Thinner tire sizes for mountain bike
I recently got a bike from a friend and I would like to use it for commuting, and generally getting around town. This means it will largely be driven on pavement, and the most off-road use it will see will be on very fine crushed rock walking paths. However, it needs a bit of love, especially the tires which are badly worn. The current setup is a bit weird, with a front tire that is 26"x1.95" on a 559x18 rim, and a rear tire that is 26"x1.75" with a 559x27 rim. I would like to move to a thinner slick, but I am not quite sure how low I can go. I've seen a few threads like this one:
https://www.bikeforums.net/commuting/...tain-bike.html
which include links suggesting that the front could go as low as 1.1" or so, but I am not sure about the back. One of the examples on that thread mentioned they moved from 2.125" to 1.5" which would be fine with me, but they do not mention the rim size. Anyway, I was wondering if anyone had experience with this, or knows of a lower limit I should make sure to shy away from for each of those rims.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
1.5 inch is good.
One of the wheels was likely changed out at some point, most likely due to damage or theft.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 1062 Post(s)
Liked 665 Times
There's a note at the end of this page about tire widths:
https://www.sheldonbrown.com/tire-sizing.html
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Get some of these and forget about narrow -- go as wide as will fit:
https://www.renehersecycles.com/prod...tires/26-inch/
Likes For Cyclist0108:
Unlisted member
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 432 Times
I've used 26x1.5 on my MTB commuter for about 10 years and my next tires will be wider. The Performance slicks I used were pretty stable, but the ones I replaced them with are too squirrelly for me now.
Likes For no motor?:
Bikes: 2010 Origin8 CX700, 2003 Cannondale Backroads Cross Country, 1997 Trek mtn steel frame converted commuter/tourer, 1983 Univega Sportour, 2010 Surly LHT, Others...
Quoted: 48 Post(s)
Liked 15 Times
I like the Continental Travel Contacts and their 26X1.75 rides like a narrower tire on hardpack. Pressure can be dropped off road. Very versatile, smooth and easy rolling, durable, and flat resistant.
The Panaracer TServ is a nice tire for a 26" mtn bike commuter as well. Available in 1.25, 1.5, and 1.75. The 1.75 - 2.0 width on a 26 tire is the sweet spot for me.
Likes For AusTexMurf:
Passista
Quoted: 868 Post(s)
Liked 721 Times
Tire size is third to suppleness and tread pattern IMO. I'd go for a supple wall, non-knobby tire in 1.5/1.9.
Likes For Reynolds:
Bikes: Marin Muirwoods 29er
Liked 5 Times
I was in a very similar situation to the OP, gifted an old MTB to commute with. I gradually worked my way down to 1.5 slicks and now use that width on my latest commuter.
Quoted: 1364 Post(s)
Liked 1,678 Times
Long story short: My main commuter from 1997 to 2015 was a mountain bike with 26" wheels. I have put about every type of tire on it. Wide, thin, tread, slick and hybrid (smooth center section, knobby shoulders...very bad all around). 1.5" slicks are the narrowest I'd go. I now run 1.85 slicks and am very, very happy.
In the winter it wears 1.65 studded snow tires with aggressive tread. Those are not so great on dry pavement, but incredible on snow and ice.
Likes For BobbyG:
Disco Infiltrator
Liked 2,105 Times
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Similar for me. I've been on 26"x1.75" tires for years, gonna try to fit 2.1" Rat Trap Pass next time around.
Likes For ThermionicScott:
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
Nashbar used to offer house-brand Kevlar-belted 26x1.25 tires that I used for a long time. I forget their pressure rating; maybe 90psi.
I now ride Continental Tour Ride/Ride Tour 26x1.75 at 60psi. They roll fast and I've not had a single flat in 3 years. They're also affordable - less than $25 online.
Likes For Eric S.:
Only issue I had with Continental Travel Contacts , was I got quite bored
with all the 'experts' pointing out my once knobby tire was worn smooth in the center/...
I use 26" Gatorskins on my commuter. The rims are Mavic XM317s which specify a tire width of 1.5 to 2.1, but the Gatorskins are 26x1 1/8. I've been using them for years and I'm on my second pair. No issues at all.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I agree. 1.5 slick is about ideal.
I've used the 26x1 1/8 gatorskins (and 1" panaracers), and they do nothing for the bike. Technically they are a little slower unless you are riding on new pavement - but that is a different story. High pressure doesn't make you faster.
WGScott is probably right (go big or go home), but there are some good selections for fast commuter slicks in the 1.5 size - it gets harder to find as you go larger. Sure - you could go for reneherse tires - but those are rather exotic - not the most durable tire for commuting.
Passista
Quoted: 868 Post(s)
Liked 721 Times
Of course it's a compromise, but I meant sidewall suppleness, which has a big effect on ride quality. The op didn't mention trail riding.
Disco Infiltrator
Liked 2,105 Times
We mostly don't run cotton clinchers or tubulars on commuter bikes either
Genesis 49:16-17
Genesis 49:16-17
Schwalbe Marathon Supremes. The answer to all tire questions. If you want to know what bike to get, Surly LHT.
Quoted: 8 Post(s)
I have schwalbe landcruisers in 2" which work for your rim widths. Cheap, but heavy and very durable overall. I traverse tons of glass due to inconsiderate yahoos and am flat free for a year and 1/2 of 60% commuting. knock on wood
Liked 415 Times
depends what you mean by supple.
high thread count tires tend to be harder to puncture but easier to tear
low thread count tires (with thicker cords) tend to be a little easier to puncture, but harder to tear. That works well with tubless as the sealant can easily repair a small hole, but not a gash.
but of course if we are talking sidewall - supple tires have thin sidewalls. I don't tend to get sidewall cuts on pavement - just gravel and off road.
My Cannondale was considered a mountain bike with no front shock when I bought it in 1995. These days it would be considered a hybrid or commuter. It came with knobby tires intended for dirt use. Over the years, it has become the trailer hauler for when the boys would get pulled behind. To make like easier, I ditched the knobbies for a much smoother ride. I attached a pic of the tires I have on it now. Unfortunately, I don't have a size for you. I do commute, but I use my road bike. I have Gatorskins on it and would recommend them highly.
Quoted: 576 Post(s)
Liked 1,003 Times
Like others, I've been on various widths and styles since '90 but now I use fat slicks. Maxxis DTH is my current fave, I have four pairs now and need to get some more for my other 26ers. They are fast, light, and cheap, but not the most durable.
This is my Stumpjumper which I commute on via Old Croton Acqueduct Trail (mild trail), South County Trail (Paved+very mild trail), and the streets of Manhattan and the DTHs handle it all with no issues. The other week the S County was super muddy but these tires just floated right over the soup.
Likes For DorkDisk:
Bikes: Working on replacing my stolen Soma Buena Vista Mixte
Quoted: 417 Post(s)
Liked 95 Times
I have these on my new bike in 650b. No long term review yet, but they feel awesome. https://global.bluelug.com/fairweath...kin-11320.html
