Help me mull a wheel upgrade for Salsa Warbird
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4408 Post(s)
Liked 3,031 Times
I've got a 2020 Salsa Warbird 600 GRX that is sweet as can be, but of course it came with cheap and heavy wheels - WTB speedterra hubs ST i23 rims. This seems to be an OEM combination, so I can't find any specs on overall wheel weight, but I gather it's around 2000-2100 grams for the set.
So I'm thinking about an upgrade. I could get carbon wheels from LightBicycle for maybe $850 and they'd weigh around 1600 grams. But I'm not entirely sold on carbon rims for a gravel bike.
Any suggestions for alloy rims that would come in for about the same weight but less cost? Or alternatively, maybe I should just go with carbon rims? I'm running 42 mm Terravail Cannonballs now, but I'd like the option to run anything from 32 to 42 mm on these, so I'd be hoping for internal rim widths of 23 mm or so.
Quoted: 1099 Post(s)
Liked 1,039 Times
Quoted: 1873 Post(s)
Liked 692 Times
I literally just went through this for my Warbird. I went went carbon Bontrager Pro 3V's for two reasons:
1) I've never seen an alloy wheelset last all that long on a properly ridden gravel bike. The spokes holes in particular seem to give out way sooner than they should.
2) Bontrager's warranty is pretty great. 2 years against defects (spoke holes breaking), and lifetime crash replacement (much cheaper than buying new wheels every time they break, which they will.)
I figure the initial up front cost will even itself out over the course of a few years.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Bikes: Niner RLT RDO, Trek Remedy 9.8
Quoted: 108 Post(s)
Liked 117 Times
I have Light Bicycle wheels (hooked rims) for my gravel bike and I really like them - also they are much lighter than 1600 grams.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
keep in mind with carbon - you are often looking at hookless rims. Not really a problem if you are below 5 bar, but I wouldn't go more than that. Although hook-less rims seem to be a little fat on the diameter side of things, making it more difficult to mount some of the tighter beads you can find on a higher pressure tubeless tire. Food for though.
Quoted: 101 Post(s)
Liked 41 Times
I’ve been happy with the DT Swiss c1800 wheelset that came on my 105 Warbird. DT Swiss says 1741g for the set, MSRP is under $500 but I’m guessing you can find them for less than that because they are a common OEM wheelset. Only had them for a year, but so far they’ve been great.
I'd go with the DT Swiss GR 1600 if you just want something reasonably light (for a wide alloy rim) and bombproof for training / adventure riding. You can still order them from Merlin Cycle for less than MSRP ($500) in the grey market. I had to talk myself out of a pair.
Other options (all built in USA by the way):
$700 - HED Emporia GA (formally Belgium G)
$700 - Astral Outback
$600 - Spinergy GX (cool wheels, but a big gotcha on truing)
I'm kinda waiting to see if there is a sale on the HED or Astrals during the winter myself (why I didn't get the GR 1600).
Liked 3,031 Times
Liked 415 Times
Quoted: 427 Post(s)
Liked 339 Times
The DT Swiss Whelset mentioned above is our second favorite, but the often overlooked bargain is the new Shimano GRX wheelset at $419.00 US. It has fantastic and easy to service Shimano cup and cone hubs, weighs a little over 1600 grams, is really durable and has straight pull spokes. We have put these on a lot of bikes this year as an OEM upgrade, and honestly for under $500 they are our favorite. We stock and sell DT Swiss, Reynolds, FSA, Hunt and Easton at our gravel shop by the way but in this price range they are our favorite. They do not have a cult following or cool decals, but they DO PERFORM! And when they do need servicing all you need is bit of grease and cone wrenches, no special bearings to order or finicky adjustment procedures.
Liked 3,031 Times
Quoted: 427 Post(s)
Liked 339 Times
The published weight specs on the set bounced around when they first came out but the last we saw was I think 1650 grams. I'll check the weight on a set we have at the shop this week and confirm. This actually has a steel hub body which is incredibly durable, and that means more of the rotating weight is at the center instead of at the rim though so that makes it a very fast-feeling lively wheel. The Hunt and FSA wheels at this price are overall lower quality though a lot of folks like them because they are trendy. The Eastons are really good but a bit more expensive, The DT Swiss are nice but a bit more pricey (have to spend $800+ to get an equivalent to the GRX). Reynolds are fantastic but way more expensive (carbon only). After a thousand miles or so the differences become more apparent in how they hold up. We test everything we carry ourselves with multiple riders and frankly and to our surprise the Shimano GRX wheels are really high quality, great ride quality, durable and very well priced. Our only issue is we wish they were 1.5MM wider inside. Two of our heaviest riders beat the pee out of a set for the whole summer and they stay dead true, and bearings really hold up... And if you have ever worked on a Shimano wheel you know how easy and inexpensive they are to service. Not the sexiest, but they do hold up. And no weird tools or methods for the spokes either. Shimano was really late to the game with introducing these, but they knocked it out of the park when they did. Nothing we have seen beats these at this price.
Quoted: 427 Post(s)
Liked 339 Times
Note: Riding Gravel review claims 1650 grams for 700C wheelset: https://www.ridinggravel.com/reviews...ts-checkpoint/
Liked 3,031 Times
The step up from that is their Ultegra-equivalent WH-RS770-700C, which comes in at 903 grams (rear) and 733 grams (front), so 1630 grams. I've seen this one selling for about $700
I’ve got about 1000 miles on a set of Hunt 30 carbon gravel disc’s so far this season. I don’t ride rocky singletrack but I’m a big guy, ride gravel 90% of the miles and so far so good. I went with carbon for the durability. The advertised weight of 1480grams was spot on. They have Novatec hubs that are annoyingly loud but they have held up so far. Tires mount really well tubeless (Ramblers and Terra speeds).
I looked at their site and they are 100 bucks more than when I bought mine in February. You pay a 10% duty on any purchase over 800 so that adds enough that I think I’d go for a wheel with a better hub set for comparable dough.
For the folks who say alloys ride better... you may be able to tell a difference but running tubeless 40 or 45mm tires? I don’t think so. Durability of the carbons makes it an easy choice imo.
Liked 3,031 Times
It's confusing. For the GRX wheelset (WH-RX570 700C) that sells for $419, Shimano has the front wheel at 769 grams and the rear wheel at 950 grams. So, 1720 grams for the set. That's a pretty good deal.
I tend to like Shimano hubs, too which are pretty quiet.
Still thinking. I'll buy wheels for this rig eventually, but I'm not in a hurry.
Quoted: 125 Post(s)
Liked 54 Times
Also, dwmckee, can you clarify which of the dt swiss wheelsets mentioned is your second favorite? I see the GR1600, G1800 and C1800 all mentioned.
Hope and DT Swiss are 2 examples have end caps to support both QR and TA.
Paire de roues DUKE Lucky Star ultra / Bitex - JPRACINGBIKE1
Offset alu rim. D-light spokes. Bitex.
CX-Ray are higher price. There's also a DT Swiss hub option.
Quoted: 576 Post(s)
Liked 1,004 Times
I've been using Easton EA90SL Discs since April and really like the light weight and quick engagement. They use replaceable end caps, weigh at 1560g per, have an inner width of 19.5mm, but are hookless - if you want to run high pressure they might not work for you.
