Addiction LXXVI
#1801
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Remember how the drivetrain on the Habanero was finicky and skipping at times? I replaced the chain (even though it did not measure as worn), cleaned/lubed the RD, and cleaned off the cassette. At least in the stand, everything works fine now. I won't have a road test until Wednesday. Fingers crossed this solved the problem.
#1802
Liked 8,925 Times
#1803
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Yesterday was beautiful but I didn't get a chance to get out. Today looks like more of the same. The visitors, from NOB, who prevented yesterday's ride, are flying out tomorrow morning.
#1804
smelling the roses
Liked 901 Times
I have a large stash of used chains. Where do these things come from? At any rate, I'm not particular about buying new ones as long as these are still within specs. KMC is my favorite brand if I have to buy new.
#1805
Bikes: Shmikes
Quoted: 10167 Post(s)
Liked 5,862 Times
#1806
smelling the roses
Liked 901 Times
From the C&V for sale thread, I have recently purchased a lifetime supply of bar tape(5 bikes worth) and a Suntour/Dia Compe brake and shifter/derailleur set. I had been on the lookout for aero levers and six speed indexed. This purchase gives me both. One would hope we are nearing the end of componentry purchases too. However, if a set of 105 SLR brakes were to appear.....
#1807
Liked 8,925 Times
I have a cold-weather cycling question. I know there is a whole sub-forum devoted to this, but let me throw it out here first.
My concern is with cold weather gloves. I am fine with conventional gloves down to about freezing. For below freezing, thin gloves are not adequate and my fingers get too cold...but thicker gloves are too thick in the fingers and I lose my dexterity/feedback with braking/shifting etc. The solution I have used is to go to mittens with glove liners, which keep the fingers warmer, but I lose even more dexterity. Bar mitts are also an option, but you can't brake from the drops with them as they force you on the hoods. So...
I am wondering if there is a good winter type glove that has THICK insulation on the back of the hand/fingers, and between the fingers, but THINNER insulation on the palmar aspect of the fingers. The idea is to keep fingers warm but preserve tactile feedback/dexterity. With typical hand positions this side of the hand is not in the wind anyway.
Is this a valid ask? Anyone know if this exists and if it solves the problem??
#1808
smelling the roses
Liked 901 Times
I'm surprised no one has yet invented bar heaters.
#1809
Bikes: Shmikes
Liked 5,862 Times
#1810
Liked 8,925 Times
Aha. I may have to go shopping then. The ones I have tried seem to have the same thickness all around.
#1811
Liked 8,925 Times
It's a thing. Electric heated bar tape. Let me see if I can find a link....
https://ame-grips.myshopify.com/coll...ke-heated-wrap
#1812
Administrator
Quoted: 11969 Post(s)
Liked 6,646 Times
Maybe I'm wrong, but I'm convinced all these chain problems nowadays are the result of 11 and 12 sp drivetrains along with the weight weenie craze necessitating a thinner gauge chain. BITD when I used to ride tons, chains never broke unless installed improperly. Sure we didn't ride 20,000 miles a year like some of you nuts guys, but we rode plenty.
#1813
Bikes: Shmikes
Liked 5,862 Times
My neuropsych guy, Mike, and I had the only bikes in our part of the garage this a.m. Sad.
#1814
Bikes: Shmikes
Liked 5,862 Times
#1815
Administrator
Liked 6,646 Times
Crabon bars would assplode.
But seriously, do crabon bars conduct heat like metal?
#1816
Administrator
Liked 6,646 Times
Did you mean sane? Is sad a typo, or . . .
#1817
Mostly Harmless
Bikes: Have two wheels
Quoted: 13714 Post(s)
Liked 4,529 Times
A proper utility bike.
#1818
Liked 8,925 Times
#1819
Quoted: 20810 Post(s)
Liked 9,456 Times
One other thing that this makes me wonder about is swapping or adding another layer of bar tape to something that'll insulate from those heat-sink handle bars a little more effectively. It wouldn't do much good if your hands are primarily on the hoods (which big heat vampires, IMO) but it might help a lot in the drops.
#1820
Mostly Harmless
Liked 4,529 Times
I am not opposed to synthetic socks. And I do not shun all cotton.
#1821
Mostly Harmless
Liked 4,529 Times
#1822
Liked 9,456 Times
Edit: take it with a grain of salt, but this was the first search result:
Composite made from carbon fiber and epoxy resin is a material with heat conductivity x 40 times less than aluminium and 10 times less than steel
#1823
Bikes: Shmikes
Liked 5,862 Times
#1824
Bikes: Shmikes
Liked 5,862 Times
#1825
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
