Using different gears for wear prevention?
Quoted: 18 Post(s)
Do any of you make a point to use differing gears so as not to wear out certain cogs prematurely?
I'm almost always in the 15 or 17 tooth cogs and middle chainring. I was just reading how the smaller cogs can wear out a chain quicker than larger ones. I'm gonna switch it up to 23 and 26 & the large chainring for a while. I do have concerns about crosschaining and extra noise but so be it.
The thread titled "Anyone Tracking Gear Usage" got me thinking about this.
I'd rather wear out the cassette than start cross chaining and wearing out everything else.
I consider the cassette a wear and tear disposable item.
I shift for good cadence to not wear out my knees. I worry less about wearing cogs since they are easier to replace than knees.
Do you always go with same speed on flats? I naturally shift through most cogs by starting at 0 and riding at varying speeds at varying grades and wind.
Likes For HerrKaLeun:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
The machine is supposed to prevent me from wearing out, the reverse definitely takes a back seat. I use the gears I need, and really don't care if it takes a few miles off a replaceable part.
Likes For livedarklions:
Firm but gentle
Slightly Off Topic
I also worry about cog wear and drivetrain wear in general. This mindset has me usually installing a new chain about every 2500 to 3000 miles. I know there is about a rivet diameter of stretch at this point. The bike just seems to shift better and everything feels smoother with that brand new chain, could be mental. Part of me wants to be able to say “screw it, it’s just a bicycle, ride it till it skips”, but that will never happen.
I guess it better than not using brakes because not wanting to buy new pads/rotors
Likes For mattleegee:
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
Why not just replace the 15 or 17 cogs when they wear out?
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Quoted: 1743 Post(s)
Liked 1,281 Times
Use the gears you need to use. Replace as needed.
Likes For bruce19:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12781 Post(s)
Liked 7,696 Times
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
The fastest wear item in the drive train is the chain. But if you ride with a worn chain, you will also wear out your cassette.
No need to worry about overusing one cog, as long as you replace the chain before it’s worn. Check the chain for wear monthly.
Park Tool makes a chain wear checker that’s not expensive:
Chain Checker
Chain Checker
Likes For terrymorse:
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,872 Times
Definitely. I run my car in 4th on the highway half the time to spare the overdrive, too.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Hmmm, cross-chaining to prevent drivetrain wear.... interesting.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
OK I'll admit it, I have selected gears for no other reason than to distribute wear. I don't shift as much as most, and sometimes I don't "shift" mentally from my fixed gear to road bike and might finish a ride without shifting at all. It's just a shame when the 16+/- are worn out and the rest of the cassette is pristine.
Likes For wphamilton:
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
Cogs primarily wear out when they are used with a worn chain. Chains wear out from being ridden with inadequate lubrication and, eventually, over time. If you replace your chain before it get to the point where it is wearing the cogs, your cogs will not wear out.
Quoted: 2952 Post(s)
Liked 3,106 Times
Yeah, this is annoying. Particularly when you primarily ride on the flat lands and you're mostly in 3 or 4 cogs max.
Likes For TimothyH:
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Cassette and front ring wear can be minimized by using several chains throughout the life of one cassette.
I use three chains per cassette, cleaning and swapping about every 1000 miles for road, more frequent for gravel.
-Tim-
-Tim-
Tragically Ignorant
Liked 9,098 Times
If you really want to avoid wear, don't ride the bike.
Solutions can be worse than the problems they are intended to address. If your legs are ok with shifting for this purpose, no harm in doing it. If I were to shift for that purpose only, I would find it incredibly annoying because of my strong preference for high gears.
The better question might be if there's any way to buy bikes these days other than SS that don't have a bunch of gears we don't need?
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I make a point of staying out of the small cogs unless I'm in the big chainring (I have triple cranks). In the past I have worn out the small cogs prematurely, so I try to avoid that.
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
I just use 30 dollar caasttea and a 30 dollar.chain and switch them out for the better ones on race day .
