View Poll Results: Keep dork disc or remove it
Voters: 128. You may not vote on this poll
Dork disc
#51
I know you know this, but it’s not “when” you dump the chain into the spokes, it’s “if”, and it’s only going to happen if the limit screw is set incorrectly and/or the RD hanger is bent inwards accidentally. A normal, properly adjusted bike doesn’t dump the chain off the big cog. People manage to get tens/hundreds of thousands of miles out of their frames without a catastrophic chain drop.
If I have a disc the right size, I'll keep it. This is coming from someone who saw the advantage when my mountain bike derailleur got out of alignment after a fall. I don't like them when they are oversized or broken and will seek a replacement.
#52
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
Needing a helmet is also an "if", but do you wear one? Plus, to the average person, a helmet or lycra is a lot more dorky than a plastic spoke protector.
Shifting into the spokes only happens when your RD is improperly adjusted or the hanger is bent. If I crash on the right side, I replace the hanger if bent and check the limit screws. Plus, unlike the consequences of getting it wrong when not wearing a helmet, the worst that can happen with no dork disk is jamming your chain and having to replace some spokes. That's better than a skull fracture.
#53
Bad comparison. Crashes can happen on any ride and are usually out of your control (other riders, cars, weather, bad roads, whatever). The helmet could save your life. I know it's saved me on a few occasions, or at least prevented more serious injuries.
I'm just a bigger dork than you with my dork disc and helmet.
#55
Quoted: 17 Post(s)
I forgot about the old steel ones.
It got me thinking... Are there custom dork discs? Dork disc or wheel cover, something shiny and blingy. Gold-colored, intricate patterns, LED lights, whatever. I would actually buy some wheel bling, whether it's a dork disc or wheel cover. No, not something professional and cool looking like those TT discs. No, something gaudy and flashy. I want the bicycle equivalent of hub cabs and beauty rims.
#56
Serious Cyclist
Bikes: Emonda SL6
Liked 261 Times
The bike barely fell over and I didn't think to check the dérailleur with such a minor fall. The worse that can happen is losing control of the bike and crashing. However, I would agree that this is not likely to happen as you aren't going full speed if you are shifting into the largest cog.
#57
Bikes: Shmikes
Quoted: 10170 Post(s)
Liked 5,863 Times
Likes For Deal4Fuji:
#59
Bikes: Trek Domane SL5
Quoted: 25 Post(s)
Liked 41 Times
Came back from a ride this morning and rays of sunshine were glistening off the cassette. Then I noticed the dork. I knew immediately, and the dork knew, this was his last roll. Snip, snip, snip and it was gone. In my view the cassette area is a fine work of engineering and machining that doesn’t deserve to be tainted by this piece of plastic. By most accounts it will likely weather and eventually break off anyway.
Thanks for the input. Point well taken to ensure the RD is properly adjusted.
Likes For Fendertele:
#60
Quoted: 941 Post(s)
Liked 319 Times
#61
What is accomplished by removing it, other than it being gone?
#62
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4390 Post(s)
Liked 3,016 Times
This does not address the wisdom of having a dork disc, but just sayin - none of the many regulars on my group rides has one, and if some new person shows up with one, I silently assume that this is a person without a lot of road experience, and I keep my distance from them in the pace line.
#63
Quoted: 18415 Post(s)
Liked 15,553 Times
#64
Bikes: Shmikes
Liked 5,863 Times
If I "ran" a dork disk, it would function like one of those animal secondary sex characteristics, like the peacock's tail, which serve no purpose other than attraction, actually detract from purely physical fitness, and signify a surfeit of vitality and coolness simply by their awkwardness.
Likes For MoAlpha:
#66
Bikes: Shmikes
Liked 5,863 Times
#68
Bikes: my precious steel boys
Quoted: 438 Post(s)
Liked 603 Times
weren't kickstands mostly removed/replaced with centerstands because the "traditional" placement of them could cause frame damage if people sat or leaned on the bike with the stand engaged? IIRC it caused stress to be put on the frame in a way it wasn't designed to handle
#69
Quoted: 1324 Post(s)
Liked 927 Times
The so called dork disc is like an insurance policy = you hope you never need t but if you do you're really glad you had it. If a chain for whatever reason goes past the largest cog then a "dork disc" saves the spokes from being gouged and then later breaking.
Cheers
Cheers
#70
Bikes: J.C. Higgins Freightliner built between 1958-1963, 1985 Mongoose City Bike, Sear & Roebucks Ted Williams Signature Series Free Spirit mid 70s, 2005 Schwinn Stingray Stealth
Quoted: 18 Post(s)
Liked 11 Times
#73
I've also had the chain jump the small cog, and on my bike the spacing there is perfect for the chain to jam there too, and I don't have quick releases for an easy unjam (by choice, an urban bike, I use nut axles for slightly improved anti-theft, but mostly because adjusting the wheel bearings is so much easier and bearing preload stays more consistent). So I've pondered if there is a cluster lockring that is thicker or has a step to prevent that. I thought of putting a spacer behind the cluster, even bought one, but that greatly reduced lockring thread engagement to a point that I thought compromised things, so I didn't go through with it.
#74
Yeah, that's what I thought. UNTIL I did a bit too fast of a shift to low while climbing a hill and the chain jumped over the big cog and JAMMED between it and the spokes. Tore up the spokes, source of subsequent spoke failures, all on the drive side so impossible to replace on the road. Now, I have dork discs on all of my bikes. I favor plastic, and just big enough in diameter to do the job. Not big enough to prevent a super bent long cage derailleur from getting in the spokes, more of a chain guide in case the chain jumps the big cog.
#75
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I've never seen the disc on GC or sprinter's bike so are you saying you shift faster than they do?
