Gravel lights
Quoted: 1873 Post(s)
Liked 692 Times
Gravel lights
Which lights are you all using for night gravel riding? I'm in the market and looking for some feedback, good and bad, on lights you all have tried.
2019 Salsa Warbird
2019 Salsa Warbird
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
These are what our high school XC team uses: https://lightandmotion.com/collections/bike
Expensive, but extremely reliable and hold a long charge, given the intense light they produce.
I should add I personally use cygolites, but if I wanted to do serious night trail riding (which my kid does, but I don't), I would put the LightAndMotion lights on the bike.
Sunshine
Quoted: 10970 Post(s)
Liked 7,496 Times
https://cygolite.com/product/dash-pro-600-usb/ - on medium setting, I get over 2 hours out of it and its plenty bright to see the road ahead and any potholes/washboard.
https://www.kryptonitelock.com/conte...ml?type=lights - the XBR model has an acceleration sensor setting so it lights up when you slow down suddenly. Its very light, compact, and the battery lasts for a bunch of rides so i rarely have to charge. I can see it from multiple blocks away in the burbs, so on a dark gravel road, a slow pulse light will be easily seen from afar.
I have thought about adding one to my left seatstay too, but havent yet. When I ride into work(when i went to an office!), I used a steady light on a bag on the left side of my rear rack plus a pulsing light on the seatpost. 2 is twice as good as 1.
I dont do a lot of hard riding at night, admittedly, so I dont have a need for a stronger or longer lasting lights. Most of my gravel riding at night comes from rides that start with the sun up and end after dusk, so its 50/50 and a 2 hour headlight light is plenty.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
The key is the mounting, needs to be hard mounted or it's going to bounce too much on rough surfaces. I use the gopro mount under my computer mount with an adapter for my Niterider 900, works great!
Likes For Rides4Beer:
Quoted: 733 Post(s)
Liked 815 Times
Old guy on a bike
On the bike Fenix BC30R, 1,000 lumens for 2+ hours and the top of the beam is flat for road riding
https://www.fenixlighting.com/produc...ix-bike-light/
On my head I wear a Fenix HL55 which has been discontinued, but the replacement looks even better
https://www.fenixlighting.com/produc...able-headlamp/
If you ride in fog a light on your head is not effective, it bounces back, but any other time having both lights is great. Reasonably priced too
Quoted: 336 Post(s)
Liked 309 Times
I opted for a generator setup. While all of the lights I see recommended here look great, they annoy and often blind drivers. Nearly all generator lights have a high cutoff like a car headlight.
The best combo for gravel in my opinion is a generator light and a helmet light. The helmet light helps see low hanging branches and you can point it into a turn, which you cannot do with most mounted lights. For the occasional car coming the other way, you can simply point your head to the side of the road so you don’t blind the driver.
Gravel rides always take longer than expected, so riding with a generator doesn’t carry the stress of running out of battery. Using a headlamp also solves the problem of how to use a bike-mounted light for a road side repair.
The amount of light needed for most gravel rides is not as much as people think. Without light pollution from car headlights, signs, and street lights, I can run my headlamp o medium instead of high and still feel perfectly safe. Wet pavement and dirt is the exception, as it seems to “soak up” light easily.
Randomhead
Liked 3,700 Times
I have dynohubs on all my bikes. Road, mtb, fatbike, gravel. I find that gravel ride times are somewhat unpredictable, and it's nice to always have a light. If I know I'm going to ride at night, I have a back up Cygolite Expilion.
I use the Gloworm X2 for riding in the dark on my mountain bike and gravel bike. Long battery life, great lighting, and easy to swap between bikes.
Bikes: Niner RLT RDO, Trek Remedy 9.8
Quoted: 108 Post(s)
Liked 117 Times
I use a Sofirn flashlight (about 1200 lumens) strapped to my helmet for gravel and paved trails. When mountain biking I will add a bar light that has an external battery pack.
Likes For grubetown:
Fredly Fredster
Niterider Lumina 750 & 900 headlights. Niterider Solas 100 tail light.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
They are great when they are new, but they don't last long
The USB cover comes off, making your light vulnerable to moisture
the mounting tab to mount to the bracket brakes, making the light unusable.
I liked my first one so much I bought a second. Bad move. They both fail in tandem though.
Meanwhile my older cygolite and nightrider lights are still going strong.
Likes For chas58:
Liked 415 Times
Shoot(a), I just follow someone with brighter lights...
That was last night - given that bike was powered with a dynamo - he had no problems running full power lights for a 40 mile ride, where I ended up swapping lights out half way through.
Likes For chas58:
Liked 415 Times
Helmet lights totally washout any shadows making rocks and obstacles hard to see. And, they can be blinding riding by white street signs (i.e. speed limit). Not to mention they are a nightmare if you are riding with anyone else.
So, I tend to put a brighter light on my bars, and about 1/2 the power on my helmet (and turn it off if I really need to see road texture).
Likes For chas58:
Liked 692 Times
Great suggestions all. I was able to re-solder the battery cables back on inside my Niterider yesterday. So, I guess I'll be rocking that and a Bontrager Ion 700 in tandem on my night rides this year.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
3 Light and Motion lights... no problem. The plastic mounting tabs have not broken.
I might add... it's darn spookie riding at night in the middle of nowhere.
I would avoid Light & Motion at all costs. After having owned three of them, I finally learned my lesson. And they are far from water resistant, too. Like I said before, they look very cool, but they do not last.
Liked 742 Times
I would not avoid Light and Motion.....at all,. after owning 3 of them. I am not HAM fisted and have not broken the plastic tabs. The lights are very water resistant. Like I said before, they look very cool and last many years.
Non omnino gravis
I have four L&M lights, the eldest of which is over five years old. I dunno what people are doing to break that tab off, but it must be pretty serious.
(Very) recently upgraded to a Lezyne 1600XXL (complete with remote switch) and while it's too early to make a statement about longevity or survivability, it sure is bright. The handlebar switch is a fantastic luxury.
It's not an issue of being ham-fisted. The tabs can only be opened by bending them back on themselves. They are made of hard plastic. Eventually, through repeated bending, the plastic fatigues, cracks and breaks at the hinge. It's been well documented. Unless you are using some other type of tab (maybe made of silicone or rubber) or just don't use your light the much, the plastic will eventually detach.
Randomhead
Liked 3,700 Times
I kinda like riding with a helmet light in the woods in the summer. The bugs fly around your head, which is bad, but it attracts bats, which I like.
So far no bats have hit me.
Likes For unterhausen:
Old guy on a bike
I’d much rather ride in the middle of nowhere than in a city; the four legged animals are much mor predictable than the two legged animals. Except for squirrels.
Here's the problem with the Light & Motion Urban light series design.
The dust cap for the charging port is made of hard plastic polycarbonate, not flexible rubber or silicone. If you have a visor on the front of your MTB helmet- that's the same material form with this cap is made. It's fixed to the metal housing at one end. In order to open it one must bend it back along a horizontal crease or "hinge" (circled in red). In the photo you can appreciate that the plastic crease has begun to fray and deteriorate from fatigue due to repeated opening and closing. This is to be expected if one repeatedly bends a hard material at the same spot - we've all done with with a paper clip.
On this-particular light the crease / hinge has nearly degraded, due to fatigue, and only a small bit of it remains intact. After a few more charges, it will completely beak off and I will have to replace it with a fresh one. Which might last me six months (I ride every day to work and always use a front light).
An additional problem with this design and choice of material for the cap (hard plastic versus soft rubber) is that it cannot possibly provide a water-tight seal against the lamp's metal housing. The plastic cap edge does not conform to the charge port opening as tightly as it should - two hard surfaces won't seal against each other as well as a hard and soft surface would.
Until Light & Motion changes the design of this charge port cap, I advise against them. You'll be waiting for the cap to break off and then will need to replace it with a new one. Over and over again.
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
That looks like (unreinforced) nylon, not polycarbonate (not that it matters to the point you're making).
