Are these all the types of shifters?
Quoted: 9 Post(s)
Liked 22 Times
Basically my question is, will 99%+ of bikes that people are riding fall into these 7 categories:
No Shifting (single speed)
Thumb (10-24 speed)
Grip Twist (5-24 speed)
Stem (5-12 speed)
Downtube (10-14 speed)
Integrated / Brifters (16-33 speed)
Bar-End (3-24 speed)
Other (3 speed)
Assuming thumb includes both thumb/index and just thumb
Thumb (10-24 speed)
Stem (5-12 speed)
Other (3 speed)
Quoted: 2026 Post(s)
Liked 1,096 Times
Downtube can be 10-30 speeds at least and maybe 33 if Shimano or Campy make 11-speed rear shifters in that format.
Barends are 3-30 at least as above.
A couple of less common types are Kelly Take-Offs (10-30 speeds) that mount downtube levers beside dropbar brake levers and Retroshifts (10-30) that mount downtube or barend levers directly on the shiftlever themselves.
you don't have to have a front derailleur to use more than 1 chainring,
its just more convenient..
and in addition to 'greasy finger shifting', with a chain tensioner /RD
and the 'quick beam' kit, flip flop hub with 1 or 2 cogs on each end,
and 2 chainrings,
Flip, taking off the wheel , & pull it back to tension the chain.
there is the front planetary internal gear system, 2 types,
button in the crank-arm center .. those shuttle thru the BB axle
(one side or the other, sticks up) , and handlebar cable shifted.
and the cable less kick back 2 speed..
and 2 chainrings,
incazzare.
Paris-Roubiax
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Location: England, currently dividing my time between university in Guildford and home just outside Reading
Bikes: Too many to list here!
A few points, firstly that there might have been 7-speed rear brifters made when they first started out, so it may be 14-33 speeds for those assuming you don't run a single chainring with them. I've also seen downtube shifters with no front derailleur, and you may even see the occasional 4-speed rear derailleur still on the road. Sturmey-Archer also make a downtube shifter for their 3-speed hubs.
There were also some front derailleurs shifted directly using a lever attached to the derailleur mechanism itself.
The car-style frame-mounted shift lever for the 3-speed hub on the Raleigh Chopper and the quadrant shifter that still turns up on very old 3-speeds around here also come to mind, although you may already have them covered under "other". The official designation for the standard shifter for the SA hub is a "shift trigger", by the way, if you do want to add that as its own category.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
There are 7-speed brifters. I have one. You left out kick-back shifting with 2-speed rear hubs. Just pedal backwards to shift between high and low gear.
Quoted: 3376 Post(s)
Liked 5,518 Times
2-speed bottom-bracket: https://www.schlumpf.ch/hp/schlumpf/news_engl.htm
Liked 1,096 Times
Quoted: 1529 Post(s)
Liked 718 Times
You could also be running a Campy 8spd system on a Shimano 7spd cassette or freewheel, since it's the same 5mm spacing. I had two such bikes.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
Dave Moulton's blog has a great writeup.
The derailleur was operated by two levers on the right side of the bike’s rear seatstays, just below the rear brake. The top lever released the rear wheel, a lever below it operated a simple guide that moved the chain from one sprocket to the next.
Because this chain shifter was on the top portion of the chain, above the chainstay, it was necessary to back pedal to actually shift. The pull of the chain as it climbed over the teeth of the sprockets, moved the wheel forward. Once the shift was made, the rider’s weight automatically moved the wheel back and re-tensioned the chain.
Liked 718 Times
The Cambio Corsa was a mind-bending bit of engineering IMO. Quite a leap just to come up with the idea.
I would love to come across an old machine so equipped...
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,695 Times
I have 7-speed brifters. 1999 Shimano RSX.
Grip shifts have been on 3-speed bikes and went up to 27 speeds. You could probably make a 30-speed Gripshift bike by mixing groups but the Sram 10-speed group comes stock with a double up front.
Thumbshifters should be above-bar shifters only.
Trigger shifters would be the thumb + index finger.
Rapid fire (without the +) used to be called below-bar thumbshifters or push button thumbshifters back in the day.
Add Wishbone shifters:
Suntour wishbone shifters 1990 by felixdelrio, on Flickr
Add Rocker shifters (that's what I call 'em, anyways.)
Passista
Quoted: 868 Post(s)
Liked 721 Times
Also top tube shifters, as the Sturmey Archer quadrant and some old French bikes:
https://www.flickr.com/photos/25671211@N02/2444026031/
https://www.flickr.com/photos/8379107@N03/5379126317/
Seat tube also, but unusual:
https://www.flickr.com/photos/cycleczar/4151041881/
90/91 Mavic's Mountain, (VTT in French), had a double lever , under bar, thumb shifter, too..
part # 825.
part # 825.
Bikes: everywhere
Liked 7,695 Times
Ahh, yes, I remember those. Velobase has a pic of one, claimed to be Mavic 850:
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
Thumb (10-24 speed)
Stem (5-12 speed)
Other (3 speed)
Thumb (10-24 speed)
Stem (5-12 speed)
Other (3 speed)
(From https://classiccycleus.com/home/?p=4258)
Jeff Wills
Jeff Wills
Bikes: everywhere
Liked 7,695 Times
I reckon electronic shifting needs to be added as well.
Old School Mavic stuff, as well as the new stuff from Shimano and Campagnolo.
Liked 1,096 Times
The Schwinn enthusiasts would want to include the top-tube mounted "Stik-Shift", available in 3- and 5-speed versions:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
They're Shimano A050 shifters. My buddy has a pair on his touring bike.
Bikes: everywhere
Liked 7,695 Times
You need to shop more super lowend roadies
They're Shimano A-050.
https://www.amazon.com/Shimano-Handle.../dp/B001L5Y1GC
