, 08:04 PM
alan s
alan s's Avatar
Quoted: 1496 Post(s)
Liked 189 Times in 128 Posts
Not that wall, of course.
alan s is offline
Old 03-20-17, 12:12 PM
seeker333
seeker333's Avatar
Bikes: yes!
Quoted: 282 Post(s)
Liked 38 Times in 36 Posts
Originally Posted by Deaner
I need help finding a solution to keep my handlebars from rotating and hitting my top tube...
https://www.sjscycles.co.uk/frames/t...-inch/?geoc=US
Thorn's "steering lock" should work provided:
a. you have >10mm of headset spacer on a 1 1/8" fork steerer tube to permit striker installation, and
b. your headtube has >10mm of extension above toptube junction and an OD of ~37mm to permit limiter installation. You need striker and limiter parts for a complete "steering lock". Make sure all fasteners are included since they are probably not a stock item at the Local Hardware Store.
Headtubes with 37mm OD are typical for steel frames designed to accommodate forks with 28.6mm (1.125") steerers. For example, the Thorn "steering lock" will fit a Surly LHT/DT (28.6mm steerer/30-40mm HT extension/37.3mm HT OD).
Obviously a velcro strap, mini bungee or paracord through the wheel and over the downtube will also immobilize the fork/wheel/rack/luggage, saving ~60g and $60. I prefer the simple/cheap solution in this case.
seeker333 is offline
Old 03-20-17, 12:27 PM
edthesped
edthesped's Avatar
Quoted: 188 Post(s)
Liked 3 Times in 3 Posts
NM this must be what you're referring to on the REI bikes...
Doesn't FSA make one called the headblock???
https://ebike.hu/products/steering/h...-hbs-1-1-8-90/
edthesped is offline
Old 03-20-17, 12:48 PM
Deaner
Quoted: 5 Post(s)
The link you posted is what rei specs on some f their frame, it is unfortunately not available from fsa, they just put their name on it. In design it seems very similar to the Acros so I wonder if there is some weird licensing restrictions going on. The link you posted is the only other place on the web I have found mention of the headblock. I am really hoping that it will pop up somewhere else though.
Deaner is offline
Old 03-20-17, 12:51 PM
Deaner
Quoted: 5 Post(s)
Thank you, this is exactly the sort of thing I was looking for. I don't mind 60 grams so I will probably be getting this unless something pops up.
Do you have any personal experience with this?
Deaner is offline
Old 03-20-17, 01:16 PM
fietsbob
Bikes: 8
On my Bike With a front Porteur rack on the down tube, I have a Strap with a Side Release Buckle. Its quick to use..
fietsbob is offline
Old 03-20-17, 01:25 PM
Leebo
Bikes: Kona Dawg, Surly 1x1, Karate Monkey, Rockhopper, Crosscheck , Burley Runabout,
Quoted: 854 Post(s)
Liked 111 Times in 66 Posts
Originally Posted by NoControl
My wife carries a hair scrunchie on her bike. When she parks, she doubles it up and slips it over her brake lever, engaging the brake. The bike does not move, and does not fall. Problem solved. I do the same thing now, except I use a fat rubber band. I saw what the wife was doing, and I said to her, "Honey, get me a rubber band, and make it snappy!"
Cut a section of 26" inner tube, works well for brake levers.
Leebo is offline
Old 03-20-17, 01:35 PM
edthesped
edthesped's Avatar
Quoted: 188 Post(s)
Yeah, I figured that out when I tried to find one for sale... Sorry.
Old 04-02-17, 12:29 AM
Medic Zero
Medic Zero's Avatar
Bikes: Old steel GT's, for touring and commuting
Quoted: 39 Post(s)
FWIW, I tried the Batavus one, and ended up removing it a few months later as it was ineffective. Any real load on the front rack overpowered it and the front wheel flopped anyway. It appeared to be designed so that you could overpower the lock so that you didn't cycle away from a halt with your handlebars locked and unable to maneuver. Unfortunately, this overzealous safety measure made the whole thing basically useless.
If for some reason someone still wanted to try that one, even with the above knowledge, you should also know it's just half a headset, the upper half. If your old headset is toast, you'd still need to source a lower.
I realize this doesn't address the OP's problem, but since that product came up in this thread I felt like I should share my experience with it, particularly when I posted about it last year before I got it, no one had ever used one here before.
Medic Zero is offline
Old 04-02-17, 04:55 PM
Snuts
Mid Tour!
Snuts's Avatar
Bikes: Marin Muirwoods Racked out for this years Tour, Norco Indi 4 racked out from last years tour, Giant Defi II for week-end ripps.
Quoted: 152 Post(s)
Liked 4 Times in 3 Posts
I install a piece of self adhesive Velcro tape on the down tube, Makes it a one handed operation.
The pictures show how it works, and stores.
-Snuts-
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Snuts is offline
Old 04-02-17, 09:20 PM
Deaner
Quoted: 5 Post(s)
Cool. Thanks for the insight.
Did you get a 1" threaded headset from Batavus, or is it a 1 1/8" one? Are you still using the headset?
Deaner is offline
Deaner
Quoted: 5 Post(s)
-Snuts-
That looks like a pretty good solution, thanks.
Deaner is offline
Old 04-04-17, 09:38 PM
Medic Zero
Medic Zero's Avatar
Quoted: 39 Post(s)
1" threaded. Don't recall where I sourced it from, might have been ebay. I didn't realize it was a Batavus branded product until this thread. IIRC, it's actually a Shimano product, something like "HPX-10".
I'm not still using it, since it wasn't effective at what it was supposed to do, wasn't a very smooth headset, and was ugly and clunky, I swapped it out for a regular headset. A ~$30 headset was far smoother than the Batavus/Shimano locking one.
Old 12-10-18, 10:20 AM
acidfast7
Bikes: 2010 Cube Acid / 2013 Mango FGSS
Quoted: 1053 Post(s)
Liked 41 Times in 36 Posts
https://shop.tout-terrain.de/bicycle...ergo-stop-plus
acidfast7 is offline
Old 12-10-18, 10:29 AM
Deaner
Quoted: 5 Post(s)
This is just what I was looking for. Currently I put on a really strong spring, but this would be better.
I suppose however I will have to get out the brazing torch to add the stops onto my headtube as this seem to be a proprietary design.
Deaner is offline
Old 12-10-18, 10:53 AM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,932 Times in 2,557 Posts
Another very clean way to accomplish the same thing - use a brake cable quick-release, but ride with it "off" and put it "on" to park. For years I had a QR hanger on the seat on for cantilever brakes. On was for parking. I simply slipped the bridle off to pull the wheel. Another place where many bikes have brake QRs is in the brake lever. If you have both that and the QR at the caliper, you can use the caliper one as your parking brake.
Ben
79pmooney is offline
Old 12-11-18, 10:33 AM
JaccoW
Overdoing projects
JaccoW's Avatar
Quoted: 784 Post(s)
Liked 1,238 Times in 686 Posts
HBS Headset 1 1/8 Inch With Headset Lock - Black
The only problem I might see is that it is "semi-integreated" so maybe not a full ahead stem.
JaccoW is offline
Old 04-08-19, 03:49 PM
Deaner
Quoted: 5 Post(s)
Looks like it might be for 1 1/8" threaded but its hard to tell. If the
Next time I am Europe way I will give them a call.
Deaner is offline
Old 04-08-19, 11:57 PM
Rick
Quoted: 626 Post(s)
Liked 401 Times in 277 Posts
STEERSTOPPER will hold the front end completely straight and comes with an adjustable elastic to place over the handlebar and around the brake handle.
Rick is online now
Old 04-09-19, 10:05 AM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1908 Post(s)
Liked 574 Times in 339 Posts
Did anyone mention Velo Orange's wheel stablilzer?
https://velo-orange.com/collections/...eel-stabilizer
Or the venerable Rhode Gear "Flickstand"?
GearInches.com » flickstand
https://www.ebay.com/itm/153432289276
www.rhmsaddles.com.
rhm is offline
Old 04-12-19, 10:48 AM
bwgride
Slow Rider
bwgride's Avatar
Quoted: 38 Post(s)
Review of an option
Cane Creek ViscoSet Review - BIKEPACKING.com
bwgride is offline
