Terrible mistake, L'Eroica edition
I rode the 2018 Eroica-CA 89 mile Coastal route. As best as I recall, the fastest downhill stretch is the part after Adeleida. (https://ridewithgps.com/routes/27745408. See mile 28-32).
For the current EC event, this section starts at mile 58 on the Santa Lucia route (https://eroica.cc/en/california/santa-lucia-route).
On my 2018 ride, I used Campy NR short reach brake calipers with new Kool-Stop pads. I weigh about 150 lbs. During the steepest parts of that descent, I had to white-knuckle grip the brakes for a full 20 minutes or so. If I eased up on the brakes for the slightest amount, I was at risk of either going over the side of a cliff, or crashing face first into a vertical rock wall.
If I had to regularly descend steeper hills like those at EC, I'd be seriously looking for better brakes. One guy on Classic Rendezvous had his vintage frameset reworked after EC to add braze on pivots for Mafac brakes.
A local friend of mine stated that Mafac Racer brakes compare quite favorably in performance to modern Campy double pivot sidepull brakes. Or should I say that the modern Campy double pivot brakes compare favorably to Mafac brakes?
I suspect that one critical difference is that Mafac brakes have longer brake pads, compared to Campy NR. This increases the braking surface area, thus increasing friction and improving overfall stopping power.
Likes For Andrew_G:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
@RustyJames set up a Koolstop tour a few years ago, those guys seem to know the science of braking well. Maybe we can contact them to see what they say on the subject?
What larger surface areas give you is longer wear, as the pressure on on the pads decreases with increase in surface area (P = F/A, P=pressure, F=force A=areas)
Likes For gugie:
Apparently a L'Eroica bike is any pre-1987, steel frame road bike with downtube shifters, and without clipless pedals or aero levers. (Some clubs now allow aero.)
And here I thought it was an old ten speed that someone is asking $2800 for on Marketplace. But no! It turns out every bike in my garage is a L'Eroica bike! ("Yes, this is a true classic, the Schwini Giro di Chicagua...")
Or they would be, had I not installed dual pivot calipers on every one of them, thereby destroying $2700 or so in market value of each. Whoops! 😬
Likes For Mr. Spadoni:
Quoted: 3811 Post(s)
Liked 6,710 Times
I've twice ridden California Eroica. There was no bike inspection at the start or at any point (other than follow riders giving each the side eye). In fact, there's was an overall startling level of neglect from the organizers.
Likes For nlerner:
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
I like DP brakes just because they're easier to adjust. Pretty handy when you change wheels.
Likes For DiabloScott:
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
On dirt, maybe not easy exactly, but not too hard if you have skilz. You just have to push your weight back to counter the natural tendency to endo.
Klaatu..Verata..Necktie?
Quoted: 10435 Post(s)
Liked 11,912 Times
I have 2 Eroica Compliant bikes (except for the pedals), but much as I love riding them, I have no wish to do one of the Eroica rides. But I salute the riders and the organizers!
Likes For genejockey:
Quoted: 3015 Post(s)
Liked 3,804 Times
It is interesting to me that the Eroica rules, which were promulgated around 1997 IIRC, essentially specify a bike that was 10 years old or older THEN, but is now 37 years old, rather than building the rules around "no technology less than 10 years old". Not a complaint!! It's a completely valid choice. I'm just curious about the choice.
Likes For iab:
Liked 11,912 Times
There were rules in 1997? As best I know, just started as a bunch of people riding old bikes in 1997 in the spirit of Bartali and Coppi. And in reality the rules are easy. Lugged steel, no clicky gears, no clipless pedals, no aero. I suppose then you got your usual killjoys with their "whatabouts", and formal rules were created. And for the last 27 years there has been a "let's nitpick the rules" thread every 1-2 hours on this site.
Quoted: 1952 Post(s)
Liked 2,013 Times
I think there was so much new tech showing up on new road bikes from the mid eighties on that 87 (or 85) makes sense to me as a good place to stop. It’s not about 10, 20, 30, … year old bikes.
Bikes: Several
Quoted: 207 Post(s)
Liked 1,042 Times
I rode down Cypress Mountain's 10-17% grades with my Weinmann 500 single pivot brakes without an issue. Of course, both the calipers and levers had been thoroughly disassembled, cleaned, and reassembled with new grease at all pivot points and running Kool Stop pads and new cables and housing. Even the best brakes will be sub-par with grime in the pivot points.
My collection: 1947 Ciclo Piave, 1955 Liberia, 1969 Colnago Super, 1972 Legnano Olimpiade Record Specialissima, 1980 Mercian Vincitore, 1983 Gitane Interclub, 1985 Peugeot PGN10, 1986 Bianchi Vittoria, 1987 De Rosa Professional, 1989 Vitus 979, 1990 Bianchi Axis, 1990 Specialized Sirrus, 2001 Colnago Dream B-Stay, 2007 Trek 1000
Likes For Brad L:
Quoted: 3464 Post(s)
Liked 2,831 Times
I rode down Cypress Mountain's 10-17% grades with my Weinmann 500 SP brakes without an issue. Of course, both the calipers and levers had been thoroughly disassembled, cleaned, and reassembled with new grease at all pivot points and running Kool Stop pads and new cables and housing. Even the best brakes will be sub-par with grime in the pivot points.
do not like that sound at all.
Likes For repechage:
Bikes: Might as well, now that I am here...
Quoted: 79 Post(s)
Liked 78 Times
I went to the Eroica Valkenburg last year. I did not want to use toestraps, I used SPD-pedals (two sided, so one was a platform the other clip in) in conjunction with those nice lace shoes of Vittoria. Who look the part
Used dual pivot as well, dura ace IIRC. Nice and shiney.
About the pedals: I asked the organizers beforehand. Not a problem! Happy to have you
Brakes? I dont think anyone checked. Everyone had a good time enjoying the scene, the food and the ride. And each other's bikes.
So I tink that, as long as your bike is 'in the spirit' of Eroica, you're good to go.
You can always argue that the upgrade of the brakes is the upgrade that the bike would have had anyway, back then.
And on aero cables: if I still had my Peugeot Triathlon bike I would have ridden it (still regret selling, in hindsight) and it's as aero as it can be in 1987.
Those arent really rules, They are more like.. guidelines. Harrr!
Likes For Millstone:
aged to perfection
Quoted: 838 Post(s)
Liked 1,258 Times
seen outside the coffee shop in Paso 2017. I liked this one.
brake cable service loops a little too long but that's a nit
/markp
/markp
Quoted: 46 Post(s)
Liked 112 Times
At last years L`Eroica in Tuscany, Gaoili I can 100% confirm that no aero brake settups were allowed (I spoke with a rider who had been turned away at scrutineering and personally witness scrutineering chase a chap down who tried to slip through with clipless pedals - he failed to ride as an official entrant though would have been free to ride the roads of course as they are not closed or private.
In defense of L`Eroica Italy the event is just outstanding and really, really well organised, plus its massivly over-subscribed so just accept the rules for what they are - old school pre `86 race bikes with period gruppo`s - I`m there again this year on my `63 Legnano and attempting the Sunday on a late 20`s english 3 speed - no need for aero hoods on those two....
Cheers, Dan.
PS - brakes - use well settup and bedded in Kool Stops - the descents are properly scary...
Cheers, Dan.
I found these statements on the L’Eroica web site. The rules have a lot of words about the aero brake levers and cable routing, but nothing very specific about the brake calipers. In my opinion, dual pivot calipers would probably not get you kicked out.
This one is for the Italian event: i) There are no restrictions regarding the type of brakes, as long as they are in keeping with the period of construction of the bicycle and they are safe.
This one is for the California event: i) there are no particular rules on the type of brakes as long as they are in line with the construction period of the bicycle and that they are efficient for safety reasons.
For California, aero brake levers are okay: c) we prefer the traditional brake lever setup on the bicycles, brake cables pass outside and over the handlebars (cables can pass inside the top tube of main frame), however, starting in 2017, aero brake levers without built in shifters will be allowed.
It seems that the Italian event has plenty of entries, so they aren't worried about losing a few people who don't want to comply. On the other hand, California is trying to attract more entrants, so they are more flexible. In the end, it's really just cosplay for bikes. There are a few concessions made for safety, but the idea is to experience what the old timers had to put up with back in the day.
Bikes: Cannondale Synapse, LeMond Victoire, Bianchi Campione d'Italia, Kona Hei Hei, Ritchey Ultra, Schwinn "Paramount" PDG, '83 Trek 640
Quoted: 268 Post(s)
Liked 325 Times
Eroica California was quite relaxed about equipment requirements the years that I did it. It sounds like L'Eroica in Italy is much more stringent.
There are plenty of good options, "aero" and "non-aero". Mid-80's Japanese single-pivot brakes with modern pads and cables are plenty good enough. Properly-adjusted centerpulls and cantis are both good enough (again with modern pads and cables).
Again, at least at Eroica CA, dual-pivots would not lead to excommunication. Better if they're polished sliver, though.
I'm not Mark, but...
The crankset looks like a Holsworth-branded Andel-manufactured Taiwanese crankset. I can see hints of "H" to the left side of the right toe strap, plus what appears to be the crest of the Holsworth brand. I've previously seen the Holsworth branded crank on UK websites.
Here's one photo from a blog: https://velovintagehyde.blogspot.com...-crankset.html. ;the crest look identical.)
The same crank has been available in the USA under the IRD and Velo Orange brands. Chainrings have occasionally been available as OEM drillium.
ANDEL ENTERPRISE CO.,LTD..
(Check the RSC73-277PW for double chainring: https://www.andel.com.tw/products_d.php?pid=56&cid=12
and RSC73-377PW for triple: https://www.andel.com.tw/products_d.php?pid=55&cid=12.
https://velo-orange.com/collections/...rankset-34x48t
https://www.interlocracing.com/shop/...2923,2622,3097
Señor Member
Quoted: 1492 Post(s)
Liked 1,095 Times
So my frame can be 1985, but my bar-cons have to be 79.
Likes For USAZorro:
Liked 5,802 Times
They cab be 2024 vintage as long as you run them friction.
BTW, who goes to a costume party but doesn’t wear a costume?
Likes For gugie:
feros ferio
Quoted: 1393 Post(s)
Liked 1,327 Times
With brakes, it's all about system leverage, pad (good) friction, parasitic (bad) friction, caliper rigidity, and adjustment and lubrication of pivot points.
My most terrifying braking experience was with short-reach Campag. sidepulls and Shimano pads, on a 15% descent under high-humidity, patchy fog, weather conditions. Replacing the Shimanos with KoolStops helped considerably, but it was still not enough for safety. I now have Shimano dual-pivot sidepulls (huge difference), Shimano aero levers (15% more leverage than the original non-aero Modolos), modern cable housings, and KoolStop pads, and the Bianchi is a lot more enjoyable now that I have braking confidence.
I still have the original Weinmann centerpulls on the Capos and Mafac centerpulls on the Peugeot, and those work far better than the Modolo or Campag. single-pivot sidepulls ever could, under any conditions, again because of leverage. One can also boost centerpull brake caliper system leverage by varying the length of the straddle cable, which is a trivial operation on Mafacs.
Likes For John E:
