View Poll Results: Keep dork disc or remove it
Voters: 128. You may not vote on this poll
Dork disc
Quoted: 20810 Post(s)
Liked 9,456 Times
Blowtorch.
Likes For WhyFi:
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,872 Times
If someone offered me one today, preferably a shiny, metallic one, I would seriously consider putting on my Cervélo.
Quoted: 18883 Post(s)
Liked 10,646 Times
My bike didn't even come with them, nor did my fancy hoops. I'm just not cool enough.
Quoted: 551 Post(s)
Liked 277 Times
Check first if the dork disc is an illusion.
Quoted: 18424 Post(s)
Liked 15,579 Times
TNT was originally invented to remove them.
Likes For indyfabz:
Liked 15,579 Times
Likes For indyfabz:
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
It looks odd on a sexy bike IMO...
My question would be more ''Why would you need one'' rather than ''Should I keep it or not''. If it has no real purpose, get that thing out of yoooo sight.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
A) check rear derailleur alignment and shift through all of the gears while off the bike, or
B) just hop back on and ride
If you're the type to recheck everything, you may be able to do without a dork disc. If (B) describes you, definitely keep it on.
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 339 Post(s)
Liked 229 Times
I haven't had a roadie with one in 47 yrs, and I've never had a problem.
My wife and daughter do consider me a bit OCD with my bike maintenance though....YMMV
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
Pro TT bikes essentially have one giant dork disc in the back, so if it’s good enough for them I don’t see why rec riders keep removing them.
Likes For Dan333SP:
Quoted: 4560 Post(s)
Liked 2,802 Times
I leave 'em on with new-to-me older bikes, at least until I'm sure the rear derailleur is properly adjusted. Eventually the all plastic dork discs break so I remove 'em then.
An older Araya/Suntour wheelset came with a metal and plastic dork disc. I used it with the original Suntour freewheels because it seemed to serve as a spacer. When I switched to SunRace freewheels the rear flange was very slightly thicker so the dork disc required tweaking the RD barrel adjuster and limit screw, or just removing the dork disc. I removed the dork disc.
If I had a classic older bike with all metal dork disc I'd leave it on. It adds just the right amount of wrong.
Likes For canklecat:
Likes For Pirkaus:
Quoted: 1529 Post(s)
Liked 718 Times
If you have one of those Mavic dork discs with all the little hooks for the spokes, the correct removal procedure is to remove it, take a dump on it, pour petrol on it, and then to set it on fire.
Likes For Kimmo:
Likes For Jeff of Vt:
Liked 10,646 Times
Just to clarify, because this is the 41, you set them on fire after you remove them from your wheels.
Likes For Seattle Forrest:
Dedicated Detritus Dodger
Bikes: Some mighty fine ones at that!
Quoted: 191 Post(s)
Liked 603 Times
It all depends on you. If your bike falls over or you crash, do you:
Like on my old Sears Freespirit ten speed.
Wouldn't put it on my steel Bianchi though.
I don't even know what a "dork disk" is. Does that mean I need one...or not?
I'm so easily confused. Maybe I am a dork disk.
Likes For Bicycle...and D:
Quoted: 4806 Post(s)
Liked 3,932 Times
Is the cost of perhaps a new rear derailleur, chain, paint, any carbon fiber in the area, the dropout, some spokes (and perhaps the wheel) for a should-never-happen but can mishap OK for you? If so, remove the dork disc. Recently someone here posted about the mishap he just had. The $$ total was impressive.
If you chose not to use a dork disc, see to it if you ride conventionally spoked wheels, that the "pulling" spokes on the drive/right-hand side come off the inside of the hub flange. In other words, if you are standing on the left side of the bike (on most, you cannot see anything behind the cassettes standing on the right), those drive spokes that come off the top of the hub and are pointed back as they go to the rim. Now, those spokes should be coming out of the hub flange toward you; so you cannot see the spoke heads. They are hidden between the flange and the cassette.
If those pulling spokes are indeed on the inside, then, when you do dump the chain off the cassette into the spokes, your non-pulling spokes will do their best to reject the chain and you will minimize damage. With outside pulling, the spokes will suck your chain down deeper and the damage level goes far higher. (If you try to visualize this, you will come to the conclusion I"m full of smoke. This was the word of both my shop mechanic 40 years ago and the local guru-to be who used to hang out at our shop, the then far from famous Sheldon Brown. Also my experience. Actually I've never tried outside pulling but I do look at both the damage and lacing pattern every time I see one of those mishaps. Yes, the worst inside pulling disasters are worse than the best outside pulling disasters, but overall, inside pulling comes out far ahead. I've usually been able to jury rig and ride home. Most outside pulling - that's not remotely an option.
Ben
Ben
Liked 3,932 Times
Ben
Bikes: Shmikes
Liked 5,872 Times
I would put it on my Cervélo strictly pour épater les bourgeois and, judging from the above, it would.
