Center lock disk trouble
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
I just purchased a set of wheels with DT Swiss 350 straight pull hubs. I am trying to figure out how to get the brake disk fastened onto the front wheel. There isn't enough room between the axel and the disk lock to get the freewheel tool in. The tool wont fit over the axel.
Anyone have any experience with this?
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
What size axle is the wheel? Generally this happens with a 15mm or 20mm axle size, which requires a special lockring either Shimano SM-HB20 or Shimano HB-M8010
Quoted: 803 Post(s)
Liked 2,984 Times
sounds like you have the 20mm thru axle adapters that need to be removed first.https://dycteyr72g97f.cloudfront.net...WEB_EN_001.pdf
he said member
Bikes: yes please
Liked 1,951 Times
Yep, 20mms axel. Thanks guys!
Bikes: Trek 5600 Carbon road bike, Giant Anyroad Comax gravel bike, Cruzbike QX100
Quoted: 10 Post(s)
Liked 19 Times
There is a tool which looks like the freewheel tool, but has the ability to fit in where the freewheel tool doesn't.
he said member
Bikes: yes please
Liked 1,951 Times
Man that would have to be thin walled. There isn't any room to speak of. I did order the other lock ring, got one for $9.00 so it's probably cheaper than the tool. Thanks though.
