What should I do to this bike?
Just got what seems like a great deal on a Fuji Cross that I plan to use as a road / commuter and possibly light trail bike. It's in great shape, was only $200 and has tons of upgraded (or at least aftermarket) parts:
- Dura ace rear derailleur/cassette
- FSA front derailleur / cassette (Gossamer?)
- Mavic open pro wheelset with ultegra hubs
- Terry falcon x saddle with carbon seatpost
- Cat eye strada cadence computer
- Look keo pedals
- Shimano front brakes (not sure type)
- TRP CX 8.4 linear pull rear brakes
- Ritchey bars with new tape
- Specialized stem
- Some unbranded carbon headset and matching unbranded carbon forks
It's kind of a Frankenbike! But beats the hell out of a stock Fuji Cross, especially for $200!!!
Main questions, any changes, additions or tweaks you'd recommend?
Should I get front brakes (shimano) to match the rear brakes (TRP CX 8.4)....if so, which one to go with?
Should I replace front FSA derailleur / cassette with dura ace to match rear? I'm kinda thinking only this one and leave the rest.
Or should I just leave it entirely as is and not mess with it if it ain't broke? I'm kind of a n00b so any and all advice is greatly appreciated! Thanks!
Unfortunately it won't let me post pics cause I have less than 10 posts. Lame.
WORK AROUND, shared google photos folder: http$$$:// (DELETE THIS) photos.app.goo.gl/kf52XX6enhzTcrhp7
- Look keo pedals
- Specialized stem
Quoted: 2604 Post(s)
Liked 1,933 Times
What to do with it? How about ride the fool out of it?
Quoted: 2952 Post(s)
Liked 3,106 Times
I wouldn’t do anything to it. Sounds like a classic CX parts-bin build.
Liked 3,106 Times
Actually, now that I think about it, I’d get a second wheel set so you can have one set for dirt/gravel and one set for pavement.
I checked the chain today, it's good. Wheel hubs look flat. Going to clean it up (looks like it's been used for CX) and give it a test ride.
Might replace cables if shifting seems funky, otherwise I'll wait til next tune up.
A couple folks recommended replacing the front forks so I can fit matching brakes on the front and fit larger tires. This might be cool if I get more into gravel or rougher trail riding, but I'll probably hold off for now as it'll be mostly road and only light, well manicured wimpy trails.
I may keep an eye out for a dura ace front group to match the rear.....the FSA is the only thing I'm a little hesitant about. Any time I've strayed from Shimano in the past I've regretted it (although have never had Campy).
Thanks again fellas! Great advice! Gunna clean out the dirt and gunk and go for a ride now!
Liked 3,106 Times
The good news is that you can pick up some great deals on rim brake wheels these days, particularly if you don't need 11-speed compatible hubs.
That's a good point! I'm fine with rim brakes. As far as hubs, I'd prefer to get a drop-in replacement, so I guess I'm looking for a rear wheel with a 9 speed shimano cassette with appropriate spacing to fit dropouts? I could buy the wheel, hub, cassette all separate and built it, but I'd prefer to just by one or a set of two ready to drop in.
Quoted: 2495 Post(s)
Liked 738 Times
What year bike is it? Newer ones do not have bosses for v-brakes. Still ... $200?? Carbon fork? It would be absolutely irresponsible to "ride the fool" out of that bike without properly paid up life insurance. As for "upgrades"? None. Even a fork swap (plus labor) puts you in the price range of my bike and mine is new. And I wouldn't touch the tires unless you don't mind being smoked by young women on fixies on your favorite road course.
Bike is an '03. I carefully inspected carbon forks and did a tap test. I know you can never tell for sure but the forks seem fine.
I found a custom Carl Strong steel fork w/ v-brake mounts for $100 on craigslist....brand new, never installed. I'm thinking about offering $70 or $80. I can do the labor myself....adding brakes wouldn't be too tough.
But really I don't think I need larger tires...I'm not doing CX....mostly road commuting and possibly occasional "off road" light, well-manicured trails. So if I don't need bigger tires, no point in getting another fork, brakes, etc.
I think I'm just going to ride it as is for now (I'll check the forks again)....maybe keep an eye out for matching DA 7800 front components and another set of wheels so I can have one for larger trail tires and another for tiny road tires. But I'm not gunna go crazy and dump a bunch of time and money into a modest commuter bike. $200 is a great deal for what it is....if I start dumping a buncha $ into it, it kinda defeats the purpose of buying a cheapie for commuting that I don't need to stress too hard about getting stolen.
Quoted: 18378 Post(s)
Liked 4,512 Times
Liked 4,512 Times
It looks like an interesting bike. Not real expensive. But, quite "flashy". Get a good lock for it if you're doing commuting.
At one time it would have had front and rear canti brakes, which were replaced by linear pull V-Brakes in the rear, and simple older dual pivot brakes in the front.
If everything works right and satisfies your needs, then just use it as-is.
New tires when you eventually need them.
Liked 3,106 Times
It is a little weird that it has a caliper brake fork. Not really an issue if you're riding gravel or racing cross on a dry course, but add a little mud and things get sticky. Literally.
Liked 3,106 Times
Just seems odd to stick a road fork on a CX frame, especially when the calipers will limit the tire sizes that can fit. It might also change the handling since CX forks seem to be slacker than road forks, in general.
Liked 738 Times
I realize that. I have a CX bike of that vintage. There are a handful of us still racing cantilevers rather than discs, but our numbers are dwindling.
Well that's perfect because I won't be doing CX, and it'll mostly be a road/commuter. I like the CX frame geometry because it's a bit more upright and I have a very bad back (several herniated discs). If I wanted to do light, nicely manicured wimpy trails, what's the biggest/best tire I could fit between those front brakes? And would I need wider rims for such a thing? Again, doesn't need to be an all out downhill mountain bike tire....just some light offroad duty.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I don't think you can fit any larger tires on the front than you have now. Maybe if those are 26c you could try 28, but it looks pretty tight.
Liked 738 Times
