Insanity...
Rhapsodic Laviathan
Insanity...
All you wieght wienies can just give it up, you'll never be diety status, like this guy and his exalted beast. Your dedication pales in comparison. Pure overkill reached only by psychos of high caliber.
Likes For ChinookTx:
Bikes: Salsa Beargrease XX1, Trek Eqnuinox 9.9 SSL, Trek Madone 6.9 ,Trek District Carbon, Trek Boone7, Trek Fuel EX9.0,Trek Fuel 9.5, Trek Rumblefish Pro, Trek Remedy 9.9, Trek Equinox7, Trek District Belt
Quoted: 578 Post(s)
Liked 82 Times
Should have went with a set of German MEILENSTEIN OBERMAYER LIGHTWEIGHT SCHWARZ Edition Wheels as they are lighter then what he has on there by almost 100 Grams for the set..
Trek Fuel EX9.0 Trek Fuel EX9.5 Trek Equinox 9.9SSL TTX Trek Madone 6.9 Pro Red Project One, Trek Boone 7, Trek Rumblefish Pro, Trek Remedy 9.9, Trek Carbon District
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Head over to Weight Weenies and look at the lightweight threads.
Lots of guys are building 9 lb bikes and putting big miles on them.
Gunter Mai was probably started the whole uber-light movement put 20k miles on a 3.2 kg bike.
-Tim-
-Tim-
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4394 Post(s)
Liked 3,017 Times
Quoted: 578 Post(s)
Liked 82 Times
Likes For waters60:
Used TESA tape for bar tape...I can't see that stuff having much cushion at all. It's usually used to loom up wire harnesses in cars. GM likes to use it a lot. Just enough fuzziness to keep stuff from rattling under the dash. It's fairly tough but I can see the fuzz/softness of it coming off on your hands in fairly short order.
Señor Blues
Liked 3,017 Times
Quoted: 7653 Post(s)
Liked 3,485 Times
"Hang on tight going downhill." A little noodly, perhaps?
I am glad they didn't list the prices for all those parts. he probably pays more for bolts than I spent on my group set.
Rhapsodic Laviathan
I actually wouldn't mind some carbon fiber bolts for a few grames off my denali build, that actually needs it. Still thinking if I should repaint or not after I strip off the super thick single stage paint.
Rhapsodic Laviathan
Rhapsodic Laviathan
Rhapsodic Laviathan
Quoted: 18430 Post(s)
Liked 15,585 Times
Make that two.
BTW...Are you aware that Buddy Ebsen was originally cast as the Tin Man? Shortly after filming began he developed severe respiratory problems from the aluminum powder used in his makeup. He nearly died. He was quietly replaced with Jack Haley and the makeup changed.
