Preserving Patina?
Preserving Patina?
Old 04-12-21, 06:36 PM
ddeand
ddeand's Avatar
Quoted: 206 Post(s)
Liked 102 Times in 46 Posts
Preserving Patina? (Pics Added)
Quick question. What are some methods or recommendations for protecting a 50 year-old frame that has a bit of surface rust and other typical wear and tear? Best way to clean up as much rust as possible? What is best for final coating of the frame? Thanks!
Some days, it's not even worth gnawing through the restraints.
ddeand is offline
Old 04-12-21, 08:12 PM
merziac
merziac's Avatar
Quoted: 4512 Post(s)
Liked 6,387 Times in 3,672 Posts
merziac is offline
Old 04-12-21, 10:47 PM
Insidious C.
Quoted: 463 Post(s)
Liked 336 Times in 213 Posts
I think we're going to need to see some pics.
I.C.
Insidious C. is offline
Old 04-12-21, 11:30 PM
frogman
frogman's Avatar
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times in 158 Posts
Here's what I would do if the rust isn't too extensive.
Clean and dry the frame, lightly sand the rust areas with steel wool then spray them with Krylon Rust Stop then spray the entire frame with Krylon clear coat.
frogman is offline
Likes For frogman:
Old 04-13-21, 12:40 AM
gaucho777
gaucho777's Avatar
Quoted: 834 Post(s)
Liked 2,127 Times in 555 Posts
Pics might be helpful, but this is my general advice:
1. Strip frame
2. Clean and degrease frame/fork
3. Soak frame/fork in oxalic acid bath (approx. 24-36 hours with a dilution of about 1 tablespoon per gallon of water)
4. Apply wax (I avoid cleaning/polishing wax unless paint has dulled)
5. Rebuild with new grease/bearings/cables as needed
gaucho777 is offline
Likes For gaucho777:
Old 04-13-21, 04:59 AM
nlerner
Quoted: 3811 Post(s)
Liked 6,711 Times in 2,613 Posts
Originally Posted by merziac
Rub with popcorn?
nlerner is offline
Likes For nlerner:
Old 04-13-21, 05:36 AM
jonwvara
jonwvara's Avatar
Quoted: 765 Post(s)
Liked 660 Times in 351 Posts
Originally Posted by nlerner
Rub with popcorn?
It's like media blasting, but easier on the paint. Extra butter is a good idea.
www.redclovercomponents.com
--Ogden Nash
jonwvara is offline
Likes For jonwvara:
Old 04-13-21, 06:27 AM
mechanicmatt
Hoards Thumbshifters
mechanicmatt's Avatar
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 338 Times in 193 Posts
1. Strip frame
What wax do you recommend?
mechanicmatt is offline
Old 04-13-21, 07:14 AM
nlerner
I did read on the Internet that Orville Redenbacher got his start in frame refinishing.
nlerner is offline
Old 04-13-21, 07:42 AM
BFisher
Quoted: 767 Post(s)
Liked 1,898 Times in 889 Posts
He did the Wright Bros. frames, didn't he?
BFisher is offline
Likes For BFisher:
Old 04-13-21, 07:51 AM
Wildwood
Veteran, Pacifist
Wildwood's Avatar
Quoted: 3898 Post(s)
Liked 4,836 Times in 2,229 Posts
oxalic acid bath may not be needed at all. For surface rust only - it can be neutralized without soaking the entire frame. When you pull the BB check for internal rust, if none is present, I would not OA bath the entire frame.
But all answers are general responses without seeing the frame detail pics.
Wildwood is offline
Old 04-13-21, 11:00 AM
ddeand
ddeand's Avatar
Quoted: 206 Post(s)
Thanks for the suggestions - I appreciate them. I probably won't be using the Reddenbacher method since I swore off popcorn a couple years ago, and I know that I'd end up eating the stuff before I got it on the frame. I also don't want to do the whole "dip the frame" method unless I really have to. My other vintage projects have all entailed stripping the frame and doing a complete respray, but this is going to be a utility bike (not a restoration) that will eventually become my pavement/gravel "fishing bike". (More on that when I get it done.) Any more ideas are welcome!
ddeand is offline
Old 04-13-21, 12:02 PM
merziac
merziac's Avatar
Rub with popcorn?
You might be on to something.
merziac is offline
Old 04-13-21, 03:16 PM
Wileyone1
Quoted: 5 Post(s)
Liked 3 Times in 2 Posts
Any quality car wax will work.
Wileyone1 is offline
Old 04-13-21, 03:40 PM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 10435 Post(s)
Liked 11,912 Times in 6,100 Posts
I've seen the guy on the "BikeIt UK" YouTube channel use a product called Kurust for neutralizing/converting rust before doing touch up painting over it. AFAICT, it's not sold in the US, so at the moment I'm waiting for it to arrive from Merry Olde. I'll post results when/if I see it. Apart from that, I had pretty good results with Meguiar's Scratch-X on a 1989 Schwinn Circuit that had dulled, but not faded paint and no rust to speak of.
genejockey is offline
Old 04-13-21, 04:44 PM
27inch
vintage rider
Bikes: 1937 Roadmaster, 1972 Schwinn Typhoon, 1972 Raleigh Sports
Quoted: 35 Post(s)
Liked 11 Times in 8 Posts
Any bike that old likely needs to come completely apart for a thorough cleaning and relube at the very least.
I like the idea of just polishing off the rust a bit and giving it a coat of clear gloss. It'll preserve the decals and original paint. I'm not sure if Krylon is the best or not, some rattle can clear paints will yellow with age. I've used clear lacquer in the past but not from a rattle can, as well as Dupont auto finish from the paint shop, which I normally have around the garage anyhow.
I wouldn't worry about soaking the whole frame unless you open things up and find its a rusty mess inside. chances are you just have a few rusty scratches that need to be addressed.
You could spot clean the rusty spots with some Evaporust, then polish the original paint up as best you can with some light polish but saving the decals is tough when trying to get gloss back out of old paint like that, especially if its pinstriped. The clean and clear method may be your best option to preserve the decals and any pinstripes.
27inch is offline
Old 04-13-21, 05:09 PM
C9H13N
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 229 Times in 121 Posts
My 2 cents - don’t do anything permanent unless you’re going to spring for a full repaint/powder job. IMO most paint touch ups look like crap and are worse than leaving as is.
Strip it down to the bare frame and fork, wash, lightly polish (previously mentioned Scratch-X works well). Give it a couple coats of automotive paste wax. Reapply wax occasionally to maintain. It’s lasted this long with less care than that.
C9H13N is offline
Likes For C9H13N:
Old 04-13-21, 06:15 PM
jonwvara
jonwvara's Avatar
Quoted: 765 Post(s)
Agreed. In any case, the existing paint looks good--definitely at the light end of the patina scale, by my standards, at least.
--Ogden Nash
jonwvara is offline
Old 04-13-21, 06:23 PM
jdawginsc
Edumacator
Quoted: 2440 Post(s)
Liked 3,130 Times in 1,969 Posts
Rust is grey hair on a vintage bike. If you dye it, no one seriously believes you have grayless hair...
Clean, polish a bit, and enjoy the small bits of patina!!! Each rust spot has a story to tell!
Do not take my advice by the way...powdered butter flavoring for popcorn is my secret polishing ingredient!
jdawginsc is offline
Likes For jdawginsc:
Old 04-13-21, 09:29 PM
ddeand
ddeand's Avatar
Quoted: 206 Post(s)
From the suggestions so far, I think I have a plan of attack. The frame has been stripped - bottom bracket is off, headset will be next. First, the grease, oil, and grime will be scrubbed off with degreaser and Simple Green. Second, I’ll work on the rust spots to the extent that the paint isn’t further damaged. Third, I’ll try a light rubbing compund to smooth out the remaining finish, followed by a polishing compound to really smooth things out. Finally, I’ll apply a few coats of wax. I think that’s about as finished as a “fishing bike” should be.
ddeand is offline
Old 04-13-21, 09:49 PM
canklecat
canklecat's Avatar
Quoted: 4560 Post(s)
Liked 2,802 Times in 1,800 Posts
For small rust spots try Brownell's Oxpho-Blue. It's the best cold blue I've tried (the Oxpho-Blue liquid, not the cream or paste based stuff). Mostly for firearms but works on any carbon steel to remove and neutralize light surface rust. I'd usually wind some fine steel wool around cotton swabs, dipped in Oxpho-Blue, and lightly rub the rust spots to remove the excess while simultaneously blackening the bare steel to prevent further rusting.
I wouldn't treat an entire frame with the stuff, but to minimize rust on a bike that I just wanted to knock the dirt off of and protect against further rusting, it should do fine.
canklecat is offline
Likes For canklecat:
Old 04-14-21, 12:26 AM
Brad L
Brad L's Avatar
Bikes: Several
Quoted: 207 Post(s)
Liked 1,042 Times in 322 Posts
I use Metal Prep from POR-15. It has phosphoric acid, which will leave a rust-proof protective layer. Once I've cleaned the area and removed the loose rust, I lightly scrub the area down with a soft paper towel wetted with Metal Prep. It doesn't appear to harm the existing paint but the bare metal turns a dark grey. I have a fender on a car I'm restoring that I stripped to bare metal and treated with Metal Prep about 6 years ago. I did nothing to it afterwards and there's still no rust.
Brad L is offline
Likes For Brad L:
Old 04-14-21, 10:42 AM
75lechamp
Bikes: 1975 Motobecane LeChampion (silver lilac), 1974 Motobecane Grand Jubile (red/black); 1975 Motobecane Team Champion (orange); 1982 Pinarello Professional (Exorcist Green); 1974 Raleigh Professional MkIV mink blue, 1974 Motobecane Grand Record blk/red
Quoted: 103 Post(s)
Liked 750 Times in 172 Posts
Patina treatment
I recently got a Motobecane that had basically been sitting outside for about 30 years, and considered a repaint. However, I got it from the original owner, and I wanted to instead try to honor that heritage. So, I basically spot treated rust in the bare spots, polished the whole frame and then used a 2K clear coat (the kind that is in the spray can, that has the hardener you can mix in, then need to use in 24 hours I think.). Then wet sanded and polished the clear. I took some artistic liberties with the Champion Team decal I added, by mixing the original black script with gold in the bare metal areas. I like it, but others may not...
75lechamp is offline
Likes For 75lechamp:
Old 04-14-21, 11:27 AM
geeteeiii
Bikes: HVZ Meteor 1979, HVZ Champion 1962, HVZ SS Moskva80 1981, Dürkopp 1936
Quoted: 41 Post(s)
Liked 350 Times in 70 Posts
Without any serious flaky rust, i dont do anything with frame. I dont ride it in the rain and keep it in a dry place, so its unlikely it will get any worse.
geeteeiii is offline
Old 04-14-21, 04:10 PM
Humanbeing757
Bikes: 1962 Dawes Realmrider 1984 Raleigh Record Ace 2009 Specialized Hardrock 2021 Whyte Sterling 1984 Al Carter Hot Rock 2013 Giant Defy 1
Liked 27 Times in 12 Posts
I’m also building up a ‘patinated’ bike. I’m planning to apply a coat of boiled linseed oil after I’ve cleaned the frame.
Humanbeing757 is offline
Likes For Humanbeing757:
