Cable stops on vintage frames, what to use for ferrule?
What am I supposed to use here as a cable ferrule for a normal derailleur cable (the short piece that attaches between the actual derailleur and the frame)? A normal cable ferrule doesn't work because it is too wide to insert into the cable stop braze-on. Last time I used a raw cable without any ferrule, it started coming right through the cable stop braze-on. I'm surely botching terminology. I don't know what to call this stuff.
I see old-school bikes with a short wire coil that appears to be just the inside of a modern cable, but slightly wider.
Likes For ppg677:
Likes For Old Yeller:
Bikes: yes
Quoted: 512 Post(s)
Liked 411 Times
You need a step-down ferrule. One end is large enough for the cable housing ferrule and the other end is small enough to fit into the cable boss. That probably steps down from 5mm on the cable housing side to 4mm on the boss side.
Likes For Vintage_Cyclist:
Quoted: 1166 Post(s)
Liked 443 Times
You might try a stepped ferrule. Something like 4mm/5mm. This will fit more securely, not flop around & will accommodate index ready compressionless housing. Jagwire or Shimano branded kits often include a variety in the bag.
Likes For masi61:
Ride, Wrench, Swap, Race
Quoted: 1566 Post(s)
Liked 1,301 Times
Ferrules are very critical for preserving the ends of compressionless housing, and must be sized for a slop-free fit to prevent any of the lengthwise strands from migrating into the hole that the cable must pass through.
I sometimes have to search to find the right-sized ferrule for both the housing and for the cable stop. I have taken to keeping my ferrules more organized since I use a lot of them and hate to waste time searching for the right one.
The particular ID size of some late-'80's Schwinn's housing stops under the chainstay has recently given me some grief, had to spread them open to get a ~5mm stepped ferrule to fit. Seems they used standard housing with no ferrule on the 6s models, but that had to go for good shifting to be realized.
shimano is 4mm
campagnolo is 4.1 mm
i think
just bought some campy step down • steel
and shimano step down alum.
the old campagnolo wound wire is 4mm
and then again, i could be totally wrong
blahblahblah chrome moly
Quoted: 1197 Post(s)
Liked 2,627 Times
In case having Campy part numbers might help in your searches:
On a full-campy bike, that piece of housing from chainstay to mech (with the proper ferrules at each end) would be part number 617 if the bike has a #621 "diver's helmet" chainstay braze-on.
For bikes with no braze-on, they made the housing stop clip #636, and it doesn't use a step-down ferrule. The housing for that came with matching "plain" ferrules at both ends, part #622
This is from Catalog 17a ('79 I think).
I don't remember ever seeing a part number for just the ferrules. I wouldn't be surprised if they did sell bags of ferrules to distributors or bike shops, but they didn't call them out in the catalog, at least not in the NR-SR era or earlier. I stopped paying attention to Campy after Record-C came out.
Oh wait here it is, in Catalog 18 ('84 I think). Plain ferrule is #619, step-down is #620. Sorry for writing the above out of ignorance, but I'm not going to delete it now, after all that typing.
Only the pickiest concours judge would take off points for not having the period-correct ferrules, but if you want it to look excruciatingly correct, please avoid anything made of plastic, or black or any color besides "silver" (broadly defined). Campy's were dull-plated steel, but a silver aluminum ferrule could be acceptable, at least it wouldn't make me want to hurl. They're thicker-wall though, so they don't look completely right to us old guys who grew up with tutto Campagnolo. Please for God's sake don't use one that says Jagwire or <shudder> Shimano on it...
Kidding! Well, mostly. I do have a small stash of actual Campy-brand cables, housings and ferrules that I keep for total period-correct builds. But for most bikes, just making it work is good enough.
Likes For bulgie:
Likes For oneclick:
Likes For thinktubes:
Bikes: Yes
Quoted: 3236 Post(s)
Liked 3,883 Times
At least he attempted to provide new info for a common question.
For diver's helmet stops, I use Shimano stepdown ferrules with Jagwire outer cables. It works perfectly with indexed shifting.
My Bikes
My Bikes
Likes For Andy_K:
Likes For Millstone:
As for me, finding step-down ferrules was once a very difficult task. Recently, I found a shop here in Sendai that has a jar of metal ferrules. Apparently the proprietor obtains them from Shimano.
MORE: recently I visited another shop owned by a friend who is both the proprietor and mechanic. I needed some advice concerning a derailleur hanger. He spotted that a plastic ferrule contained in a Shimano cable kit was disintegrating. He scolded me for using it. The metal variety was substituted with satisfying results — not a perfect fit for an ancient Sugio 75 component, but good enough.
AND: more recently I've learned that some vintage components do not mate exactly with currently available step-down ferrules. At least not the ones I can find. I can't exactly set down the details here. So if this dinosaur thread stays open for added discussion, contributions and blah blah details, I'll be a faithful follower.
Vitus 979, Simplon 4 Star, Gazelle Champion Mondial, Woodrup Giro, Dawes Atlantis
Likes For Lenton58:
Quoted: 604 Post(s)
Liked 1,064 Times
Similar cable stop on my Bianchi, went to look to see what I used, yup step down ferrule.
Tim
Tim
Quoted: 802 Post(s)
Liked 760 Times
My 80s Raleigh also has a diving bell cable stop along the chainstay. The frame did come with the correctly sized stepdown ferrule to fit in the cable stop, only problem is that it doesn't fit modern index derailleur housing, the housing is too fat. I 'solved' the problem by using another stepdown ferrule and another regular ferrule. Indexes fine so...maybe I don't mess with it.
And I've also got to figure out the appropriate stepdown for CLB brakes, the ferrule and housing is too large to fit.
Bikes: yes
Quoted: 512 Post(s)
Liked 411 Times
Custom step-down ferrule made from a barrel adjuster liberated off a bonked-up old derailleur. Shortened the smaller threaded end to fit the stop and filed-down the threads and barrel ridges smooth.
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
OK, ancient thread, but this might be useful to someone, someday.
The ferrules / cable end caps I had for brake and shift cables fit the housing just fine, but the cable stops on this old Motobecane were not cooperating. While the housing would fit into the cable stop, the ferrule would not. FIX: cut the ferrule down and slide it in place, then run the cable, then shove the housing in place. This "sandwiched" the ferrule in place so it could do what it's supposed to do, to stop the housing from compressing. There's nothing saying the ferrule has to be a certain length; it just needs to go over the end of the housing and up against the cable stop.
Here's the bare frame, hopefully you can see how the frame's cable stops are designed, which made it so cutting the ferrules down was the only way they were going to fit.
Bikes: Yes
Liked 3,883 Times
These have a 5 mm inner diameter. The 619 ferrule (without the stepdown) from bulgie's part's diagram fits it with a vintage steel coil cable. For indexed shifting, I hadn't been able to find anything that fit perfected until I stumbled into an arrangement with @oneclick who machined the ferrule in the picture above for me.
My Bikes
My Bikes
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1301 Post(s)
Liked 942 Times
To select the proper step-down ferrule, you should make sure you are getting what you need. Overall length, length of the narrower section, inside diameter, outside diameter and outside diameter of the narrower section should be ascertained.
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
I still have to try the metal valve cap bodge that is mentioned above. I need an odd sized step-down ferrule for a Sugino 75 derailleur.
Quoted: 1866 Post(s)
Liked 665 Times
ronfinch
Bicycle Mechanics
8
06-13-18 10:59 AM
bartturner
Tandem Cycling
10
11-04-12 03:10 PM
