Is VO2Max the best predictor of lifespan?
Perceptual Dullard
Peter Attia has been saying this, and now a new GCN video repeats it.
This is not a criticism of the main point, which is that cardiorespiratory fitness is a good thing to have. That seems unassailable. The question I'm raising is whether VO2Max measurements, especially using the current generation of wearables (like Whoop, or Apple watches, or Garmin watches, or the Oura ring), or VO2Max estimates from running or cycling or rowing tests are accurate, precise, or, in fact, necessary.
Much of the long-term evidence that cardiorespiratory fitness matters for longevity comes from the Copenhagen study, which has tracked adult men since 1970, so more than 50 years. In the Copenhagen study, the original cohort were middle-aged men who were given an ergometer test to estimate their VO2Max and asked some questions about their lifestyle and then-current disease status. Then these men were followed up for nearly 50 years, to look at mortality from any cause. It turns out that their VO2Max scores back at the time of enrollment did a good job of predicting lifespan.
But we know that other measures of cardiorespiratory fitness are highly correlated with VO2Max -- a rising tide lifts all boats. If you have a power meter (and I know most people don't) and you track FTP, or CP, or some other similar measure, my guess is that these are just as good and (if you already have a power meter and I know most people don't) more convenient and cheaper to do. In addition, there appears to be a lot of variance in VO2Max estimates made by Apple watches, Whoop bracelets, and power meters (they do seem to move together, but the actual raw numbers appear to vary a lot).
Bottom line, I think cardiorespiratory fitness is important--I'm just not sure that it's worth it to go out and do a specific test to estimate VO2Max, or to buy an Apple or Garmin watch to get their VO2Max estimates. Because of the variance in VO2Max estimates, I'd also be pretty wary of looking at those VO2Max tables and saying either "Oh No!" or "Woohoo!" because of your score.
Likes For RChung:
Likes For work4bike:
I guess I will be checking out soon....
just another gosling
Liked 1,998 Times
Best idea: don't ever look at that stuff. Bad for your heart.
That said, my numbers have always been crappy and my guess is that I will not be long-lived. But I've had and am having a helluva good time.
Results matter
Results matter
I just make sure that I include enough intensity in my training to maintain my VO2 max, regardless of how accurate the measurement is. The various devices I have that estimate VO2 max all appear to suggest I’m hovering around 50 and it hasn’t dropped over the last 5 years, which is quite encouraging. My FTP has also been pretty consistent over that period.
From what I recall of Peter Attia’s book, the link with longevity appears to revolve around the idea of maintaining our basic mobility in old age, which requires a minimum VO2 max. Once we drop below that minimum value (18 seems to ring a bell) our days are numbered. So having a much higher VO2 max in midlife gives us a larger buffer before we reach that critical level and therefore we should survive longer.
Bikes: Shmikes
Liked 5,968 Times
If VO2max is all that, why do women outlive men?
Seriously, though, it’s clearly a marker of something important and presumably correlates with a whole batch of other health parameters, but I’m not
sure that maximal oxygen uptake per se is keeping anyone alive unless they’re trying to cross a busy street. The point about estimation is also well taken.
Likes For MoAlpha:
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Liked 942 Times
I think the number simply paints an overall picture of health. And I imagine there is a point of diminished returns.
And the extremes on either side of the scale probably skew the numbers.
-Example - fire drill at work last week. As a floor fire captain(yes, I'm a dork) - I have to wait until the floor/stairwell is cleared. We had three employees at their limits walking DOWN the stairs. VO2 max levels were probably less than 10, maybe 5.
I do think cycling VO2 max estimates paint a decent picture but doesn't tell the entire story.
Assuming the same power output - an 80kg rider like myself with lean with upper body muscle will have a lower cycling VO2 max than a 60kg cyclist that's built like a T-Rex. Almost 15 points lower. They will climb faster - but are they really healthier/will they live longer in general? And is their true VO2 max actually 15 points higher?
Rowing/cross country skiing would probably lead to more accurate results.
Bikes: Shmikes
Liked 5,968 Times
Likes For MoAlpha:
Liked 942 Times
You need to be extremely skinny/lean - possibly lean past the point of being truly healthy. You need to do fairly extreme levels of intense exercise - 15-20-25+ hours per week, with large amounts of threshold, VO2 and beyond levels of intensity. Then you need to consume mass amounts of extra fuel, which can be taxing to every system in the body.
Similar to how one can have too much muscle mass and all that's required to gain/maintain that mass.
Likes For Jughed:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Liked 3,071 Times
Originally Posted by Jughed;23234680[b
]I was thinking of the extreme levels a pro athlete/cyclist has to go through in order to get a VO2 80++[/b].
Version 7.0
I like GCN and Dan in particular. It is unfortunate that they are dissolving. VO2max, as measured in the lab, may be an important metric for getting a pro contract in an endurance sport or getting on a development team. For juniors interested in getting on Team USA sprint development team, USAC requires a 5 second max power effort on the Wattbike. If one doe not generate enough watts...no good. But I digress.
My new Garmin Connect Home Screen proudly displays my VO2max. Garmin must think that 1) they have a solid way of determining VO2, 2) think I am impressed with the number or 3) put up a number so their device is competitive with other independent of the accuracy. I give the Garmin VO2 a meh.
My own theory of aging is that strength is determinate. Strength is an enabler that allows one to pursue activities such as cycling, hiking, skiing, stair climbing, running and etc. With strength, one can develop one's mitochondria through training and increase the ability to generate more ATP and increase/maintain VO2.
The more that strong muscles are utilized, such as in cross country skiing, the more opportunity to increase oxygen utilization and increase VO2.
I have been consistently strength training since 1974 and I went through a phase where I concentrated on getting to muscle failure in the gym. Then I fell into a maintenance mode that lasted years. I am back into the get to failure mode with the most effort in a short period of time trying to maximize eccentric contraction along with concentric. I have been using fancy weight machines with computer screens that show a band of green and I have to keep the line in the band over the duration of the effort. These gyms are popping up where I live.
The machine can deliver increased eccentric load such that the "negative" feels really heavy compared to the concentric motion but yet I can stay in the green and get to failure. The theory is that the higher levels of force increase / maintain bone density as well as strength. I am doing one session per week with the fancy machines to failure and using conventional strength training to get in another full body session to failure.
IMO, with a strong muscular and bone base, one can overlay any aerobic modality that suits one fancy including cycling and have a reasonable shot at higher quality of life.
Having said that, only aerobic zone 2 with no intensity will make Jack a dull boy. IMO, at least one intensity session per week that goes to failure running, cycling, swimming, skiing and etc is required. That conclusion goes back to the video that increased VO2 is important. Zone 2 creates the opportunity to increase VO2 and intensity seals the deal.
Likes For Hermes:
Bikes: Shmikes
Liked 5,968 Times
I was thinking of the extreme levels a pro athlete/cyclist has to go through in order to get a VO2 80++. Or to maintain a super high level throughout life.
Perceptual Dullard
Likes For Polaris OBark:
Bikes: Shmikes
Liked 5,968 Times
climber has-been
Liked 3,803 Times
I am not built like a T-Rex. I'm built like a spider monkey.
Minus the tail.
Likes For terrymorse:
Likes For Kai Winters:
Liked 942 Times
The weight lifting aspect is interesting. If I started lifting again, and lifting to failure - I would quickly build up to 200#+. When I rode back in my 20's, heavy road riding, mountain biking, BMX, and lifted at the same time I weighed in at 220#++, and I wasn't fat.
My weight would go up faster than my VO2 max. And it would go up faster than my w/KG at FTP.
OM boy
As the 'Best ' predictor of lifespan? for whom? at which point in their lifespan? ongoing?
VO2 Max prolly is a great indicator of overall 'condition' of the organism, very tied to fitness. Then there's genetics... which can be :Go To Jail' Card or 'Pass Go & collect $200'...
When I have comprehensive physical - the results I see make no mention of VO2 max...
I know all the hot new metric devices can give you 'VO2 max' and a bunch of other guesses, like calories expended, etc... Personally, I don;t put much into the value of those numbers...
So, it really has no value for the average person, since it's so difficult to get any population studies (The Copenhagen and Finnish studies as only a few).
And then there's the gender divide... how much does 'gender' play in the population validity?
I do think it can be a 'Feel Good' number, and thereby also a 'Feel Bad' number...
Been quite some years since I had the snorkel on... And how that goes can also be greatly affected by personal, psychological, and short term physical things; to cause significant variation.
Trying to make 'connections', I did a quick 'google' of - does muscle mass have an impact on VO2 max - try it...
very interesting variety of reading...
in that I found " VO2 Max is a vital sign - How to Measure It" interesting...
which covered some methods used for measuring VO2 Max. Of course the snorkel is the gold std...
I do remember my numbers from the early 80's, and a comparison seems 'ludicrous', but maybe fun.
So I did the Norwegian calculation - surprised, a Feel Good number. But really close to reality? I very highly doubt it... But still was Fun.
We all have so many numbers going thru our heads, available from so many sources , HR, PWR, STRESS, - if we pick any combination to use, it's still guessing, until we see some direct impact on our wanted 'results'...
Even thought the Norwegian estimate number feels good, it will have no impact on how I manage the remainder of my days.
Without some direct 'Tie' into what we want, VO2 Max is just another number.
Don't get me wrong - we should still move forward strongly on science and learning/discovering more. It's all 'minor' or maybe greater 'Gains', which have helped us make better decisions on living our lives.
Ride On
Yuri
Ride On
Yuri
Ride On
Yuri
Ride On
Yuri
Perceptual Dullard
Increasing disparity in trend of expectation of life at birth between US and other high-income countries
In 1980, the US's expectation of life at birth both for men and for women, was smack dab in the middle of the other high-income countries. Today, among high-income countries, it's last.
Liked 1,998 Times
GCN dissolving? I know they are a bit campy - but I do enjoy watching their stuff.
Results matter
Results matter
Liked 1,998 Times
For sure, top pros do seem to be long-lived. The object of the game in the US is to have enough money not to be a part of the declining red line. It's not magic, it's diet, medical care, and housing. The US is structurally failing its population in all three aspects.
Results matter
Results matter
Likes For Carbonfiberboy:
Perceptual Dullard
Likes For RChung:
