Power Meter Better than Heart Rate for On Road Zone 2 Training?
I'm on a training program whereby I need to stay strictly within Zone 2. This is a piece of cake on my Wahoo Kickr where I have both heartrate and power data. That said, it's summer and I would also like to train outside.
Outside, 90% of my riding is on an awesome, multi use path around a reservoir right outside the door of my house. As awesome as the ride is, I struggle to stay in zone two based on my heartrate alone. It's a lot of acceleration and deceleration as opposed to a steady grind which, frankly, makes the ride fun. I don't yet have power on my outdoor bike but, as of now, I'm considering it.
Does power tracking make it easier to stay in zone two on outdoor rides? I consider heart rate to be the gold standard of Zone 2 determination but, at the same time, heart rate tends to be laggy in a way that power is not. Can anyone confirm or refute my assumption that it would be easier to train in Zone 2 with a power meter? The power meter will be a big investment but, if it gets me doing Zone 2 reliably outdoors, I'm in.
Habitual User
Quoted: 4957 Post(s)
Liked 8,098 Times
If you're riding on terrain where it's difficult to maintain a constant effort, staying in a specific training zone is going to be difficult, regardless of how you are monitoring your effort. That said, a power meter might be helpful in limiting the efforts that push your HR above your target zone. Learning how different effort levels feel in your body is an important piece of the puzzle, too. For me, on the road, I tend to pay attention to HR more than power.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
No. HR better, breathing even better than HR. Power in Z2 will vary by Z2 training volume, HR will vary less, breathing won't vary. Basically, it's the exertion level below the point where your deep breathing rate begins to increase.
Unfortunately it's actually more complicated than that. The way most zone calculators delineate Z2 is somewhat random. Here's a discussion of how to find your Z2 levels: Note that a power meter won't help unless you've been to the lab.
https://peterattiamd.com/how-to-find...lactate-meter/
One should also mention that there are two internationally used systems for numbering zones. In the US, most people use a 5-7 zone system where "Z2" is the zone in which the OP is interested. In Europe, many people use a 3 zone system, where the upper limit of Z1 is located at the upper limit of the US Z2.
Results matter
Results matter
Likes For Carbonfiberboy:
Yeah, the Attia stuff is what my current plan is based on really.
Breathing, sadly, isn't of much use to me. It's my nature to underestimate my level of effort so I really need something more objective.
I disagree that a power meter would not help. What I've done indoors is calibrated my zone two based on heartrate and breathing and then worked out wattage based programs that gets me to those targets consistently. That's been working wonderfully. My hypothesis is that I ought to be able to enforce wattage outdoors in real-time and use that as a way to achieve my target heart rates +/-. That, acknowledging that all manner of outdoor "stuff" will tend to affect my heartrate in ways not present in the indoor situation. Following my heartrate seems too see-saw-ish so far. I'm always high or low for a variety of reasons and often feel as though I'm reacting inappropriately because of the lag. I'm hoping that using power instead will have a flywheel effect of sorts so that I can ride a bit more smoothly.
Similar to what I do indoors, I'd like to ride based on power, check out the heartrate implications when I get home, and then adjust my power targets accordingly.
Habitual User
Liked 8,098 Times
Liked 1,938 Times
Yes, power will help you to smooth things out, however its average will vary with training and training state. It does take a lot of practice to corral all three measurements and keep them in some relation to one another.
Using power outdoors drives me a bit nuts because of the large variations even on the "flat" which is never actually flat. I've found the most important thing is to keep one's cadence even, let power vary as it will within limits, while holding breathing even and HR also within certain limits. It takes a while for power levels to affect fat usage and lactate levels. Breathing rate however is quite closely related to metabolism as is HR.
Indoors is a completely different condition where holding power steady works perfectly.
Results matter
Results matter
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
I use both a heart monitor and power meter, and I roughly know the power levels that keep me with zone 2 heart rate. If I look down and see power above that range, I know to back off a bit.
But I don't do strict "must stay in zone 2" rides, as I don't see the value of being that regimented. "All roads lead to Rome".
Thank you, all, for your input. Data points...
Clearly, not having yet ridden outdoors with power, my impression of its awesomeness needs some tempering. Anybody wanna mail me their power pedals to demo for a week?!?
That speaks well to how I've been envisioning using a power meter. When I ride the route that I ride, all manner of "events" cause my heartrate to jump temporarily. When that happens, it can easily take a minute or more for my heart rate to come back down. Sometimes as long as five minutes. During that time, which feels like hours:
1) I'm flying a bit blind as to whether I'm expending the right amount of effort and;
2) Another "event" may well take place. Bunny hopping a dachshund, passing a group, or whatever.
On the other hand, I would think that I could correct power surges on timelines closer to five to ten seconds and then just trust that my heart rate will come back down to a level commensurate with the power based on historical performance.
Inugo San Millan's data backed theory is that, once you leave zone 2 for an appreciable stretch, it can take a long time to get back to it because you've triggered metabolic events which don't switch off easily. So once you leave zone two in the context of a 60-90 minute ride, that's the end of your zone 2. Having begun to drink from the fire hose of glycolytic energy, it takes some doing to convince your body to go back to gnawing away at the fat stores.
The stakes with this are abnormally high for me. I'm an unmedicated, lean type 2 diabetic which means, among other things, that I don't have many levers to pull with respect to keeping myself in remission. I'm banking on the strict zone 2 training -- to the tune of 6+ HRS / week -- to yield the mitochondrial improvements that I need rather desperately. In San Millan I trust... for now.
climber has-been
Liked 3,567 Times
I wouldn’t put much confidence in that theory. Exercise physiologist Andy Coggan said there is no scientific evidence to support it.
Quoted: 2333 Post(s)
Liked 2,097 Times
To stay within "zone 2", this is what I have found.
Lactate>Power>breathing>Hr
I like to amuse myself with guessing my power output by feel in my legs and surprisingly, I can guess pretty closely what my 3s Pwr is reading on the Garmin. Breathing also works for me. I cannot tell what my HR is and it lags for physiolofical reasons beyond what I want to write. My lactate levels do not correlate well with the 5 or 7 zone models and they vary tremendously by the type of training plan and level of fitness. The Maffetone HR method is about as good as any in terms of keeping you to that lower aerobic level for your metabolic training needs. It works for me especially if I keep the efforts down on hills. If you are good with math in your head, you can calculate your power while riding hills knowing the gradient, the speed, and your weight.
https://philmaffetone.com/180-formula/
Bikes: Shmikes
Quoted: 10175 Post(s)
Liked 5,871 Times
Unpopular opinion: Pay attention to power, HR, and perceived effort on the trainer and then use RPE once you are calibrated. As the coaches say, “if it feels hard, it is hard” and the real physiological stress induced by a given chunk of power x time varies from day to day according to your baseline state.
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 569 Post(s)
Liked 772 Times
I don't think Z2 is your only lever - I do ride at lower intensities most of the time, but I also incorporate blocks of high intensity training over the winter or to "tune up" in the summer. I also pick days to just let it rip, Z3/Z4 rides just for the sake of speed and blowing off some steam.
I pull all the levers from time to time, with no difference in BG's or A1C - in fact, the fitter I get from all training, the better the numbers.
As said above, maintaining tight Z2 power levels on the road is a crap shoot. Even on the "flat" bike path I frequent, 2-3' changes in elevation, up and down slight grade changes you may never even notice, can have big effects on power. Then you have hills, accelerations from stop signs or unintended accelerations... very difficult to use power for Z2.
Even Z4 efforts on my flat path are difficult to keep in range. I'm getting better at maintaining a 20+/-w window, but sometimes you will look down and you are 80w low on a downward grade that you can't even feel, followed by a 100w high on a slight rise.
Likes For Jughed:
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
Plus, indoors you can get away with constantly monitoring HR and power but outdoors you should probably be paying more attention to traffic, dogs, and potholes rather than staring at your head unit to micro-manage power. Using power to "steer" HR is sort of like driving in reverse where you're using the front wheels to steer the rear of the car. You can do it but it either requires that you do it at slow speed or that you have had a lot of practice.
Likes For RChung:
Bikes: Shmikes
Liked 5,871 Times
Liked 1,938 Times
Yes, it's just way easier to ride outside than in. Outside, I hardly notice my legs while riding at the same average power indoors my legs start to hurt much earlier. I think outdoors we get more power variation, meaning that we get little rests which make all the difference. So maybe on a 6 hour ride I have an average HR of 118. If I sat on my rollers for 6 hours at a steady 118 . . . well, impossible. I couldn't do it. And there are all those photos of Froome staring at his head unit. Don't do that. I have a riding buddy who rode into the back of a parked SUV and was injured. The SUV was fine.
Results matter
Results matter
Liked 2,097 Times
I can do a higher NP outdoors but a higher average power indoors (with a huge blower cooling me) although I don't like riding indoors at all. It is worse than cleaning the bike after two back to back rain days.
Likes For GhostRider62:
Bikes: Shmikes
Liked 5,871 Times
Quoted: 4415 Post(s)
Liked 4,867 Times
I find power very useful for calibrating my efforts outside, especially on steady climbs and TT efforts. But staying strictly at Z2 power outdoors really requires a very flat route. My local routes simply do not allow it, regardless of what I measure. Technically I could probably do it by crawling up every climb and pushing more on the descents to keep power in range, but it just isn't fun riding like that and a very inefficient way to cover miles (if you get into the habit of riding like that).
So what I do for Z2 outdoor training rides is ride on RPE and keep an eye on my HR and Power on the steady parts of a climb or flat. Without a PM it is very easy to over-cook your power at the start of a ride, particularly on the climbs. I see this all the time with my riding buddies who don't have a power meter. They shoot off up the first climb we hit and ask why I'm holding back. Then I tell them what power we are putting out and they are surprised. For me that's the value of a PM for outdoor rides. It just calibrates your efforts during the course of a ride, from when you are fresh, through to being more fatigued at the end.
Likes For PeteHski:
Version 7.0
Bikes: Too Many
Quoted: 1340 Post(s)
Liked 2,482 Times
With respect to perceived level of effort and difficulty...Trainer > track (fixed gear) > road. I use the road as the base case and derate workouts from there depending on training modality.
I like power levels and RPE as well as the conversation test for riding in z2. I look at HR but my HR can be lower after a harder previous day or vary for a number of reasons that have little to do with the training objective. If I use the San Millan conversation test then my HR will be higher and more like z3 as per Coggan.
Gold standard. Do the ride. My gold standard standard is make every pedal stroke count.
Quoted: 528 Post(s)
Liked 230 Times
Quoted: 528 Post(s)
Liked 230 Times
1) I hold my cadence between 65 BPM and 70 BPM rather than my usual 85 BPM - 95 BPM range.
2) I hold my pedal force to the level that I seem to naturally gravitate towards when optimizing pedal efficiency. Pushing comfortably but not mashing per se.
It's basically a version of this I think:
That said, a power meter might help me perfect my method even more if it could display pedal force instead of power. Is that possible? I would assume that force is the fundamental variable that power meters actually track so whether or not that is available is probably just a matter of how things are set up for display purposes.
I'm torn as to whether or not I'm happy to know about the Coggan stuff. Rationally, this is where my head's currently at:
1) There's a pretty good change that all roads do lead to Rome as you and Coggan say but;
2) The zone two road almost certainly leads to Rome.
Given how badly I want to get to Rome, it make logical sense for me to stick with Z2. So, while it's a relief to feel that I can probably be less strict about zone two, it's annoying to know that I could probably -- but not certainly -- ditch zone two altogether and just go back to to the hell for leather 20 minute all out efforts that I enjoy much more than Z2.
