Centerlock vs 6 bolt disc question...
I am sure this is probably a dumb question, but I'm new to the world of disc brakes...
My current bike has 6 bolt discs. If I get a new set of wheels with centerlock, aside from having to buy the different discs for the wheel and making sure they are the same diameter, there shouldn't be any compatibility issues right?
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
There shouldn't be. I have one wheelset of each for my main ride.
In practice, the rotors might sit in a slightly different position in space, relative to the bike frame. You can buy rotor shims (usually for the 6-bolt) to correct that. I think there might be rotor shims for center-lock, if you need those instead.
The worst case scenario is that you have to adjust the position of the caliper slightly after a wheel-change.
Likes For Cyclist0108:
Quoted: 184 Post(s)
Liked 67 Times
If you want to continue using your current 6 bolt rotors or you want to buy another set of 6 bolt rotors, you can get adapters for using 6 bolt rotors on centerlock hubs.
https://bike.shimano.com/en-US/produ...SM-RTAD05.html
wgscott is right -- the design specs would put the rotor in the same place, whether it's 6-bolt or centerlock. If one rotor has worn thinner or is off in some way, you'd just adjust the caliper a hair.
Likes For ljsense:
Occam's Rotor
Liked 2,331 Times
BTW it is not a stupid question at all. The answer is under-documented.
Bikes: CO-OP ADV 3.1 aka Beeftank (stolen, RIP), State All-Road
Quoted: 96 Post(s)
Liked 144 Times
In case you wanted a real world example, I swap out CL and 6b discs with no issues. Go for it!
Likes For walnutz:
