Show us your cleaned drive train
Quoted: 800 Post(s)
Liked 512 Times
After reading all of the posts on here recommending how to clean a chain, cassette, etc., and realizing my drive train desperately needed some cleaning, I did a bit of cleaning last night.
I also thought I'd start a thread so others can show the efforts of their work too. Cheers.
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times
Just the chain, but I was blown away at how well the Park chain cleaner works. I always thought these were for lazy people who didn't want to take their chains off to clean them properly, but the first time I used it, I was shocked. The chain was a complete and total mess of grease and gunk, and in just a few minutes running it through the cleaner, this is what came out.
Likes For cthenn:
Quoted: 800 Post(s)
Liked 512 Times
@cthenn you might have convinced me to purchase the Park chain cleaner...
Bikes: Shmikes
Quoted: 10171 Post(s)
Liked 5,864 Times
Actually, that's a pret-ty nice result...
That park chain cleaner works really really well IMO. I bought one last year after reading some reviews and was also pleased with the results. I don't know how some of you guys keep your drivetrains so clean unless you wash extensively after every ride. I wash and lube every 200-300 miles which works out to being about every 2 or 3 weeks.
Quoted: 479 Post(s)
Liked 277 Times
Damn @cthenn... that looks like you cleaned, flossed and polished that chain. Ordering a Park chain cleaner in 3... 2...
Cleaned the old fashion way:
I like Simple Green's bike degreaser - it's foamy so it doesn't run as quickly... probably better for bearings, etc... probably
Quoted: 942 Post(s)
Liked 527 Times
No Park Chain Cleaner or special solvents. Entire bike is wiped down after every ride. I use a Connex chain so I can remove by hand, clean, relube and reinstall. Chain is pulled though my hand using a rag/t-shirt to get big gunk off, then run through my hand in a clean t-shirt and some rubbing alcohol. No need to deliberately degrease chain unless I do something like 100 miles in wet/crappy conditions. The rest of the drive train is wiped down using a clean t-shirt and rubbing alcohol (floss cassette, rings, pully wheels). Discs are wiped down with alcohol. Process takes 30 minutes. Bike stays looking like this I put on average 500 miles a month on it.
Likes For jadocs:
Likes For fasthair:
Likes For Johnny Rad:
It's the inside of the chain that needs cleaning the most. Wiping off the outside does little. A park chain cleaner leaves the chain swimming in dirty solvent, unless the whole process is done at least twice.
If you want a really clean chain, drop it in a bottle of mineral spirits and shake vigorously. Repeat with clean solvent.
Quoted: 647 Post(s)
Liked 136 Times
I dunno, never heard that before, but it seems to not do that... I use a two step process, first wiping the chain down with a degreaser soaked rag, to get off most of the external gunk, then run the chain cleaner with undiluted Simple Green (a gallon just is less than $10 at HD). Chain comes out sparkling clean every time, and it doesn't feel like there's gunk or grit lodged inside. Also, it seems important to use the Park brand version of this. I haven't personally used the generic versions, but from things I've read, this is one time where the brand name item is superior. I will note, that I've used it probably 10 times or less, and some of the brushes are already fraying slightly. I think they sell replacement parts, but it seems to be starting to show wear already...
Quoted: 389 Post(s)
Liked 255 Times
That's my opinion. I could be totally off, but it seems that normal use would drive dirt out of the inner parts, and cleaning would do the opposite. I know it's anecdotal, but I had a mountain bike with many races, and well over 5000 miles of commuting after I retired it, and the stock chain, never cleaned, only lubed. I have never cleaned a chain in over 50 years. …..But..... I am going to get that Park cleaner
Quoted: 1975 Post(s)
Liked 232 Times
Quoted: 42 Post(s)
Wipe down chain - Park chain cleaner with solvent - Park Chain cleaner with water - Dry - Lube and let sit overnight before wiping off.
In between degreasing I like a lube that you can add and wipe that cleans at the same time like rock and roll gold, but right now I am using Morgan Blue race oil and liking it.
Quoted: 18883 Post(s)
Liked 10,646 Times
Quoted: 4560 Post(s)
Liked 2,802 Times
Too late. My bike had its annual cleaning last month, and I've ridden since then.
Wow. I’m going to sub to this thread and then go hide in a corner. I’m not worthy...
Quoted: 942 Post(s)
Liked 527 Times
Likes For wedgeSG:
Quoted: 5224 Post(s)
Liked 3,581 Times
Cleaning a chain once every 1500 miles is pretty much worthless too.
