Rear rack w/ disc brakes
dazed and confused
Bikes: 2011 Cube Hyde Team Alfine 8 IGH, 2007 Giant Rock hardtail mtb
Hi again, what's the difference between regular pannier racks and those that specify disc brakes? Are they wider? Is it the way they mount?
I'm not seeing a lot of options for disc brake compatible racks. For example, on CRC there are 40 racks which don't mention disc brakes and only 3 that do.
Are my choices really that limited?
I use the Topeak Explorer disc-compatible rack, which works well with the Topeak slide on trunk bags.
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
A lot of it depends on where your caliper is mounted. If the caliper is inside the rear triangle, any rack will do. This location is becoming more common.
In any event, that's where my caliper is so I didn't need a special rack and I don't know exactly what makes them special.
Older than dirt
Bikes: Too darn many.. latest count is 11
Rather than the rack going straight to the dropout, the rack is designed to clear a caliper mounted on the back of the seatstay. Kind of an L-shaped mount, rather than straight. This pushes the rack stays outboard, without which you would have to come up with a DIY installation.
dazed and confused
Bikes: '08 Trek 7.3FX
EDIT: Recalled incorrectly.
A quick Google search turned up a bunch of results under "disc compatible rack."
Does anyone have a closeup pic of this?
see detail #2
the stand off itself is a pretty basic machine shop project.
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
from a sellers site: htthttps://www.calhouncycle.com/produ...oduct=1327p://
see detail #2
see detail #2
Grizzled Curmudgeon
Bikes: Specialized Diverge, Santa Cruz Tallboy LT Carbon, Specialized Stumpjumper (hardtail), Kona Humuhumu, Co-Motion Nor'Wester
I have the Old Man Mountain "Cold Springs" rear rack on my disc-equipped Specialized Stumpjumper hard tail. See https://oldmanmountain.com/Pages/Rack...ar_gallery.htm for photos. In the top photo you can clearly see the stand-off on the mount. This requires an extra long rear skewer, but seems to work well. I've had mine for about 3 years with zero problems.
keithmo.com
keithmo.com
dazed and confused
Thanks for the details. I went to the LBS yesterday where they have the non-disc brake Topeak SuperTourist and held it up to a couple of bikes with disc brakes. Now re-reading this thread it all makes sense.
I'm not sure how common it is to have the caliper mounted inside the rear triangle. It appeared all the disc equipped bikes at this shop would need a disc specific version rack. However, I did get an email from Cube which said,
"The Mounting points are on the outside of the frame and the disc brake is on the inner side."
So it looks like I might be able to use any rack afterall.
