Might WD-40 hurt tires?
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Thinking of using WD-40 as a quick and dirty frame/rim wipe. I wouldn't intensionally put it on the tires but they might get some overspray. I'll be careful with the rotors.
Jedi Master
I buy it by the gallon and spray it all over my off-road motorcycles and have never noticed that the overspray does anything to the tires, but off-road tires don't last very long anyway. I wash my bicycles with soap and water, so I've never had a need for wiping them down with WD-40, but I wouldn't worry too much about the tires if I did.
Likes For kingston:
Quoted: 581 Post(s)
Liked 921 Times
It's not great for plastics in general, so I would avoid getting it on tires. You also probably don't want any to seep into bearings as it can act as a solvent and break down your grease. Instead of spraying on and hoping to miss the tires and other crucial bits, spray some on a rag and use for the rag wiping clean exactly where you want to clean.
Likes For ClydeClydeson:
Quoted: 839 Post(s)
Liked 1,062 Times
Some rubbers will swell and be ruined with WD40 but probably not tires as they have to withstand all kinds of glop on the roads. I would still make an effort to keep the WD off any part of the tires. My worry would be making the tires a little bit slippery on the road surface. Not a big worry mind you but take it easy when starting out on a ride to get a feel for if your traction is OK.
Quoted: 5224 Post(s)
Liked 3,584 Times
I wouldn't use it on rims if the bike has rim brakes
I wouldn't spray it anywhere near disc brakes
I use it to remove china marker from car tires after tire rotation
Likes For rumrunn6:
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
/whatIheard
/wasntme
Likes For Juan Foote:
Liked 3,584 Times
Is it ok on the rotors tho? I've used it & thought it was ok. I just sprayed it on some paper towels away from the bike, then used the towels as I spun the wheel
Likes For rumrunn6:
Likes For sloppy12:
Liked 960 Times
Yes, not going to hurt the brake components. Similarly as pointed out above, don't let it get in the hubs either. If it hits a spoke it can discolor it but would depend on what they are made of.
Quoted: 2338 Post(s)
Liked 2,827 Times
I use it for cleaning parts, wiping down really well afterwards. there is enough lubricant I would not get it anywhere near rims/disks, also would think without a super good wipe down it could attract dirt. overall I would not use it this way.
Quoted: 540 Post(s)
Liked 416 Times
WD40 is just cheap and low grade. A lot of it is needed to make it work, that's why the aerosol cans are expensively a rip-off, and best dispensed in a finger trigger spray bottle (like the ones you use to spray cats into obediance).
The only time I would use it on a bike is on abandoned bikes I find and hoard. I would spray it entirely all over so it can rest in peace in my backyard, so I can pull parts from it when needed. It is a penetrant. Left over long periods of time, it does work. More the reason you don't want it to seep into things like bearings.
The surface area of a bike is so small, it's really easy to clean it properly, polished and waxed, at which point dirt comes off it so easily with any damp rag, or carefully with pressure washer on my lazy days, which is almost all of the time now.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
I had a guy wipe down some machinery once with WD40 and he specifically called me back to the shop to show me what he did because he was so proud. The next day he wasn't so full of pride.
Besides this, your bike will smell like WD40 too.
Likes For Chuck M:
Quoted: 569 Post(s)
Liked 584 Times
WD-40 for anything other than general household use for non-mechanics amazes me. WD is lubricants w/ anti-corrosion agents, penetrants, water displacers and something for cleaning(50% OMS). A gal of OMS and a spray bottle will clean and not leave anything on your rims or rotors like WD does and cost much less than a gal of WD and if you buy spray cans of WD you will spend 5 or more times as much.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
I do agree with others that the use of WD-40 as a wipe down isn’t a particularly good idea. Mineral spirits or Simple Green or just plain water should be enough. Don’t use anything oily on the chain and your cleanup will be a whole lot easier from the start.
Stuart Black
Stuart Black
Liked 4,220 Times
WD-40 is only “water displacing” in that it’s an oil that sticks to the metal. A bit of water and the action of moving the chain will churn that mixture up and displace the oil with a layer of water on the metal since metal has more affinity for the water than oil does. But that happens with any oil based lubricant.
I agree that it shouldn’t be used as a cleaner, just like TriFlow shouldn’t be used as a cleaner for fairly obvious reasons.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 967 Post(s)
Liked 1,631 Times
Yes... It works but there are some things that do not go well with WD-40 and it leaves just enough of an oily residual to act as a magnet for light dust. ON the other hand that same light residual makes it easy to blast off mud even if it has dried latter on.
I found that ArmorAll "Tire Foam" (Must Be Brand Name) to be the best. I spray the entire bike, everything, then wipe it all off. The brand name tire foam has helped preserve paint, decals, leather, tires, spokes nipples, and plastic.
Jedi Master
I've used Pledge to wipe off a bike on rare occasions when it's little dirty but not dirty enough to wash. It seems to work ok for that and it smells lemony fresh!
Likes For kingston:
I use Griot's Vinyl and Rubber dressing, after being recommended by Aaron's Bike Shop (rideyoubike dot com). Sheds mud easier on mountain bikes!
Liked 2,011 Times
Liked 4,220 Times
Snarkiness aside, there are a number of better products that will do the job without serving as a dust magnet. Car wax, Pledge, ArmourAll, etc. would be a better choice.
Stuart Black
Stuart Black
There’s this stuff that has been around for years (and years and years and years). Called “paint”. Even comes in different colors if you like. Does a wonderful job of preventing metal oxidation. You should try it
BTW ever used latex paint on iron\steel with out a primer? The water in the paint will cause the metal to rust under the paint. It's not pretty.
