Addiction LXXVI
#1326
Bikes: Shmikes
Quoted: 10170 Post(s)
Liked 5,863 Times
#1327
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Likes For datlas:
#1328
Liked 8,925 Times
BTW how much does a force AXS Groupset cost? Asking for a friend.
#1329
Silver Comet Fred
Bikes: 1
Quoted: 8835 Post(s)
Liked 2,986 Times
#1330
Silver Comet Fred
Bikes: 1
Liked 2,986 Times
This is the site for research on purity, quality, and yes, awesomeness.
https://labdoor.com/
This is a great site for all things supplement.
https://www.bulksupplements.com/
Might give it a shot but several years ago I took it for 6 months or so with no noticable effect. Might be snake oil.
As far as giving up refined carbs?
The cure is worse than the disease.
#1331
Quoted: 20810 Post(s)
Liked 9,456 Times
#1332
Silver Comet Fred
Bikes: 1
Liked 2,986 Times
Damn right, you can take my sugar away from me when you pry my cold dead hands from the sugar bowl.
#BumperStickerWorthy
#1333
Mostly Harmless
Bikes: Have two wheels
Quoted: 13714 Post(s)
Liked 4,530 Times
#1334
Mostly Harmless
Liked 4,530 Times
#1335
Mostly Harmless
Liked 4,530 Times
About $2,300 for Force level rim brake version, if you don't need calipers. Add $150 for brake calipers.
#1336
So it is
Quoted: 11402 Post(s)
Liked 4,759 Times
#1337
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
I don't have enough wheelsets to go around, so they get moved to whichever bikes are currently active. I took the blue Trek out this afternoon. It has a Vittoria Open Pavé on the rear and an Ultrasport ll on the front. When I got home and cleaned up, I ordered another pair of those babies. The Open Pavés, of course.
#1338
Liked 8,925 Times
Hmm...
#1339
Bikes: Shmikes
Liked 5,863 Times
The #1 rated glucosamine product is available at Walmart and cheap!
#1340
Mostly Harmless
Liked 4,530 Times
#1341
Bikes: Shmikes
Liked 5,863 Times
Coffee science question: I have a burr grinder and the static charge it puts on the coffee makes it fly out of the little receptacle, stick to the housing of the grinder, and get all over the counter. However, I have recently discovered that if I set it one tick finer than the usual grind I used for the drip machine at home, no charge. When I grind it coarse for the French press on the boat, I don’t think it’s that that sticky either, but it’s been a few weeks and I’m not sure.
Anyway, why does a small change in grind make such a difference?
#1345
Liked 9,456 Times
#1346
So it is
Liked 4,759 Times
#1347
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
You are looking at $2500 for Force, 3500 for Red. Roughly. And it effects everything, wheels,bottom bracket,...well, not the headset. But that's groupo, still need to get wheels for the disk brakes.
Now, I didn't pay that, I shopped around on EBay and got lucky. I should be all in under $3500.
I got tangled up with a post mount (disk brakes) frame. That caused me a little trouble. I ended up buying a set of Red post mount calipers. No one makes adapters! There isn't enough room on the frame apparently. There is one co. But New old calipers was just easier. I
Then the wonderful folks at Sram decided we needed another bottom bracket standard. So now we can all try and figure out Dubb. The new axle is 28.9mms dia. Basterds. I sti ok working on that one.
#1348
he said member
Bikes: yes please
Liked 1,951 Times
#1349
Silver Comet Fred
Bikes: 1
Liked 2,986 Times
#1350
he said member
Bikes: yes please
Liked 1,951 Times
