Best chainwhips for freewheel disassembly
Quoted: 195 Post(s)
Liked 207 Times
In the '70's I bought a couple of chainwhips so I could swap cogs around. They were flat stamped steel with a hole close to the edge with a length of chain attached and a knob on the short end meant to fit between the teeth of a cog. It worked fine then but as freewheels got tougher to separate over the years they usually break a chain before moving the first cog. I've checked on-line to upgrade and the whips are often referred to as cassette removal tools. Since I've never had a cassette so tight it would stress a tool that could budge a freewheel cog, my question is, are they any good for my purposes? I'd hate to buy a shop tool from Park when that would be overkill. Worse yet though is to buy a cheapie that flat doesn't work. Guys?
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 204 Times
I had a chain snap after starting to bend the handle (steel) on an old whip. I will make sure to soak any freewheel I work on in the future. C&V freewheels are very old even if they look fresh.
Last new bike 1991
Last new bike 1991
Quoted: 1438 Post(s)
Liked 1,092 Times
Not cheap but no chain to break: https://www.amazon.com/Pedros-142722.../dp/B001Q270CC Use on the small cog, put a chain whip on one of the larger ones where you have better leverage.
Likes For dsbrantjr:
SE Wis
Quoted: 2747 Post(s)
Liked 3,398 Times
Quoted: 184 Post(s)
Liked 204 Times
Thanks.
Last new bike 1991
Last new bike 1991
Quoted: 1944 Post(s)
Liked 2,164 Times
I have a 2x6 and lag screws as my freewheel vise. The toughest cogs to break are those threaded onto another cog, like the Sachs Aris 1st/2nd position.
John
John
I had 2 ..lever: hot rolled steel , added ovalized steel tubing for a handle, with long leverage..
to make the chains in the chainwhips not blow out the pins, I used 3 1/8" chain 3 piece master links
to attach the chains to the steel flat bar..
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
Birzman Sprocket Remover. I would go as far as saying that there is no point discussing any other tools in the comparison.
Quoted: 4806 Post(s)
Liked 3,929 Times
Ben
Quoted: 840 Post(s)
Liked 336 Times
