Are these tire cuts too big?
aged to perfection
Quoted: 862 Post(s)
Liked 1,297 Times
I would suggest that tire is a candidate for replacement.
not only cuts but based on general condition.
but what do I know ?
/markp
/markp
Likes For mpetry912:
Clark W. Griswold
Quoted: 4493 Post(s)
Liked 4,172 Times
That doesn't look like a tire I would ride on anymore. If it were an emergency and I had to run it I guess but I would just replace it
Likes For veganbikes:
Klaatu..Verata..Necktie?
Quoted: 10601 Post(s)
Liked 12,206 Times
On the plus side, it's an excellent candidate for indoor trainer use!
Quoted: 1006 Post(s)
Liked 1,687 Times
I can't afford any kind of tire failure so I would have to replace the tire.
If this had happened on the road and the tire was still holding air, I would simply use a flat fix patch on the outside of the tire to get home. I have found the problem with these type cuts is they keep expanding and the tire becomes deformed eventually loosing its bead or air.
Likes For zandoval:
Quoted: 6346 Post(s)
Liked 4,948 Times
Does the tire in the picture have any air pressure in it?
Usually the tell for me is if the cut puckers out like grandma's lips wanting a smooch. Then I know too many of the cords/threads have been cut and it's unlikely to last very long. Not that it's really unsafe. Just that it might give out soon and leave you with no tire for the new tube in the bike bag.
But yeah, if my tire had cuts that big, then likely they threads were cut too. So it'd be puckering up when inflated and I'd be changing the tire. For roadside emergencies you can boot it by putting something between the tube and the cut. $1 bills work. $100 bills work better. Or cut out the side of a plastic bottle and lay that in there.
But if it's tubeless or tubed, and the picture is with it aired up to your normal riding pressure, then I probably would ride for my normal out and backs it till it gives out completely. Though if my next ride was a long ride or a real important ride, I'd probably change it.
Quoted: 4598 Post(s)
Liked 5,143 Times
It depends how bothered you are about the risk of it failing. If I get cuts like that then the tyre goes straight in the bin without a second thought. Tyres are the most important component on the whole bike.
Likes For Paul Barnard:
Quoted: 4874 Post(s)
Liked 4,040 Times
I've repaired quality (and expensive) tires with slits like that and larger (cutting the cord) with real sailcloth glued in with contractor grade contact cement (the stuff you bond countertops down with) and run the tires without incident until it was road tired and dead.
Note: real Dacron sailcloth from a sailmaker, not the stuff Joann's Fabrics sells.
Should Be More Popular
Quoted: 22732 Post(s)
Liked 9,099 Times
Bikes: yes, i have one
Quoted: 1152 Post(s)
Liked 1,195 Times
Why do we seem to get some really crappy out of focus pictures and a request to make heads or tails out of it.
can't tell how bad from pic. Ride them on easy rides I suppose.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,344 Times
As long as the cord are not compromised and you don't mind walking if they are, they won't assplode on you.
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
If no cords seem to be cut, I'd be tempted to pump it up and dab some Shoe Goo into the cracks to protect the innards. But I wouldn't run it on the front again.
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 378 Post(s)
Liked 480 Times
That tire looks blitzed to me.
For a boot, the thin envelope material (Tyvex?) from fedex, usps, or ups works better than a dollar bill.
Cut it up into nice little strips and pack it into your patch kit.
Mad bike riding scientist
Quoted: 6276 Post(s)
Liked 4,303 Times
All of the cuts look like they have cut into the tire casing. The tire won’t necessarily blow out but it can develop instabilities that make it look like a snake belly and that can impact the ride and control. Minor cuts to the tread are okay but when they go deeper, the tire should be replaced.
Stuart Black
Stuart Black
Likes For cyccommute:
Bikes: Shmikes
Quoted: 10218 Post(s)
Liked 5,934 Times
Bikes: 1999 Bike friday NWT, 2009 Bike Friday Tikit, 2023 silverock Dewy, 2008 Dahon Smooth Hound, 2023 Litepro Trifold
Quoted: 206 Post(s)
Liked 250 Times
The only thing between you and the road surface is your tire, that rubber patch touching the road is really small. So, tires and brakes are the most important safety components on the bike. I would replace those tires unless the financial cost is unbearable.
Quoted: 517 Post(s)
Liked 657 Times
Yup. As long as the casing is not damaged, then the ride is safe. If there are bulges and distortions in the inflated tire, then at a minimum the tire needs to be booted in order to continue riding it.
There also looks to be a lot of wear on that tire, which alone would make it a candidate for replacement.
It has served you well for many miles and good times. Time to move on.
It looks perfectly fine, I wouldn't worry about it.
But, then, I'm not riding on it.
In general, I believe, where safety is involved, ' If you have to ask...'
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2701 Post(s)
Liked 5,975 Times
Superglue the cuts back together and keep an eye on them. You may need to deflate the tire a bit to do this.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Cantilever believer
Quoted: 566 Post(s)
Liked 1,956 Times
My experience has been that slick tires have a somewhat greater tendency to get cuts like the ones depicted - and since I like slick tires, I'm rather well-acquainted with the issue. As noted by others, the rubber isn't the critical structural part of the tire - it's the cords underneath and how they are connected to the beads (which do the really hard work). A risk of such cuts is that sharp debris such as glass can get lodged in them and eventually cut through the cord (and tube).
Suddenly-developing wobbles in the tire cross-section are typically where the cord layers have separated or delaminated from one another, often with some cords breaking. This is generally due to age or use - I've noticed some tires will last 5000+ miles, but others will get cord separations around 2500 miles. Note that in my experience this does not seem to be directly associated with cuts in the rubber.
This cord separation happened in April on one of my bikes. The tire was fine just a few minutes prior. I made it home OK, but replaced the tire before riding that bike again.
After replacing the tire, I inspected the inside casing where the separation occurred. Not a pretty sight:
Liked 4,303 Times
Oddly, this tire didn’t blow out. The tire split and the threads started pushing out but the tube didn’t.
These examples are a bit more extreme than others I’ve seen. This if from my daughter’s bike in Tucson so the tread probably split due to the heat as well as the breaks in the casing threads. I have had this happen in cooler Colorado, although without the splitting of the tread.
Stuart Black
Stuart Black
Quoted: 4272 Post(s)
Liked 2,990 Times
Since I'm cheap, I'd probably relegate that tire to trainer duty (assuming I still used a wheel on trainer). Doubt I'd take it out on the road anymore. More for the fact that I detest getting stuck than that I'd be worried about a blowout that led to a crash.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
