Addiction LXXVIII
#251
So it is
Quoted: 11402 Post(s)
Liked 4,760 Times
Gotcha. I guess just try flushing it a few more times and cycle it a lot. I think that a select few people have successfully overhauled Shimano STI stuff, but they are few and far between,. They really don't like going back together after being taken apart, unlike Campagnolo Ergopower levers.
eBay has quite a few in the $70-$100 range. Seems like the path of least resistance if flushing doesn't work. You should be able to swap one out without even needing to remove bar tape.
However:
As a regular Addiction poster, I am required by Addiction bylaws to recommend you look into the Cervelo closeouts on excelsports.com and pick out the R series of your choice.
However:
Some things just don't need to be said, they're just a given. Having a firm grasp of the obvious doesn't really set you apart.
#252
Administrator
Quoted: 11971 Post(s)
Liked 6,654 Times
WhyFi, I’m not wasting my time arguing over the Internet. Never have, never will. You can see what you want to see, believe what you want to believe and say what you want to say, and I’ll do the same. Adios.
#253
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
Likes For datlas:
#254
Quoted: 20810 Post(s)
Liked 9,456 Times
You've never had qualms about arguing - you were just arguing with LAJ. You just don't like it when people argue back and you're on shaky ground. Adios, indeed.
#255
Mostly Harmless
Bikes: Have two wheels
Quoted: 13714 Post(s)
Liked 4,531 Times
#256
Mostly Harmless
Liked 4,531 Times
Huh. Maybe just needs to be cleaned out. The mechanism in the shifter isn't working when it's cold, it's not just that the cable is maybe binding somewhere?
And to be clear, when you say shifting to smaller gears, you're talking about the shifter releasing cable instead of pulling, right?
Likes For rjones28:
#257
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
#258
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
#259
Mostly Harmless
Liked 4,531 Times
When was the last time you put new cable and housing on the bike?
Likes For rjones28:
#260
Mostly Harmless
Liked 4,531 Times
* see bar tape episode
#261
Liked 9,456 Times
#262
Bikes: Shmikes
Quoted: 10175 Post(s)
Liked 5,871 Times
#263
Mostly Harmless
Liked 4,531 Times
#264
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
I wonder if the multi-quote issue is browser-related; will investigate later.
#itjustworks #exceptwhenitdoesnt
Likes For Bah Humbug:
#265
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,695 Times
WOOHOOO, it's FRIDAY!
#266
So it is
Liked 4,760 Times
#267
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
I venture out to pick up a few items because I don’t want to shop over the weekend. My Costco has been playing fast and loose with their hours; one never knows for sure when they are opening or closing and their local website is totally wrong. Said they were closing at 8:30 and they actually closed at 6:30 last night. Supposed to open at 9:00 and actual time this morning is 10:00. When I got there at 9:15, there were many people sitting in cars as confused as myself.
Tooled over to Aldis and probably 40% were wearing masks. I just picked up a couple things and bolted for home.
Will try again on Monday.
Keep the chain tight!
#268
Mostly Harmless
Liked 4,531 Times
#269
Liked 9,456 Times
#270
Bikes: Shmikes
Liked 5,871 Times
#271
Bikes: Shmikes
Liked 5,871 Times
#272
Super Modest
Liked 4,620 Times
Frankly, weekends don't seem to matter these days - it's all the same. I went to Costco last Saturday at lunch time, something that I would normally avoid, 'cause it's usually a zoo, and it wasn't busy at all. And while I can't help you with the store hours being wonky, I stand by my earlier recommendation - check google maps for live busyness levels before leaving the house.
#273
Bikes: Shmikes
Liked 5,871 Times
What doesn't work for me is the snap-back button for quoted posts. PITA.
#274
Quoted: 8281 Post(s)
Liked 9,053 Times
My 6600 bike has done that on both shifters. I don't ride it very often and I have tried WD-40 but it gets gummy in there after the bike sits in cooler weather. The last time I used silicone spray lube and the shifters worked great after that. Turn the bike upside down and spray into the shifter at the base of the lever.
#275
Super Modest
Liked 4,620 Times
