Is my sleeping bag not good enough?
Bikes: Norco Threshold, Masi Giramondo
Quoted: 86 Post(s)
I have a Teton Trailhead +20f/-7c. Took it out for the first time last night camping. I was woken up at 4am because I was too cold. I was wearing a longsleeve wool shirt and underarmour long johns. I had to put on another pair of pants and use my sleeping liner. When I got home I checked the weather and it was only about 7 Celsius, which makes me worry.
My sleeping bag says its lightweight. Its about 2 pounds or so which is nice, but I'm worried for my upcoming tour that it wont be very effective.
It also takes up a lot of space in my pannier even though I use a compression bag.
Does anyone have any experience with this bag? or any reccomendations for a replacement??
Thanks!
Thanks!
Quoted: 5793 Post(s)
Liked 2,594 Times
Sleeping bag temp range info is only a guideline.
It's one of those cases "your mileage may vary".
Things like dampness, what kind of ground pad you used, your own size and weight, and the size of your tent will all affect how warm you are in a sleeping bag.
IME - the same bag has felt warm on some cold nights, and not so warm on warmer nights. It's the same as with clothing, the outside temp may be the same, and you may dress the same, but you won't always feel the same.
FB
Chain-L site
FB
Chain-L site
Quoted: 86 Post(s)
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
There are no official objective methods of rating sleeping bags in America. EU is working on a system which is getting out there, but not common yet.
Most traditional ratings are what an adult man sleeping in long underwear on top of a proper pad should feel comfortable to. Therefore, it can vary quite a bit from person to person. I generally pick one that is 15-20F lower than the lowest temp I will generally expect to be out in. I use a 25F bag for Michigan summers, where nights can easily drop down to the high 40s. If it is warmer, I just leave it unzipped.
Liked 2,594 Times
My point wasn't about the specific details as much as about the variables.
For example, if you under eat you don't produce as much body heat and can start to chill in the early AM as the fuel runs dry.
OTOH - if you're too well insulated early on when outside temps are higher, you might start sweating in your bag, which dampens it and lowers insulation. Then you have a compromised bag when the temps drop and get chilled.
So, one test may not be enough, you may want to try it under various conditions and dial in how to layer, and how it will perform under various conditions. Then you may decide it's OK for your needs, or that you need more.
But neither I, not anyone else can answer that for you.
FB
Chain-L site
FB
Chain-L site
Quoted: 86 Post(s)
the question should be, i would think is, "how am i going to determine whether ANY new bag i get will be warmer than the one i have, which is not warm enough?".
and in general, "the higher the loft the warmer" is about the best i can do. so i would take my old bag to whatever store i thought had the best deals on down bags, and lay the old bad next to the new bag, and then ask 10-12 customers, at random , which one looked like it had the most loft.
or something similar...
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
All I can say is what can you expect for $70 (prices I saw on eBay for that bag)?
Check out the EN 13537 rating system. Decent bags will have that, and will also have a substantially higher price tag.
A quilt might give a better weight to warmth ratio, and could save some money, but you won't have features like a zip and a hood. There's always a trade-off. Just as in the down vs synthetic question. (One of those is always better, until it isn't.)
If you don't spend money on a good bag now, you will probably spend much more on a succession of cheaper bags. When I finally, after decades of inferior stuff, bought a decent bag, I wanted to kick myself for waiting so long. When I think of all those cold nights, maybe a dollar a night would have meant such a difference.
Bikes: 1973 Raleigh Competition, 2010 Rivendell A. Homer Hilsen, 2010's Bike Friday Pocket Companion
Quoted: 19 Post(s)
Another issue is what you ate for dinner. If heavy on carbs, fruits and veggies you will burn through those energy sources quickly and wake up cold in the early a.m. Add some days and protein. These take longer to convert to energy and you stay warmer longer. In Boy Scouts training for cold weather camping (anything less than 50F) the following analogy is used: carbs, fruits, and veggies are like kindling --burns hot and fast, but out quickly. Protein and fats are the big logs -- not quite so hot but will go all night.
Cheers!
Cheers!
I've also found dampness to be a big factor in sleeping (dis) comfort. A camping spot down in a hollow, near a river with tons of dew, a bit of a breeze, perhaps your fly a bit loose, letting in cold, damp air in the night, your tent mesh design--can all make a diff ending up in a cold 4am period.
what sort of temps are you expecting for your trip, and where and when is it?
Many good points already listed above. Another possibility that I didn't see mentioned has to do with the type and quality of the insulation in the bag. I also see you use a compression sack. Insulation materials respond differently to compression and some take a long time to retain their full loft and provide their full insulating power. As a general rule, I understand it is a bad practice to leave your sleeping bag compressed when storing between trips.
Real Men Ride Ordinaries
Quoted: 17 Post(s)
An uninsulated pad will let the ground suck the warmth out of you. It's not pleasant. You might want a little more insulation to keep you warm. You can buy another pad, or you can use a supplemental closed cell foam pad. When it comes to real cold weather camping, I'll use an insulated air mattress and a Thermarest SOLite underneath. It's enough to keep me warm down to about 0, with an appropriate sleeping bag.
Quoted: 86 Post(s)
Liked 81 Times
Look up what the weather is now in those places and use that as a guide. The temps wont be changing significantly in the next two weeks, and if it does, it will more than likely be for the warmer.
Quoted: 86 Post(s)
THats not good; I've kept it in a compression bag for about 4 months since I bought it. Maybe this ruined the bag and I should cut my losses and ask for a swap from teton.
Quoted: 4806 Post(s)
Liked 3,933 Times
I saw this thread but don't have time to read the posts. I toured Wisconsin with one of the very first Quallofil bags, 1975. I was 6'1/2' tall and bought the considerably lighter regular bag for up to 6'. Way cold the first night. (Below freezing, October in Wisconsin.) Wore all my clothes the next and started paying real attention to fluffing the bag every time I moved. It worked and I slept well.
My touring philosophy for clothes is simple. If on the coldest, most miserable time of my tour I was not wearing everything I brought, I brought too much. Granted I am older now and like a higher level of pamper but my legs complain more than they used to if I go to far in that direction.
Ben
Ben
Quoted: 86 Post(s)
=GAJett;19634855 the following analogy is used: carbs, fruits, and veggies are like kindling --burns hot and fast, but out quickly. Protein and fats are the big logs -- not quite so hot but will go all night.
Cheers!
Cheers!
Liked 81 Times
If it is compressed, toss it in a large dryer with no heat. Some people toss in tennis balls, too. Should fluff it back out to some degree.
As a rule, sleeping bags, self inflate thermorest type campmats etc, all should not be stored squished all up.
Bikes: Custom built LHT & Troll
Quoted: 846 Post(s)
Liked 149 Times
1. You can get warmer with a liner, also useful to keep your sleeping bag clean. Supposedly adds 5F.
2. You can wrap yourself in a reusable thermal blanket. Probably another 5F.
3. Wear a woolen cap.
Have a great trip.
