What's Your Favorite Bike Oil?
Hey guys sorry if this has been posted a million times before but keyword search for some reason showed me nothing under " oil " . I've been using the Bose Shield T9 bicycle oil for a while but looking for something better that has a little bit better lasting power. What do you recommend? Thank you
Pennylane Splitter
Bikes: Yes
Quoted: 1807 Post(s)
Liked 1,447 Times
90W gear oil. Bought a little too much last time I filled the manual transmission on an old VW bug I used to own, so tried using a bit of the leftovers on a bicycle chain and it seems to do the job quite nicely. You can buy a bottle at any auto parts store. Extra: I clean and re-lube my bicycles' chains about once a month.
Likes For skidder:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Quoted: 506 Post(s)
Liked 639 Times
Likes For KerryIrons:
Quoted: 6199 Post(s)
Liked 4,816 Times
Not lasting long might be good. Then you are lubing your chain more often and flushing the grit out of the places where grit shouldn't be. The so called dry lubes are nice. I don't seem to have as much gunk building up on my chain and my inner calf and socks stay clean. If it last a long time, then you are just giving more time for your chain to get gunky.
Likes For Iride01:
Quoted: 4227 Post(s)
Liked 2,488 Times
I don't have a favorite bike lube, because I found out over the years that pretty much any type of oil will work for lubing a chain and other bike components. So I just use whatever.
Super Moderator
Quoted: 1173 Post(s)
Liked 929 Times
Same here. Even the much maligned WD-40 will work. Spray some WD-40 into a little dish, let it sit for a few days, after the light stuff evaporates, there's still oil remaining.
Quoted: 3241 Post(s)
Liked 2,512 Times
Replace the word "oil" in your search with "lube." That will get you the info you need.
Likes For seypat:
Likes For Kedosto:
Quoted: 1944 Post(s)
Liked 2,164 Times
I use coconut oil.
It has a third less viscosity, and it smells great too!
John
John
Likes For sdmc530:
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
Snake
Likes For Polaris OBark:
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Bicycles are not a particularly challenging environment for lubricants, so just about anything will work. Avoid vegetable based oils, as many will harden into gum over time.
Likes For JohnDThompson:
Quoted: 969 Post(s)
Liked 1,632 Times
For cleaning, ATF and for lube, regular doses of 5W-30. My chain gets dirty often on the roads I ride and a quick saturation of ATF gets old oil and dirt off as well as a little lube. Then I go to 5W-30. Sure the 5W-30 oil attracts dirt but then so do the others so really my biggest work horse in this match is the ATF.
Also... I need to put in a big kick for Chain Saw Oil, or Chain Saw oil with ATF mix. I especially like Chain Saw oil if things are going ta get wet. Also note that I have not tried Gear Oil... Yet!
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Best way is to not use it and use google and site:www.bikeforums.
Like this
oil site:www.bikeforums.net
Likes For dedhed:
Guest
Liked 3,270 Times
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
I clean with WD-40. Wax the chain with White Lightning. And lube components with Campy-like white lithium grease.
Likes For SurferRosa:
Thank you for all the suggestions
Super Moderator
Liked 929 Times
Sorry, poorly worded on my part.
I meant that as a way to see that WD-40 actually has decent oil in it. As a counter to all the warnings about using WD-40.
Not that I would let it sit before applying.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Quoted: 823 Post(s)
Liked 1,962 Times
Been using WD-40 Dry Lube for about a year now.
The drivetrains seem to stay cleaner longer and the shifting smoother.
Hope it prolongs my cassettes and chainrings.
Super Moderator
Liked 929 Times
WD-40 has a specific bike line of products now (I think)
Guest
Liked 3,270 Times
