Weird headset size
Bikes: 2010 Trek 1.5
Weird headset size
Hi all, long time lurker here, I'm looking to buy a replacement threaded headset for my (2005) raleigh firefly. It has a 1 inch steerer, but the frame cups seem to have an outside diameter of 34mm, same as a 1 1/8th headset. I can find no mention of this type of headset anywhere, and it's got me beat. Any ideas?
Quoted: 2026 Post(s)
Liked 1,097 Times
I wonder if it's a "reducer" headset intended to allow a 1" steerer fork to be installed in a 1-1/8" headtube frame.
Didn't know they existed, sounds plausible though. I know I could buy some shims and then use a standard 1 inch headset, but I just wondered if there was a simpler solution.
Insane Bicycle Mechanic
Quoted: 816 Post(s)
Liked 760 Times
Jeff Wills
Jeff Wills
Quoted: 239 Post(s)
Liked 7 Times
What's simpler than shims?
https://problemsolversbike.com/produc...dtube_reducers
Bianchi Goddess
Quoted: 2968 Post(s)
Liked 3,047 Times
This is a British market bike? I don't know what year this one but it says it has a 1" semi cartridge HS
https://www.malleys.co.uk/bike/thebik...01/firefly.htm
Check with your local Raleigh dealer. Do you have any pics?
Sugar "Kane" Kowalczyk
Liked 1,097 Times
That brings up a request. I wish posters would indicate at least their country location in their Forum name block. We often give equipment or service advice based on assuming the poster is in the US and that may be useless to someone in Europe or Asia or OZ/NZ, etc.
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
My first thought was that the OP thinks that because the stem quill is 1" (25.4mm) in diameter, it is a 1" fork, but in reality, a 25.4mm quill goes into a 1-1/8" fork. The malleys page does not say it is a 1" stem, just that it is a quill stem.
There is a shimano 1 inch headset that use sealed bearings cartridges that are 34 mm ish (1 1/8)... the angles of the bearings are 35 degrees inside and outside.
If your bike uses a 1 inch headset (front tube), you have to locate one of those shimano threaded headsets. Ultegra.
The other option if you need a new headset just buy a new one, done.
The bike on the malleys page is in fact a different model, although mine does still have a quill stem that I've swapped out before. The steerer is definitely 1 inch - I have been wrenching on my bikes for a while, so I'm sure of this I already have a 1 inch headset I can use that I bought before realising it didn't fit, so once the shims turn up I should be back in business.
