80 psi too low for my 700x28 tires?
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Good point. Continental has a page on their website with a nice straight answer.
They recommend choosing pressures higher than the recommended pressure.
Results matter
Results matter
Pizzaiolo Americano
There is no way for us to answer this for you. Different road conditions and rider tendencies make a difference.
Likes For Pizzaiolo Americano:
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
How often does the average rider really check their pressures? If it's monthly then the recommended pressure probably has 20psi wiggle room for this.
I am not too bad on my "fun" bikes but on my commuter I don't bother checking until they get particularly squishy.
Likes For znomit:
Quoted: 722 Post(s)
Liked 353 Times
I have foldable Continental Gatorskins (I happen to love 'em but I'm sure there may be better options) in 700x28. Someone on this forum suggested running tires at a lower pressure to help with downhill riding. This suggestion literally changed my confidence in descents. I was running 23s at max pressure and the bike always felt glitchy and on the verge of losing control. With the 28s running at 80 psi it feels like a totally different bike - for the better!
The Continental website says 95-116 is the range for this particular tire. I weigh 155 lbs and haven't experienced pinch flat (knock on wood) with 80psi. I only ride on tarmac roads (no gravel) but there are occasional potholes that I do my best to avoid. Should I be concerned about running at this low a pressure? These are NOT the hardshell versions btw.
Thanks for your insight
i got over 200lbs and i do 80 or less no issues at all.
Likes For thehammerdog:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Being an 185 pound older guy suffering from a lot of wear, a smooth ride is the only option or I would not be able to ride at all. I have folding 28mm Gaterskins with tubes on my R-300 Cannondale, probably the biggest tires I can fit on it. Without my body complaining, the highest pressures I am able to run on my local not-so-smooth roads are 40 psi front and 45 psi rear. I am not racing, just trying to keep in shape on these hills. I do ride regular, but I don't ride the mileages a lot of you guys do, and I have not noticed the bike being sluggish or squirrelly at all.
My ideal Geezer Road Ride has 40mm tires which I run at 35 psi front and 40 psi rear.
Someone is probably going to jump my case about my pressures, but hey, they work for me and might work for someone else. For me it's a matter of riding or not.
Fred
Fred
Likes For cxwrench:
Enthusiastic Sufferer
Bikes: 2015 Specialized Roubaix, 2014 Salsa Fargo, 2013 Trek Remedy, 2014 Cannondale Synapse
Quoted: 124 Post(s)
Liked 311 Times
I'm 170lbs. I ride 28s tubed with 65F/70R. You'll be good!
Likes For SapInMyBlood:
Quoted: 4806 Post(s)
Liked 3,930 Times
Totally old-school here. I run 28c at around 90 psi. Love the ride on the Vittoria G+/G2.0s. (Might run a touch less on 28c Paselas. They are both stiffer and probably bigger. Also less traction but that I take into account on how fast I will do corners.)
I state my tire pressures as the average with 2-3 psi less in front, 2-3 psi more in back. Been riding that roughly 5 psi difference many years.
Likes For 79pmooney:
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Gatorskins have a stiff, puncture proof sidewall. If you run them at low pressure they'll roll very poorly. Not that they roll well at any pressure to begin with.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Likes For sfrider:
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
I won't go back to Gatorskins, the difference in puncture resistance (marginal) is not worth the difference in road feel/resistance (significant).
Likes For Leinster:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Interesting, the calculator I use to get starting points for pressure spit out around 70-ish psi for you.
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I was at the LBS today and the mechanic was recommending the GP 4000 all weather. He said they roll similar to the GP 5000. He said the 5000 is a race day tire and the 4000 all weather has an additional layer making it more puncture resistant. Any opinions here?
thx
thx
Quoted: 338 Post(s)
Liked 408 Times
GP5000s also have an anti-puncture layer and are imo the best performance-oriented all around tire. They're actually the best rolling tire which has an anti-puncture layer and reasonably thick thread, all the better rolling tires are significantly thinner TT style tires without a puncture resistance layer. Continental really hit the spot with the GP5000, they've got both the durability and puncture resistance and the rolling resistance and grip.
Bikes: Shmikes
Quoted: 10175 Post(s)
Liked 5,871 Times
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
I’ve also had a positive experience with the 5000. 3000 miles on my pair, just finally getting into new tire territory and no flats.
I run 28s at 60/60 weighing in the 170s
Likes For phrantic09:
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,532 Times
Splitting the difference, a tire I'd like to try sometime in the future for general training usage is the Pirelli Velo 4S. Looks to be a good compromise of protection and performance.
Quoted: 2483 Post(s)
Liked 2,955 Times
Thus, according to the illustrated information, the recommended pressure for a 23-mm tire is 110 psi, but the pressure can be adjusted upward or downward throughout the indicated (albeit unspecified) range, at the user's discretion. For example, at my present weight of about 125 pounds, I usually pump my 23-mm tires to around 80 or 85 psi. And that's the pressure the day I inflate the tires. I often find that they're down to 65 psi or so by the next time that I inflate them.
Liked 3,930 Times
I use the Paselas on my winter/city/rain bikes. (Except not on below freezing roads; not all that common here in Portland.) They are not bulletproof but are so good at not picking up glass and debris that I don't get very many flats. Beads are not tight so road changes are easy. Quality and consistency is very good. Despite the non-tight beads, too loose is something I haven't seen. (I've been riding those tires 12? years and maybe 30,000 miles on several bikes. They are super consistent.) I ride mostly the cheaper (and easier to mount) wire beaded ones but have had very good experiences with all I've used from 25c to 38c. I love the width choices.
All that said, they are a far cry from the sweet Vittoria G+ and G2.0s I ride on my good bikes. Those tires get better grip, a lot better in the wet, roll faster, have better feel, are a bunch lighter and don't get a lot more flats. They do cost twice as much and don't last as long. But if I am going to be riding my good bike on iffy roads. I throw those Paselas on and the bike doesn't become a dog.
I am a light, long, skinny rider. Tires with thick casing and less than grippy tread slide out under me on marginal road surfaces which are common here in rain country. One of my criteria is keeping my skin off the pavement.
Quoted: 283 Post(s)
Liked 262 Times
You need enough tire pressure to protect the rim you have from the road conditions you ride on. A pinch flat is a tube / tire issue, but denting your rim in a pothole / on broken pavement is hugely worse. You will get advice to keep lowering your pressure until things go sideways on a ride and you ... dent your rim. If Conti says 95 I wouldn't go below 90, knowing the gauge might be off and we're really at 85.
Likes For grizzly59:
jj
Quoted: 140 Post(s)
Liked 110 Times
I’ve got wider rims. In the summer on easy weekend rides I’m good to go out the door with my pump telling me I put 50 in the front and 60 in the back, whether it’s Vittoria Corsas or Conti GP5Ks in 28mm. Below 30F outside and in commuting traffic and I jack it up to 85/100 before heading out- no idea what that measures after ten minutes in the cold.
Bikes: lots
Liked 2,932 Times
So in the cold when you have less traction you raise the pressure a bunch?!?
Likes For cxwrench:
I've rejuvenated my 30+ year old Silca pump with a new Hirame chuck and a new and much larger liquid filled 0-100 psi gauge that's accurate to plus or minus 1.5%. Now I can read the gauge easily and be confident in the pressure. The old gauge was reading about 8 psi higher than the actual pressure.
https://cimg8.ibsrv.net/gimg/bikefor...00b021c44a.jpg
