For the love of English 3 speeds...
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
I'm having a hard time fitting my rear fender back onto the '50 Superbe. I think the Panaracer Col de la Vie tires are a bit bigger than the original. The front went OK with a little wiggling and adjustment, but the rear has been a pain. It is very tight right at the back where the fender reflector bolt end rubs on the tire. I'm wondering I could use a shorter bolt, but I am afraid to remove the reflector housing bolt. I suppose I will keep moving it around to find the best alignment. I think the trick is in where it mounts at the brake; there is something curious about the way they mounted the fender stay clip. I just have to run the shifter cable, install brake cables with original oiled housings, and dial in the shift adjustment before I install the 3 speed Cyclo derailer. I am very excited about the Cyclo unit because it will help on our local trails and my commute. I may even take it on an overnighter or weekender once I can trust it.
On a normal set up (one cog) the wheel sits about half way
in the drop out allowing you a little room for adjustment
as the chain stretches.
You're entering new territory with your set up and will need
some time to dial it in...
Quoted: 157 Post(s)
Liked 113 Times
I had been looking for a 3-speeds bike and I found one in my size a while ago. It's a BSA Star Rider supposedly from '62. It's quite a heavy machine but it has some nice details. I haven't seen many of them here on the forum, but I found this one here.
Last weekend, I took it from the storage for a check and some adjustments. Mounted a Brooks B67 saddle, adjusted brakes and oiled the hub. I will take it for a small ride tonight to see if I need to do anything else. Will definitely have to fix lights and adjust the rear brake a bit better. I am busy with other projects so I don't have enough time right now for a complete overhaul. Anyway I am gonna use it as an all-around bike as it is now.
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 360 Post(s)
Liked 469 Times
Yup. Just take a coarse hand file or dremel to shorten it, making sure to clean up any burrs. I'm not sure which fender/brake mount is being used here but sometimes you can put a spacer between the chainstay bridge and the front of the rear mudguard to shift the whole assembly back and possibly give you a nicer arc to work with.
Perhaps your rear wheel is too far back in the drop outs.
I'll take nice photos at a local cycle destination when it is road ready.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Wonderful bike. Dutch market, possibly even assembled in Holland by Gazelle with Raleigh parts. The rims aren't Dunlops so likely dutch too. I think BSA's have the nicest fork crowns. Congrats.
Quoted: 1299 Post(s)
Liked 103 Times
Inflate Hard
Inflate Hard
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
I've got a Wright's non-leather saddle with the bike that's in bad enough shape that I don't consider it rideable. Will probably replace with a B-72, which would look proper and is a heck of a lot easier to find.
Pre-war/early-war, I'm equally happy. Consider that my original plan for the group was to pick up a '70's DL-1 and completely refinish and backdate it. The group was fine with this - in WWII-era reenactment, unless you've got a BSA folding bike, you fudge like crazy, and I've seen more than a few Huffy's, etc. repainted to look sorta like the proper thing at 15 feet. I discovered years ago that most WWII re-enactors know almost nothing about Thirties bicycles, and usually spend some of my off-duty time from the James Fort at MTA talking with the units, filling them in on what they need to do if they want that part of their impression to be dead-on.
And don't ask what BSA folding bikes go for. You'll be picking your jaw off the floor. They're highly desirable.
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
Quoted: 457 Post(s)
Liked 462 Times
Just rode it to town and back and its running and shifting great :-)
Quoted: 360 Post(s)
Liked 469 Times
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
I've just gone back and taken a look at the photos I posted in this thread when I first bought the bike and brought it home at Christmas. The rear wheel was installed about halfway in the drop out. Great suggestion thanks. I'm going to re position the wheel and that should take care of the fender clearance issue. In looking at the photos, I realized that the right hand brake lever was controlling the front brake. I know for cable routing perfection that is preferable, but I'm going to stick with muscle memory.
If the wheel is all the way back things get tricky. One reason it might be there is the chain is shot. Another might be because its too long. But taking a link out might make it too short. You can buy half links (ebay) to solve the latter problem. If you've not got a chain link tool, get one (Park makes the best I've had so far), get some scrap chain and see if you can remove and reinstall links properly. Its not hard.
Quoted: 157 Post(s)
Liked 113 Times
You got a good one. It's possible that this is Raleigh made in Nottingham with some aftermarket parts. They used some premium features on this bike. It has the Raleigh pattern dual purpose rims and the nicer single bolt brake levers. Back when I worked at the Raleigh dealership, the head mechanic always made a stink over stems set too high. He wanted the expander to be below the threaded section of the fork tube. Raleighs don't have a keyway cut into the tube, so it may not be as critical, but what he told me about failures there stuck with me all these years. This stem looks like the expander is up under the threads. Great choice of saddle. This bike may have originally had a Brooks since it seems to be a premium model. Nice Bike.
Quoted: 157 Post(s)
Liked 113 Times
Quoted: 360 Post(s)
Liked 469 Times
The problem here is that the chain tension (or lack thereof) has to be correct- you can just move the wheel around. Generally about 1/2" to 3/4" deflection in the middle of the chain if you pull it up with your fingers. That governs the position of the wheel.
Quoted: 3810 Post(s)
Liked 6,699 Times
More than once, I've put in the low-gear pawls backwards (or the opposite orientation that they're supposed to go), which then meant that first-gear didn't work. You might want to check that!
Quoted: 457 Post(s)
Liked 462 Times
Quoted: 221 Post(s)
Liked 237 Times
Just saw these on CL. Men's and Ladies All Gold Editions.
https://northmiss.craigslist.org/bik...907727264.html
Anybody near this location interested? I wish I was closer.
Seems like a pretty decent guy, during the course of the conversation I casually mentioned that, while not totally unreasonable, his price was a little high given the condition of the bikes. He's had an offer of $100.00 for the pair, is trying to get a something closer to $150.00 for them. They're 67's (from the hub), and he's owned them since new. The usual 'haven't ridden them in years, let them sit forgotten in the rafters' situation.
They guy's name is Winston, and his phone number is 205-570-3400 (he had no qualms about giving me his number, so I'll assume he's not going to complain is someone from the group contacts him regarding the bike).
Syke
Syke
Quoted: 22 Post(s)
I just got off the phone with the guy. A couple of days ago I'd emailed him, explaining to him how you figure out the year of the S-A hub. He called me about twenty minutes ago after I texted him a pic of one of my inventory hubs to show him the details.
Quoted: 887 Post(s)
Liked 335 Times
I looked through the photos in the ad the seller posted and I can't help but think that these bikes spent a bit of time on the gulf coast, or more time outside in any place away from the coast. I don't think that the chrome is toast, but it is nasty along with rust spots through the paint. Both are too small and too far away for me. Maybe $100 for the pair at best - nice color though.
Quoted: 221 Post(s)
Liked 237 Times
And it's not one of the standard catalog colors for 1967. The guy is originally from Southern California, that's where they were bought. Decades in the rafters, forgotten, will kill any finish.
Syke
Syke
Quoted: 796 Post(s)
Liked 522 Times
Plus one on the Park Chain link tool, you hear that you don't need a tool to undo a power link/quick link chain but I have found that to be bs, I have tried many ways shown on youtube etc with little success but the chain link tool makes it a breeze. I have been free of pin connector chains about a decade now.
Liked 443 Times
I've got one on a bike and another waiting to be installed.
Liked 103 Times
All of my bikes still have the old fashioned master links with the little clip. I like the look of these quick links. I see a change for me here, but I would want a pair of those special pliers. I can see needle nose pliers slipping off and pinching my fingers.
Inflate Hard
Inflate Hard
Bikes: 1983 Trek 600, 1972 Raleigh Sports Step Thru, 1963 Rudge Sports, 2007 Dahon MuP8, Dahon Speed, Public Mixte 8-speed IGH, mid-70s Peugeot Mixte AW conversion, Riv Platypus
Quoted: 350 Post(s)
Liked 24 Times
The master links with the plate on one side open with any pliers, but the ones with two symmetric pieces, it's tough without those special ones. Is one better than the other? No idea.
Quoted: 457 Post(s)
Liked 462 Times
The special pliers make dealing with the power links really easy! You can use the pliers to get the link to click into the locked position in addition to using them to undo the links. I do periodically remove my chains to clean them in a jar of laquer thinner so I use the pliers regularly. Cleaning my chains like that really increases chain life.
Things you already know.
Remember extra links needed going from 18 teeth to a 22. Old faithful link splitter does wonders.
I have my old faithful chain link thingy for many years.
Special thanks to Dan Burkhart for the 22 tooth cog.
Likes For Alloyboy:
