Heart rate oddness?
Bikes: Giant Prop Giant SLX Specialized roubaix
Quoted: 8 Post(s)
Heart rate oddness?
It will be interesting to hear others views on my predicaments and maybe some who have experienced it.
Last year i had what i would say was a quite normal fluctuating heart rate as in it would increase under more strain such as climbing hills or just putting more watts down through the pedals. This year it has become quite bizarre as no matter what power or what gradient of hill it caps out at the same reading.
However on the flat i am faster this year but up hill i am well down on last and i can only put this down to the failure to increase my HR. Here is the thing though my FTP is higher than last year and my weight the same.
It's frustrating to fly along on the flat faster than last year only to know that the legs just wont get the watts down to create a good climb. I have had a medical check and all is fine .
I have been training quite a bit lately so is this over training and the legs just are not up for the job to climb and so not demanding an increase in HR or is it the legs are OK but the HR will not move them quicker.
Quite a strange dilemma i have found myself in that i have never come across before.
To sum up if i had a 15 mile course with 3 or four quite steep short hills and then flats my HR would stay the same or within a few beats from start to finish with the flats being fast but the hills dismal
Thoughts?
Thoughts?
You're reading too much into it. If you've increased your cadence up the hill from last year you will likely have an increased heartrate, if you have a malfunctioning heart rate monitor, you could just replace it (if you are getting consistent 240 hr readings that's a typical sign that it's no longer functioning properly). If it's predominantly warmer this year rather than last year it could cause a higher heart rate...
What I'm trying to say is, HR is a decent metric, but there are tons of variables that can affect it. Best thing would be getting a power meter and forgetting about HR (however, HR + Power is awesome).
Bikes: Shmikes
Quoted: 10173 Post(s)
Liked 5,869 Times
I'd consult a leg-iologist, but what do I know?
Likes For sdmc530:
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Your HR might not be what's limiting you on hills. There was a time when I felt pretty good about my endurance but I could not reach a maximum heart rate on hills. I'd run out of wind or legs first before that final push and it would top out about the same as a hard sustained pace on the flat.
That eventually solved itself but it was due to conditioning other than the heart. It could be that or something else entirely in your case. There are a lot of variables, and the submaximal heart rate generally reflects our level of effort rather than modulating it.
Quoted: 20810 Post(s)
Liked 9,456 Times
Put up some HR and power graphs for this typical ride.
Likes For WhyFi:
Quoted: 6196 Post(s)
Liked 4,810 Times
Your HR will top out. You'll only be able to do a near max HR effort for a very short period. If you are seeing your HR consistently at the same level for various grades and such, then perhaps you have unwittingly trained yourself to maintain a particular level of exertion for these efforts that wind up giving you the same HR rate.
Have you tried increasing or decreasing your effort to see if your HR responds accordingly? While it's nice to know how hard and long you can maintain a certain effort by your HR rate, it can get you into a performance plateau if you make it a habit to rely on HR alone to base what you do.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
The more fit you are, the harder it is to hold a higher heart rate for longer.
Congratulations! You have a heart that is stronger than your legs & plenty of blood to carry O2 where it needs to go.
Next step: Work on leg strength to get stronger & create cardiovascular demand.
Flying on the flats is all aerodynamics & rolling resistance. The hills are exposing your leg strength as your new limiting factor.
Quoted: 18883 Post(s)
Liked 10,646 Times
Are you eating enough carbohydrates? What HR do you top out at?
Quoted: 10 Post(s)
So, every time I got to a doctor, they always say "has anybody ever told you that you have an abnormal heartbeat?"
I also went to a cardiologist, once they did a cardiac cathertization, where they run a scope up your thigh artery and then take images with die of my heart. Come back clean as a whistle the doctor says...that was around 48yrs old. I'm 52 now.
So, back to the abnormal heartbeat, my heart rate will run 175-182bpm an entire high intensity ride...like race pace Cat1 stuff....
The "experts" just say, "well, since we don't know what your heartbeat was like when you were younger, and you've been an athlete your entire life, and ride with your heart rate up over 180 even 190bpm.....guess we really don't know what to make of it?!?!?!"
Wow, that was helpful...obviously there are things cardiologist can identity immediately...but this is a classic, we don't know...enjoy your life response from them. Last time I went to a cardiolist, and when a doctor tells me that I just say, yeah, I've heard that before, what does that mean? Just to mess with them, and they shrug because they have nothing to say as to what that actually means. It just means it isn't like a normal heartbeat...ghee thanks!!!!
Quoted: 878 Post(s)
Liked 726 Times
Is that you Simon Yates?
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
LT1 aerobic or LT2 anaerobic lactic tolerance isn't the same depending on how trained you are or even across different people.
On these hills, is the pain telling you to stop or is it the physiology? The physiology stopping you would be due to your aerobic or anaerobic system not meeting the effort's needs despite your mind's ability to drive you forward.
You'll know when it's the second one. It's when you bonk a short or long climb early, and need to sit for a bit or take a little "dirt nap".
The HR will ramp quickly at first, then will have a pretty steady linear slope at a lower ramp rate from there until failure.
Does the HR for the effort look like either of these? Zoom in on the ride/workout and take a look. It should look similar to one of these. Even during a ride around town, you should be able to spot these shapes.
2min anaerobic:
https://www.strava.com/activities/2349144564/analysis
8min aerobic:
https://www.strava.com/activities/2369973736
2min anaerobic:
8min aerobic:
Quoted: 479 Post(s)
Liked 277 Times
wears long socks
Hold my beer
I am potato.
Liked 1,629 Times
Disagree.
First: Find any cyclist on their first week of cycling and make 'em do 12 mph for any length of time. Their heart rate will be 180 bpm & they'll fail to go any real distance or for any length of time. It will remain sustained higher long after the effort.
Then take a seasoned cyclist. Make him do 18 mph for a half a day...His heart rate will be 140 and will getting it higher will require hills, sprints, etc...and it will recover quite quickly after the effort.
Are you telling me the untrained non-athlete has a healthier heart because it can get to higher beats per minute with less work?
That's not how fitness works.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Disagree.
mph (or insert whatever speed) at 180 bpm. That's how fitness works. You can still do the same efforts and it doesn't get easier, you just go faster.
I am potato.
Liked 1,629 Times
Deliberately left out of this discussion is equipment. The seasoned athlete likely has a fancy bike which skews speed distance for effort.
I think we are talking past eachother.
Here, try this on for size: A 96% effort on my 1974 Schwinn Varsity. Is the heart rate pinned? No. It tracks with elevation nicely and power meter quite nicely. What's the average Heart rate? Hmmm, it's not 196 BPM.
How much Heart rate Zone 5 is there for all that time spent in Power Zone 5,6,7?
I assure you my FTP is accurately set & I own many, many power meters. A normalized power of 270 watts for an hour and a half...An average HR under 160 for an average power of 240 watts.
Screenshot_20190520-112934_Connect by Richard Mozzarella, on Flickr
I assure you on my race bike, cruising around on flat level ground my HR is less than many peoples while they are walking. What I said above is true.
The fitter you are, the harder it is to have a higher heart rate longer. Your body has adapted.
Likes For eja_ bottecchia:
Quoted: 479 Post(s)
Liked 277 Times
Or, are you confusing "need" with "ability"? I.e., as a cyclist gets fitter, he doesn't "need" to maintain the same HR to match the previous avg speed over the same route. He is still "able" to maintain that HR... but (here it comes)... if he does maintain that higher HR, he's just going to go faster ;-)
wears long socks
And he'll do 24 mph for that same mile or 3 that the unseasoned non-athlete is capable of before blowing up.
Some peoples bodies, believe it or not, do not behave exactly the same as yours, or anyone else's for that matter.
My max heart rate is 205. I just posted a ride where I averaged 180 (almost 90% max for over an hour). How was I technically anaerobic for over an hour without my legs filling with lactic acid rendering them useless if I am not fit?
The simple answer is... there is no simple answer. There are variables in oxygen uptake, oxygen delivery, metabolic efficiencies, and cardiovascular systems from person to person.
Cardiologists still argue about low resting heart rates. Some call it a fitness adaptation, some call it neurological damage.
Bikes: bikes
Liked 1,429 Times
You said you can't go as hard as long when you're fitter. That's wrong. You most certainly can. You just go a lot faster.
I can go just as hard for 1 minute, 5 minutes, 60 minutes, 3 hours now as I could when I first started. The difference now is way, way more watts and speed.
Equipment has zero to do with any of that. What you do on your race bike has nothing to do with anything. I can put out the same effort on a cross bike, mountain bike, race bike, whatever. The effort can be the same. Speed will obviously change accordingly.
Bikes: Shmikes
Liked 5,869 Times
Is it possible to improve cardiorespiratory function out of proportion to muscle fitness? I don't know, but, that might result in failure to drive heart rate.
