Do I need to use a dust cap?
Old 03-25-24, 04:06 AM
Alex Reed
Quoted: 7 Post(s)
Liked 3 Times in 2 Posts
I know that because of the dust cap, the tire valve will not fill up with mud. But, I don't bike on mud trails.
So, do I need to use a dust cap on my tire valve? Is it necessary?
Alex Reed is offline
Old 03-25-24, 04:22 AM
PeteHski
PeteHski's Avatar
Quoted: 4415 Post(s)
Liked 4,868 Times in 3,013 Posts
It depends on the valve. If Presta then no, if Schrader then yes.
PeteHski is offline
Likes For PeteHski:
Old 03-25-24, 05:40 AM
rm -rf
don't try this at home.
rm -rf's Avatar
Quoted: 974 Post(s)
Liked 512 Times in 352 Posts
I never use a cap on my Presta wheels.
The spare tube in my saddle bag has one, to protect the folded tube. And, I wrap the folded tube in a piece of heavy 4 mil plastic sheet or Tyvek. I've seen a two different cyclists have a second flat tire from the spare tube getting worn along a folded edge after months in the saddle bag.
rm -rf is offline
Likes For rm -rf:
Old 03-25-24, 05:52 AM
noglider
noglider's Avatar
Quoted: 7350 Post(s)
Liked 2,475 Times in 1,438 Posts
I never use dust caps. I suppose it's true that it can prevent dust from entering the valve stem, but it's also true that it keeps elephants out. I haven't had a problem with either.
noglider is offline
Likes For noglider:
Old 03-25-24, 06:27 AM
PeteHski
PeteHski's Avatar
Elephants are rarely a problem in valves. Dust and mud in a Schrader valve could potentially be a show stopper. Presta valves are not really vulnerable to dust with their screw top effectively sealing the stem. But I do tend to use caps until I eventually lose them!
PeteHski is offline
Likes For PeteHski:
Old 03-25-24, 06:50 AM
noglider
noglider's Avatar
Yes, it could be a problem, but has anyone you know ever had the problem?
noglider is offline
Old 03-25-24, 06:51 AM
Quoted: 18422 Post(s)
Liked 15,571 Times in 7,335 Posts
Depends on how many miles you should ride in a day.
Old 03-25-24, 07:46 AM
Iride01
Iride01's Avatar
Quoted: 6196 Post(s)
Liked 4,811 Times in 3,319 Posts
I don't like the idea of dirt getting down in them. Sure presta's are a little more resistant since you can snug them up with the little nut. But I still keep the plastic cap on both presta and Schrader valves. If I happened to lose it, it wouldn't be the end of the world.
Iride01 is offline
Old 03-25-24, 07:55 AM
pdlamb
Quoted: 2604 Post(s)
Liked 1,933 Times in 1,213 Posts
I've been known to blow a bit of air into a tube before installing it into a tire -- like when fixing a flat. I figure the dust cap keeps some of the common road schmuck off the part of the valve I'm blowing on.
But, you know, some people find dust caps terribly troublesome. If you're one of those, do not use them!
pdlamb is offline
Old 03-25-24, 08:26 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10965 Post(s)
Liked 7,492 Times in 4,189 Posts
No you dont need them. Yes they are largely a worthless component in 99.5% of riding. But in that other .5%, the top could bend due to the bike falling over or some other odd incident and it then becomes really difficult to use the valve core.
I dont have caps on most of my bikes. I do have em on 3 bikes- 2 of the bikes have caps because the caps are anodized the same color as the frames...so its vanity. The other bike that has em is my gravel bike and the caps do help keep dust from accumulating, but the caps I use also have a built in core remover so its sort of a multitool- both vanity bling and a tool if ever needed. I have never needed the core remover for me, but I have used it during a ride to replace a valve core for someone else.
https://www.amazon.com/Muc-Off-Orang...08Y941ZG5?th=1
https://www.amazon.com/Granite-Juicy...8C0PBEE2Z&th=1
mstateglfr is offline
Old 03-25-24, 02:14 PM
noglider
noglider's Avatar
I don't think that's the Yiddish word you're groping for. Maybe you meant to say schmutz which means dirt. Schmuck means male reproductive gland (and also jerk).
noglider is offline
Likes For noglider:
Old 03-25-24, 03:57 PM
MoAlpha
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,871 Times in 3,160 Posts
It’s really ornament, adornment, or piece of jewelry in German, which is why the Yiddish euphemism is so funny.
MoAlpha is online now
Likes For MoAlpha:
Old 03-25-24, 04:06 PM
Eric F
Habitual User
Eric F's Avatar
Quoted: 4957 Post(s)
Liked 8,098 Times in 3,833 Posts
I've been without caps on my presta valves, since before there were clipless pedals. This has included riding and racing road, MTB, CX, and gravel. Zero is how many times I have had a valve issue due to mud, dirt, or dust getting in the valve from the outside. These days, a more common issue is the valve getting plugged with dried sealant from the inside.
Eric F is offline
Old 03-25-24, 05:18 PM
BobG
Quoted: 318 Post(s)
Liked 117 Times in 82 Posts
I threw them away for 59 years. Then on year 60 I started using them! Why? Last summer I had a troublesome leak to find on a tubed tire. I finally discovered the presta valve to be leaking after putting the tube under water. I replaced & tightened the valve core but just to be sure I put the caps on both tubes tightly in case they were still seeping.
BobG is offline
Old 03-25-24, 05:38 PM
datlas
Should Be More Popular
datlas's Avatar
Quoted: 22600 Post(s)
Liked 8,928 Times in 4,160 Posts
Larry, is that you?
Originally Posted by rjones28
Addiction is all about class.
datlas is offline
Old 03-25-24, 06:02 PM
veganbikes
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,996 Times in 2,667 Posts
I do have a custom made valve caps on my Schrader valves (I really only have 3) they are made from .40 S&W shells glued to plastic caps because they look cool and I had the equipment so why pay $10+ for someone else to do it when I can do hand made ones from ones I emptied. My presta stuff usually doesn't have a cap some do but most don't I got a couple nice anodized ones on some of my road stuff but mostly without though I probably have a bike or two that has only one valve cap because if it brakes or I forget to put it on I don't bother.
For schrader yes all the time valve caps and probably also for Woods/Dunlop valves (though my experience with them is limited and I have never not put a cap back on) but presta they are not needed at all. One could argue you don't really need them on Schrader but it is a free piece at a shop and they weigh nothing so there is really no downside plus you can make or buy some cool ones out there.
veganbikes is offline
Old 03-25-24, 07:01 PM
NumbersGuy
Bikes: Fairlight Strael 3.0 Ultegra Di2, Lauf Seigla Rigid SRAM Red XPLR
Quoted: 108 Post(s)
Liked 115 Times in 64 Posts
I use them mostly to protect the head on my pumps. Although dirt and grit on the outside of the valve won’t impact the valve inside, it can potentially wear the rubber seal on the pump head. Keeping it clean seems like it has no downside, unless you’re trying to follow the stupid cycling Illuminati rules of coolness, or think a couple grams makes any difference.
NumbersGuy is offline
Old 03-25-24, 07:17 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,932 Times in 2,557 Posts
To me, presta caps are small labor devices. Labor to remove, labor to replace and very likely, labor to find that silly little thing you tool off to repair that flat. THe way to keep that labor small? Do the direct brand new tube to cap jar transfer when you take that tube out of the box. (And no small plastic bits to rattle around a bird's guts; probably not improving his life experience.)
79pmooney is offline
Old 03-25-24, 07:45 PM
phughes
phughes's Avatar
Quoted: 1034 Post(s)
Liked 1,292 Times in 744 Posts
Schrader valve? Yes. Once any dirt gets in around the valve stem, it can get in when you add air, and it can get into the valve itself causing it to leak. It happens often on cars. I have seen it many times. Is it a huge worry for me on a bicycle? No, not really, but I should probably take better care.
phughes is online now
Old 03-25-24, 07:56 PM
downtube42
downtube42's Avatar
Quoted: 896 Post(s)
Liked 2,065 Times in 1,081 Posts
I recall reading years ago on sheldon brown's site that a presta cap could be chopped and used as a presta/shrader adapter. I actually used that a few weeks ago, enabling me to mount a tubeless tire at the office using an air compressor.
Ultimately the repair failed for other reasons, but technically it's a possible reason to carry a presta cap (and a blade).
It's a hack. I like hacks.
downtube42 is offline
Old 03-26-24, 05:37 AM
noglider
noglider's Avatar
I asked if it has ever happened, and you told me what it would be like if it did happen. So far, the answer is no, it hasn't happened on a bike.
Cars go faster and farther, so I use valve caps there.
When I was a bike shop mechanic, I used valve caps only because customers think the job isn't done unless the caps are there. I believe they don't help anything at all. Of course, they don't hurt anything, either except, as @79pmooney points out, they are extra work.
noglider is offline
Old 03-26-24, 05:46 AM
Garfield Cat
Garfield Cat's Avatar
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times in 67 Posts
How about in Automotive applications? Do cars have them and how about those big 18 wheelers that carry expensive cargo?
This may be a poor analogy, still...
And those pesky injury accident attorneys on major networks - advertisements. I wonder if they ever had to claim that something happened and part of the blame was the proper upkeep of the vehicle.
Garfield Cat is offline
Old 03-26-24, 06:05 AM
PeteHski
PeteHski's Avatar
With Schrader valves, there is a real chance that you could get a slow leak with build up of dust and debris in the open valve. That’s why car tyres always have them fitted. With Presta valves you don’t have this same risk and therefore dust caps are not important.
PeteHski is offline
Old 03-26-24, 06:35 AM
noglider
noglider's Avatar
Oy vey.
Again, that's hypothetical.
I see I'm not succeeding at asking a question clearly.
Has anyone seen any of this happen on a bicycle?
Please answer the question I ask, not the one you want to answer. If you use words such as could, would, or should, you're not doing it right.
noglider is offline
Old 03-26-24, 09:09 AM
KerryIrons
Quoted: 506 Post(s)
Liked 639 Times in 357 Posts
Oh, now you want to get logical by referencing the real world?
KerryIrons is offline
