Climbing saddles vs flat land saddles
Quoted: 569 Post(s)
Liked 599 Times
Is it possible that a saddles used for flat land riding be less than ideal when considerable climbing is required? As snow birds I have given into using only my Selle Anatomica saddled bikes when we are in our summer place in the foothills of the Bighorn Mtns and have found a little discomfort when bringing bikes with modern light weight road saddle that tend to be long and narrow with minimum padding.
Quoted: 6282 Post(s)
Liked 4,873 Times
If it's terrain you don't ride often, then probably you just need to get use to it. But I've never really ridden in completely flat areas since riding became more than just going from point A to point B.
Agree, you probably need to get used to it, adjust it or find one that works for you. Changing saddles for me is a big pain as once it is dialed in I don't want to move it.
Likes For Steelman54:
Klaatu..Verata..Necktie?
Quoted: 10501 Post(s)
Liked 12,032 Times
I was just watching a video discussing saddle angle and climbing. Apparently Tadej Pogacar tilted his saddle a couple degrees nose-down for some of the mountain stages. The argument is that when the road tilts up, you'll naturally tend to lean forward into the climb. Also, your saddle tilts up, too, which puts pressure where it wouldn't be on the flat. So, if you're riding a flat saddle on the flats, but experience discomfort - you didn't say where - perhaps a wave saddle would relieve the pressure?
Likes For genejockey:
Thread Killer
Quoted: 3196 Post(s)
Liked 1,731 Times
Yeah, our position and weighting on a saddle can change when climbing, as muscle recruitment and force on the pedals can change, too, so yes, a saddle can be optimized for flat road or climbing comfort.
That said, most people are pretty resilient and don’t need to change saddles for varied riding, and if the do a lot of one type or the other, it’s usually reflected in their bike set up preferences, e.g. saddle positioning.
Bikes: SL8 Pro, TCR beater
Quoted: 1011 Post(s)
Liked 589 Times
The weight shifts at the back when you climb, so you can expect your pressure point to shift as well.
Since I ride in the mountains, I always tilt my saddle to compensate.
Quoted: 569 Post(s)
Liked 599 Times
I'll give the tilt a try, couple degrees at a time and see what happens. These climbs can me miles so what your saying makes sense.
Liked 589 Times
It's less comfortable on the flat though. There is no such thing as a perfect fitt for all terrains.
I climb 800+meters (2600+ft) on my usual 50km (30mi) ride. For me, having a tilted saddle is a must. Not as much as Pogacar's saddle at the 2023 TDF though!
Likes For eduskator:
Quoted: 607 Post(s)
Liked 792 Times
There are also good reasons why triathlon saddles are very different and often nose-less.
Liked 4,873 Times
Also wandering how much of a incline it has to be before Tadej does this. Mountain stages for them involve grades of 18% and more. Most of us are probably lucky to find a few brief areas of 10% where the grade only averages 4 to 5%. And the other question might be if he does this only for mountain top finishes with a steep ending climb.
Liked 589 Times
Yea. Tadej's saddle was extremely tilted. My body wouldn't like that, that's for sure. Mine is tilted just so that the bubble on a level touches the rear line. Nothing extreme.
Liked 12,032 Times
To clarify, I wasn't suggesting any of us mere mortals should tilt our saddles a la Pogacar. I was suggesting that if you're riding a flat profile saddle and find it puts pressure on your perineum when the road tilts up, it could be you'd be more comfortable on a wave profile saddle. The problem with tilting your saddle is it may put more pressure on your hands, arms, and shoulders, so you might just be moving the discomfort around, not relieving it.
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Quoted: 239 Post(s)
Liked 988 Times
I use the same saddle, but I have played with tilt depending on the terrain. During the warmer months, most of my riding is up in the mountains with the elevation gain well above the golden ratio of 100'/mile. In those cases, I run a bit more tilt. I ease it off a bit in the winter months, as the elevation gain isn't quite so extreme. It's only a few degrees, but I notice the differences on terrain. Nose down on flat terrain...I'm not utilizing the width of the seat correctly and my ass gets sore. Flat saddle on extended uphills(30-60 minute long climbs) and I start getting a bit of tingling in a spot you don't want tingling.
Another factor is how much power you're putting out. I guess you could tend to roll forward/excessively weight the bars if you have a tilted saddle and aren't putting out a certain wattage. I imagine that Pogacar is putting out enough power that loading the bars really isn't an issue.
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 356 Times
I've never felt uncomfortable in the saddle (flat profile) on climbs.
I'm also a firm believer in "Don't buy upgrades, ride up grades".
However reading this thread reminded me of this; https://www.aenomalyconstructs.com/?...UaAk81EALw_wcB
Quoted: 607 Post(s)
Liked 792 Times
The tour level riders average crazy power compared to us amateur cyclist.
This means much more of the body weight is off the bars and saddle and into the spinning!
ignominious poltroon
Quoted: 2274 Post(s)
Liked 3,495 Times
Stand up when you climb (at least occasionally).
Liked 4,873 Times
climber has-been
Quoted: 3517 Post(s)
Liked 3,656 Times
When climbing in the saddle, I'm sitting taller, and gravity pushes my hips back on the saddle. On the pedal downstroke, I may even need to pull on the bars to hold my saddle position. Virtually no saddle nose pressure.
Liked 589 Times
If you're experiencing pressure from the saddle nose, maybe the saddle's in the wrong for-aft position.
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 122 Post(s)
Liked 214 Times
I thought I knew everything I needed to know about saddles and positioning.... hah hah .....but when the ol' ways no longer work it's time for new perspectives. Of the many "how to" position videos I've watched the only one that I could relate to was from John Cobb. While he may be most well know for triathlon saddles he's not limited to that and offers tip for road riders to find their ideal position also. I went to his website after having purchased one his Pro SR/San Remo saddles and unable to get it dialed in. I now have it some 40mm more forward and tilted up 4 degrees overall rather than down 3 degrees. The narrow mid section has inherent flex, so when tilted up you pubic bone supports you while remaining flexible, and the rear section stabilizes you. Every day I ride with it I'm amazed how nice it is to ride such a saddle. I never have any saddle discomfort. I don't think any other brand or model compares to how Cobb does saddles, as he's rides what he speaks, from experience. The 8 videos are very helpful as he offers practical tips for getting you best positioning.
The closest in design to the Cobb is a Ritchey Skyline Comp. I even bought one for an upcoming bike to see. Of course it's as nice of quality, but as ling as it functions similarly I'll be happy.
https://speedandcomfort.com/pages/fitting-tips
pan y agua
Quoted: 1461 Post(s)
Liked 737 Times
However, for steepness, a lot of the eastern U.S. such as the Appalachian mountains has substantially steeper grades than climbs such as Alp d’ Huez
You could get lost and die.
You could hit a tree and die.
climber has-been
Liked 3,656 Times
The very steep roads that are used in grand tours are often little more than paved goat paths.
Here in California, the silly steep roads are either at low elevation (Old Priest Grade), or on high elevation roads that close in Winter (Sonora Pass).
Liked 4,873 Times
Climbs in the Tour de France, for the most part are really not terribly steep. They’re long, and iconic from their role in racing history, so they get a reputation.
I could also imagine Tadej whipping out a hex key real quick when no one is looking after the stage and tilting the nose down just to watch others and hear their comments about it.
Likes For Iride01:
pan y agua
Liked 737 Times
My point was simply to correct an mis impression that TDF climbs are steeper than what many of come across. While some of the shorter, non HC climbs can have some steep pitches, most of the HC climbs in the TDF do not have supe high grades.
just another gosling
Quoted: 3914 Post(s)
Liked 1,962 Times
I set up my saddles so they're comfortable, and they feel just as comfortable in any terrain. I tilt them down about .5 cm. over their length. Works for me both sitting up on the tops and all the way down, forearms horizontal. Of course different parts of my anatomy are getting the pressure as I rotate my pelvis, but saddles seem to be designed with that in mind. I've been using Selle Italia saddles for a long time. A 10% grade is only 5.7°, hardly noticeable compared to our normal change in pelvic rotation in the various positions on the flat.
Results matter
Results matter
Likes For Carbonfiberboy:
