Workout drinks
Workout drinks
Hi guys my wife and I recently purchased an echelon ex-5 spin bike. We were wondering if there is any special type of drink or shake or anything to do pre, during and post workout? We drink lots of water but just want to see if anything else is recommend? Thanks guys
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,599 Times
Thread moved from Introductions to Training & Nutrition.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
You've pretty unlikely to need anything other than water for shorter durations. Something like gatorade or powerade or even some juice is fine if you feel like you need extra calories. On long, hard rides I used half a bottle of water, half a bottle of cranberry or grape juice, and a few spoonfuls of brown sugar. Cheap, effective, tasty enough.
But damn, I'd for sure say don't do anything with milk on the bike. That's just an awful idea all the way around.
Quoted: 6193 Post(s)
Liked 4,810 Times
How long do you ride them at a time and how intense?
If you don't ride but <2 hours you don't have to have anything. Though if you are riding < 2 hours at very intense efforts, some carbs while you are riding will probably help with how you feel afterward.
IMO, consuming proteins and fats won't do much for you while riding, though a little protein sometimes helps make the carb mix taste or feel smoother going down...... assuming you put them in your water bottles.
If you ride more than about 2 hours at high intensity efforts or with intervals of high intensity, you should probably use carbs in some form, in bottles or eats, every ten of fifteen minutes from the start of your exercise. If you are consuming a lot of water, you might need to make certain you get some electrolytes. But don't get the idea if a little is good a lot is better. It's not.
It doesn't take much carbs though. Too many and you might feel bloated or just not perform well. Try and find what works for you. 100 Calories per hour might be a good start. 200 Calories per hour is way high for me. Typically I consume 120 to 150 per hour. But I'm only riding on the road. I don't do indoor training.
I'm not an expert though. This is just my understanding from what I've read and what I have done for many years.
Bikes: Shmikes
Quoted: 10169 Post(s)
Liked 5,862 Times
Milk has some carbs, fat, and protein, but only a very small amount of sodium, which is the only electrolyte that needs to be replenished during exercise of non-extreme duration. Not an optimal choice for an exercise drink.
Likes For MoAlpha:
Bikes: Shmikes
Liked 5,862 Times
Milk also goes very bad, very fast, in the heat. Blecch. :Þ
Likes For MoAlpha:
Quoted: 2952 Post(s)
Liked 3,106 Times
But yeah, if it's less than an hour, all you need is water.
Likes For caloso:
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
This is probably too much data for you...........but......just so you don't wind up drinking too many calories........
-at a pretty raucous 277w for a whole hour you'd burn 1000KJ (raucous for a beginner or low level amateur)
-your body typically is topped with 400-700 g of glycogen (liver plus muscle), this at 4.2KJ/g equates to about 2000KJ work using just glycogen assuming starting at 500g
-meaning you'd have to ride at 277w for just over 2 hours to deplete your body's starting glycogen
I would say if you're starting out and likely doing an hour or less, simply be sure to have your last full meal about 2 hours before. Then, a small snack with light carb some 30min before. Water on the bike. If you really need electrolyte for indoors heat, look into Nuun tablets. Those are electrolyte without adding unneeded calories. Then off the bike at end, sip some water and maybe have a small snack.
For what you're after I would:
-eat standard meal at least 2hrs before
-hydrate normally before during day
-small snack with a little carb before workout (maybe a Kid's Cliff Z-bar, lower calorie and carb, but has something)
-Nuun tablet in your water for the ride
-hydrate after, maybe a light snack to stave off cravings later
By all means, don't go for the carb amounts in many full strength sports drinks or "race day" drinks.
Good luck!
Good luck!
Likes For burnthesheep:
Quoted: 347 Post(s)
Liked 418 Times
Cold water - maybe with a little salt, sugar and vinegar for a hard workout.
Cold beer - Nature’s perfect post workout drink.
Quoted: 4227 Post(s)
Liked 2,488 Times
If your body is well fed then you don't need any pre-workout drinks...During you workout all you need is water...You also don't need any special ;post-workout drinks. The best thing after a hard workout is to eat some "real food" and drink a beer.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Good luck!
Good luck!
Then I add in workouts, 6 days/week, week after week, totaling only ~3Mj/week, but guess what happened? After a couple weeks at that level, I couldn't do it anymore. I wasn't overtrained, felt fine, slept well, it was just that the pedals felt heavy and I didn't have any endurance. Obviously enough, that works for one ride, but not for a lifestyle unless you're going to start counting calories or increasing the size of every meal recipe to suit whether or not you're working out that day and how many calories you expect to burn. For me, that's insanely complicated. My wife cooks a big pot of something and we eat it for 2-4 days, not consecutively of course because we eat different food every day, but spread out over the week and planned ahead for for 2 weeks, partly because Covid, and partly because that's how we've done it for decades.
The by far more rational approach is to simply add calories to each day according to the energy expenditure or some approximation to that, and mostly carbs with a some protein. We've gone back to doing what we've always done successfully: we have a startup drink and a recovery drink every day we work out. The startup drink is always the same, but the recovery drink varies in carb calories depending on the workout. No more problems, steady energy every day, very slow weight loss, no more dropping by a pound the next day.
Chris Carmichael is full of it, that one has to put out 1700 kj before one deserves a recovery drink, much less a startup. Sure, once a week one can do that fine, but do that every day and you're going down the drain and real fast. It doesn't work, not even at my miserably low power output unless all you do is work out and plan and create meals.
Results matter
Results matter
Quoted: 1186 Post(s)
Liked 289 Times
That's all good, as far as it goes. I see folks here saying, oh, you don't need pre or post, or even during fuel for most workouts, because your ordinary diet will supply the carbs and calories. But think about that for a minute. I have a daily diet which keeps me within a pound of the same weight week after week. The food is different every day, all 3 meals, my wife likes it that way and it's fine with me. She cycles through about 400 different dinner recipes.
Pre-Covid I used to commute about 60km day. Mon to Fri I would burn an extra 1400kJ/day so I naturally just ate more frequently. I couldn’t (or didn’t want to) eat that much extra during or immediately after the rides but had no problem eating more frequently during the day. I couldn’t make it to lunch without a mid morning snack and usually had something mid afternoon as well. These days I ride inside at the end of the day, maybe 700-1000kJ. I’m consistent and end up eating more during normal meals and snacks so I don’t go to bed too hungry. I just have water on the bike and prefer real food to sugar drinks. Longer rides on the weekend I’ll eat and drink on the ride but it doesn’t come anywhere close to replacing the calories burned while riding.
if you exercise consistently, it’s not difficult to eat enough during the day to compensate for your normal exercise routine. It might get a little more complicated if you exercise less frequently or only occasionally but in those cases it also doesn’t matter as much if you don’t compensate for every calorie burned while riding.
I think I know nothing.
Quoted: 233 Post(s)
Liked 290 Times
I ask because when I started riding bikes 2 years ago I wanted to get in better shape although I wasn't a basket case and not really to lose weight either. But as things have progressed I have added fitness goals and started paying attention to things like diet and hydration. For me, an interest in hydration and electrolyte replacement is more out of necessity because I was getting leg cramps galore.
Newbie racer
Liked 1,569 Times
It's directed at folks starting out who think they need a bunch of nutrition to go do a 250KJ or 300KJ workout. The work load needs to be at least as great as the nutrition one used to fuel the work! If you down 300 calories of sport drink before and after a 250KJ workout..........yeah.......no bueno.
When the workout was 35min and you only burned 200KJ...............yeah, I really really hope you're not compensating for that with a bunch of extra calories. A single drink or bar probably totals 200KJ.
If I had to put it more bluntly: fuel like an athlete if you're training like an athlete...........don't fuel like one if you're not.
If a person is confused about whether they fall into "fitness" or "athlete" territory for that.............one major difference is having very specific performance goals. It's not a specific performance goal to just say "I'm going to ride my bike more" or "I want to lose a couple pounds". Specific is "I want to reach X.X w/kg for that mountain fondo" or "I want to hit 300w for 20min" or "I want to break 25min for a 5k run". Or, I want to achieve the Then, the nutrition is specifically meant to meet the demands of workouts that challenge the body to meet those goals.
It is my opinion that from a profit and marketing perspective, companies have intentionally blurred the line between the noble pursuit of general fitness...........and athletics. In order to sell more stuff.
There's a bargain basement level of KJ expenditure in an hour to necessitate that kind of nutrition. And it isn't 200 KJ in 30min of spinning.
Bikes: bikes
Liked 1,429 Times
Your body has plenty of minerals; however the body can protest in various ways in unfavorable or unfamiliar conditions.
Likes For rubiksoval:
Newbie racer
Liked 1,569 Times
They wind up either injuring themselves or getting horrible cramps and issues.
And........that would have zero to do with whether you ate or drank enough. No, the body doth protest the beating you just gave it!
Bikes: Shmikes
Liked 5,862 Times
Studies in trained athletes have not found an association between cramping and serum electrolyte levels. The most popular current theory is overactive signaling in the stretch reflex circuit between the muscle and spinal segment due to some fatigue related factor.
Likes For MoAlpha:
Liked 1,938 Times
Allow me to qualify that....
Results matter
Results matter
Likes For Carbonfiberboy:
Liked 1,938 Times
If you exercise consistently there isn’t really any more planning involved than what you do for your baseline 3 meals/day. How did you decide how much to eat for each meal? Like most, you likely arrived at reasonable portions based on your natural hunger and satiation levels. If you’re consistent with exercise those meals, or the number of them, would get bigger or more frequent to compensate. You don’t need to get out the scales and weigh every gram of food if you weren’t already doing that for your baseline.
I remember a reporter once asked Lance how he knew how many calories he was taking in. His reply: "It says right on the box!" I think a lot of people are like me and don't live in that world. I have no idea how many calories or grams of carb are in my 3 meals diet and I'm not going to waste my time calculating it every day. I log my kj and drink calories to replace 1/2 of that. Takes 3 minutes, works perfectly, no stress on the family, and no change in portion sizes, thus no increase in hunger. Otherwise, we eat a Med natural foods diet and have done for 47 years. I have no interest in taking control of that, no no.
I had an employee who started bike commuting 5 days/week. It was 16 miles each way and rather hilly, He was a strong guy anyway, didn't bother him, except that in his second week he said he had to give it up, it was making him too tired. I taught him about recovery drinks, one here, one at home. He started doing that, never had another problem.
Results matter
Results matter
Liked 4,810 Times
Durn, I don't know if I can read a novel's worth of information every day guys <grin>
Likes For Iride01:
Liked 3,106 Times
Likes For caloso:
Thread Killer
Quoted: 3144 Post(s)
Liked 1,708 Times
My favorite drink tool is PureClean Performance’s Fundaminos: https://purecleanperformance.com/pages/fundaminos. A glass first thing in the morning on workout days, and a second glass post-workout if it was a big one. I do structured, power-based training with ride workouts usually lasting an hour. I just use water for those mostly, but when I have to do gnarly L6 and L7 intervals, I will mix in a little Hammer HEED, which is what I use in one of my bottles when on the road for long, hard rides of +2hrs.
If you’re just starting to cycle, to workout, and to train, I think the advice given to simply stick with water for now is the best advice, because the extra activity will have the greatest impact on your body and get you’re exercise development going on the right track. As I said, I’d bet you’ll know when you’re reaching the limits of what you can do, and that’s the time to start with supplements, both physically, but also strategically, as you’ll have a better sense of where you want to go and what you’ll need to get there.
Good luck!
Bikes: Shmikes
Liked 5,862 Times
Liked 289 Times
It was actually 3 pinches of salt in the 750 mL bottle. Tasted less salty than my sweat so I guess I'm simply putting the right amount back into my system. It got into my throat perfectly smooth, unlike water or milk without salt but then I craved for more. So I thought that's interesting.
Liked 4,810 Times
Salt is an electrolyte. I used to put a pinch or two in my bottles when I was using diluted fruit juice in my bottles. I typically use more electrolytes in very hot temps and way few if any during cold whether.
As for drinking milk, I used to think it disgusting too and thought it would immediately sour in my stomach and I'd vomit it up quick. However I actually tried a bottle of chocolate milk given out at the end of an organized ride by a sponsor, and surprisingly it was refreshing with no issues. For a recovery drink, chocolate milk's nutrition breakdown holds up well compared to most other recovery drinks.
For using it while on the bike? Well I think he says he uses a dilute mix. So maybe not so much unlike the drink mixes for use on the bike that have protein in them.
