Air Chuck for Presta Valves
Can anyone point me to where I can buy a simple air chuck for Presta valves similar to the one pictured here that's used for Shrader valves?
Likes For cloud:
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
Or buy the little brass adaptor (most LBS's should have them) for $1 and use your regular gauge/chuck.
Likes For bOsscO:
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
For general inflation or just to seat tubeless beads? I remove the presta core and inflate with the shrader head to seat the beads. Then allow it to air back down, insert sealant and inflate to proper pressure with a pump.
Liked 2,981 Times
simple answer, no. Cheaper to spend an extra minute screwing on the adapter & using the car valve inflator. I've looked for a simple economical solution & nothing was available that made logical sense.
-Oh Hey!
-Oh Hey!
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Be carefull that you compressor doesn't burst your tube.
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
The SKS Presta adapter is a very good choice. It’s far cheaper than a Silca chuck ($8 vs >$35) and it works with a Schrader compressor head. We use them at my co-op all the time. You don’t even have to order them on line if you don’t want to. Quality Bicycle Products carries them and your local shop can order them.
Stuart Black
Stuart Black
I’ve used prestaflate (one without the gauge) for the last few years. I only use it for seating tubeless mtb tires and finding holes in tubes to patch. Easily the best $35 I’ve ever spent. No issues seating any Mtb tires far better than the adapters.
Thanks for all the great suggestions. Among them, I will find the solution best for me.
Quoted: 1572 Post(s)
Liked 643 Times
I recently made the decision to convert to Schrader valves over this winter for that very reason.
Likes For Retro Grouch:
Quoted: 1821 Post(s)
Liked 1,697 Times
Cyclus tube inflator:
https://www.bike24.com/p2277205.html
Liked 2,981 Times
who the retailer for that in the USA?
-Oh Hey!
-Oh Hey!
Bikes: 1986 Cannondale SR600
Quoted: 20 Post(s)
Liked 7 Times
A moot point for me though: this was only an issue 30 years ago until I chopped the schrader head off my floor pump and put a Silca 24.4 chuck in its place.
bOsscO
Quoted: 296 Post(s)
Liked 355 Times
I see these all the time, but have never, ever, been satisfied with any that I've tried. They always leak on me! I don't know whether people just accept the leaking, or if all the ones I've tried have been inferior quality, but then I haven't seen anything to distinguish better quality ones.
I generally only use them to inflate the tire and take it off (and screw down the Presta valve closed) when I reach the desired pressure.
Likes For bOsscO:
Quoted: 20 Post(s)
Liked 7 Times
If I did want to switch over to a Schrader interface for inflating, I'd be tempted to get removeable-core presta tubes and a pair of ConvertAir valve converters and just leave them installed.
ConvertAir converters
The easy answer is to drill out the valve opening in your rim from 0.25” to 0.3125” (5/16”) and use a tube with a Schrader valve. Continental makes such tubes and they are they type with the threaded stem. Problem solved.
They've all leaked for me while inflating. This makes any pressure gauge on a floor pump much less useful as you can only guess what pressure you've reached since the gauge doesn't hang around at tire pressure. All the extra pumping is also a pain, though I suppose if you were using a compressor, the lost air is less of a problem.
Liked 4,222 Times
Why not just use Schrader valves if you have issues with Presta valves? Presta valves are extremely simple and easy to use if you use the proper chuck.
Stuart Black
Stuart Black
I do not have any issues with Presta valves for everyday use. I was looking for a solution that would allow me to use my air compressor when trying to seat new tubeless tires. The air compressor hose has a Shrader fitting at the end and I needed an adapter of some sort so that I could use the air compressor on my Presta valves. Silca, Prestacycle and others have various types of adapters, but these ConvertAir look like a good solution. If I like them I may keep them installed to make injecting sealant as needed an easier task than trying to inject thru a Presta fitting.
Liked 4,222 Times
Stuart Black
Stuart Black
Whatever floats your boat but if you are going to leave them in place, why not just drill out the rim and use Schrader valves? Schrader valves are made for tubeless so you wouldn’t have to fiddle with adaptors. Schrader tubeless valves cost only a little more than the ConvertAirs.
Likes For oldwinger14:
Quoted: 381 Post(s)
Liked 145 Times
I prefer not to drill the wheels to go 100% Shrader. If I did that, there’s no returning to Presta nor do I want to abandon Presta valves completely. As I mentioned earlier, I would most likely only use the Convert Air adapters to make it easier to seat new tubeless tires.
https://www.amazon.com/Quad-Wheels-M...dp/B000AO5ICG/
