Addiction 2021.1
#6601
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,900 Times
Bad batch of steel? Or cheap-as 26 year old hub that's never been serviced?
#6602
Liked 11,900 Times
I've always wanted to get one of the older Cannondale frames and put modern components & carbon fork on it. Especially something like a Black Lightning or any of the models with cantilevered dropouts.
Ever since my mountain bike cracked though, I've become very leery of used aluminum bikes.
This morning I immunized myself against buying it by letting Mrs. GeneJockey know that I was restoring my old R500 as my winter project, and mentioning that R600 while saying I need another bike like I need a hole in the head. Since she DIDN'T say, "Go ahead! You deserve it!", it has now been moved firmly into the "Don't do that!" category. By contrast, last year when I mentioned that the rear rim on the Bianchi was full of cracks and I wanted to buy a new wheelset, she essentially said, "Well, duh. Of course!"
#6603
Liked 11,900 Times
SO, the restored R500 will NOT be used as a mountain goat. Strictly flat and rolling, with only short climbs and short smooth descents. Especially since the largest cassette I can put on it is a 12-25. I can't do 3 miles of 8% on 39 x 25 these days.
#6604
Bikes: Shmikes
Quoted: 10171 Post(s)
Liked 5,867 Times
#6605
Liked 11,900 Times
And only on half of it. Who knows? One thing I noticed was that the non-drive side cone and lock nut might have been a little loose. Don't know if that would do it. As it is, once I eliminated any play in the rim when clamped in the forks, there's still a slight crunchiness, which I hope the new cone will cure.
The Dura Ace hubs on the Ritchey are as old, and have gone thousands of miles more without service, but they're still great. I'm afraid to mess with them, but also afraid not to.
#6606
VFL For Life
Bikes: Velo Volmobile
Quoted: 28616 Post(s)
Liked 1,857 Times
#6607
Bikes: Shmikes
Liked 5,867 Times
#6608
Bikes: Shmikes
Liked 5,867 Times
#6609
Quoted: 20810 Post(s)
Liked 9,456 Times
Pipes almost never pop at the freezing location - expanding ice is an indirect cause of burst pipes, not a direct cause. Rather than the ice swelling and bursting the pipe, it's the ice expanding and pressurizing the water trapped in the line (between the freezing point and a shut-off). Since water doesn't have much squish, it only take a little expansion within a sealed volume to make the line pressure skyrocket to several times the rated pressure of the lines. This is why it's advised to let a faucet drip when there's a danger of freezing pipes - you're not looking to prevent the freezing, you're looking to provide a pressure relief.
None of these things would be a problem in a sewer.
#6610
Quoted: 3361 Post(s)
Liked 3,638 Times
This is the source of my current frustration. I want a comfortable, reasonably quick, and reasonably light bike for the upcoming season but I have neither room nor money for another bike. So I am trying to think of the best way to play musical components with the stuff I have. There's no really good options IMO.
The most handwringing I'm doing is due to the replacement fork on the 716. Its' large offset allows for good handling with a handlebar bag but it is shorter than the stock fork and the top tube is ever so slightly sloping downwards. It's been like that all last year and I've never gotten over it.
I could swap back to the stock fork, but the frame has cantilever bosses brazed on for 650b wheels and the stock fork has no bosses and isn't powdercoated to match the frame.
So I either have the stock fork modified with 650b cantilever posts and powdercoated to match, or I slice the canti posts off of the frame and re-powder both frame and fork but have to go back to sidepull brakes. But then I have the option to run the original spec 700c wheels and I seem to remember liking how it rode with the wheels it was designed to run from the factory...imagine that...
But then that leaves the question of what to do with the chrome SLT....
#6612
Liked 9,456 Times
So I either have the stock fork modified with 650b cantilever posts and powdercoated to match, or I slice the canti posts off of the frame and re-powder both frame and fork but have to go back to sidepull brakes. But then I have the option to run either 700c or 650b wheels...
Likes For WhyFi:
#6613
Liked 11,900 Times
Here in Earthquake Country, that's also dry 8 months or more of the year, you think about what to do if the city water fails and you still need to deal with bodily functions. Hence, Mrs. GeneJockey buying a 5 gal bucket with a toilet seat lid. You line it with a garbage bag. But you can do the same with a toilet. Saves water, because a 1 gallon flush would need 8 lbs of melted snow.
#6614
Liked 3,638 Times
Likes For abshipp:
#6615
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
#6616
Liked 11,900 Times
My understanding is that you actually DO have to do that if you go tubeless.
#6617
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Well...the CAAD5 in that picture was extremely stiff with a jarring, jolting ride on rough roads. Great handling bike, other than that. To go the other way I bought the Gunnar and whenever I pulled the CAAD5 out for a ride I wondered how I tolerated it for the 5 years it was my main bike. I sold it cheap to a friend's brother.
After the Gunnar was my main bike for a while I bought the Seven used. It reminds me of the CAAD5. Quick handling, responsive climber, and brutal on the rough stuff.
The Cannondale touring bike was a nice smooth ride. It had a steel fork and long wheelbase with slack angles.
#6618
Bikes: Shmikes
Liked 5,867 Times
#6619
VFL For Life
Liked 1,857 Times
#6620
Liked 9,456 Times
Work on the Murphy bed began in earnest over the long weekend. Damn, I just want this thing to be done. Getting close - waiting on the final coat of paint to dry on the cabinet carcass. It's already mounted to the wall seven ways to Sunday, and it's drilled for all of the mounting hardware and assist pistons to secure and articulate the metal frame (which I've already assembled). I should have it functional either tonight or tomorrow and then I can get things squared away and return to a bit of normalcy. I'll probably start on the decorative door panels next week or so, but that won't involve turning the house upside down.
Likes For WhyFi:
#6621
Liked 3,638 Times
Anyone else watching today?
Likes For abshipp:
#6622
VFL For Life
Liked 1,857 Times
#6623
smelling the roses
Liked 901 Times
#6624
Liked 3,638 Times
#6625
Liked 9,456 Times
I was thinking more of whatever you flush not making it very far down the pipe before it freezes. Then the next flush freezing on top of it, and so on, eventually blocking the pipe. But of course, I may be full of **** here. Plumbing and electricity I leave to others.
