Single Speed Conversion
Hi guys, completely new to bike mechanics but i have set myself a little project and am looking for some advice. I m converting an old Raleigh Mountain bike into a single speed. I am trying to choose a single speed conversion kit to use. What exactly do i need to be looking out for??? Cheers..
Quoted: 1572 Post(s)
Liked 643 Times
The easiest way is to start with a bike that has horizontal dropouts because, on a single speed you don't have the derailleur's slack take up arm so you need a way to adjust the chain tension.
The next issue is how to replace the multiple rear cogs:
If you have a spin-on freewheel, a single speed freewheel is a direct replacement. They come in two cog thicknesses so you need to match the chain that you are using. You also need your new rear cog to line up pretty well with your front chainring. Usually the middle chainring position works best.
If you have a cassette rear hub you'll need to buy or make some spacers to replace the cogs that you aren't going to use. The nice thing about this is that you can adjust the position of your rear cog to match the chain line of your crankset.
Quoted: 608 Post(s)
Liked 352 Times
Does your bike have a cassette or freewheel? If cassette buy a spacer kit like this one.
Surly Single Speed Spacer Kit > Components > Drivetrain > Single Speed Cogs | Jenson USA
You will also need a cog. You can use one from the cassette you just took off or buy a single cog like this. Surly Single Speed Cog > Components > Drivetrain > Single Speed Cogs | Jenson USA
If freewheel, then you need something like this.
Shimano DX Single Speed Freewheel > Components > Drivetrain > Single Speed Cogs | Jenson USA. You will need to redish your rear wheel if you go this route.
If your bike has horizontal dropouts you don't need to purchase this next product. If vertical dropouts you need to buy some type of tensioner like this Surly Singleator Chain Tensioner > Components > Drivetrain > Chain Guides & Tensioners | Jenson USA
These are just a few of the products you can purchase. There are cheaper versions of all these, you have to decide how much you want to spend. You can also improvise by using PVC pipe as spacers, old cog from cassette and using your old derailleur for the tensioner. Without knowing the exact bike in question, it is more difficult to give you exactly what you need but this will get you started.
Quoted: 239 Post(s)
Liked 7 Times
since all those SS people are about 'style'
of course, it being a converted mtb frame would stick out far more than the tensioner would
but hey, hipsters aren't too bright
Bikes: Fitz randonneuse, Trek Superfly/AL, Tsunami SS, Bacchetta, HPV Speed Machine, Rans Screamer
Quoted: 100 Post(s)
Nobody, and I mean nobody, is going to mistake me for a hipster, or being stylish!
Kit? Why? want IKEA to package it all for you?
DIY, old 5 speed frame, 1 speed freewheel .. I got an old 5 speed wheel , replaced the axle spacers,
to be the same width on both sides, adjusted the spoke tensions to recenter the rim
between the 2 axle ends And the centered in the frame ,
put a chain on and its good ... only need 1 chain ring, do need 2 brakes..
But, I like gears, 3 speed IGH are simple and reliable.. you can buy them built.
