Steel frame with disc brakes vs Titanium
Rhythm is rhythm
Been riding 60-120 miles on my weekend ride and I'm getting sick of my harsh carbon frame (though I love it).
It has all Campy parts which I also love the feel of and function.
But I'd like to get a ride that smooths out some of the roughness and also accommodates a wider tire.
So, in your own opinion, which would be the better choice: swapping the frame for a high end titanium Lynksey or Moots or purchasing a complete Salsa Colossal 2 (steel) with disc brakes (also noticed the Niner RLT steel but a little more than I want to spend).
Your feedback is appreciated.
Thanks,
Max
Thanks,
Max
Zircon Encrusted Tweezers
Quoted: 261 Post(s)
Liked 137 Times
If the funds were available, I'd have to give this some consideration:
https://calfeedesign.com/adventure/
Quoted: 257 Post(s)
Liked 70 Times
those are a lot of different variables
which carbon frame are you on now?
are you limited to one bike?
your price points are very different between the Ti vs steel frames
also which wheels are you rolling on?
Uber Goober
You need good brakes. There's lots of threads on disk vs rim- and as best I can tell, as a disk user, there's just not a lot of reason to choose one over the other. So I wouldn't worry about that aspect at all, get the bike you like and whatever brakes it comes with ought to work.
Steel vs titanium vs carbon= can't help there at all.
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
Uber Goober
Well, I meant in general for road usage at least. It's not like all the rim-brake users I know are crashing into trees for lack of proper brakage.
Quoted: 5 Post(s)
Rim or disc brakes won't be the reason your rim brake friends are crashing into trees. Every reasonable quality type of brake, set up properly, I have come across, has worked according to the type of situation it was designed for. Also, aren't carbon bikes supposed to have a comfortable ride (terrific road damping qualities of carbon according to this I quickly googled Why You Should be Riding Steel and not Carbon | Road Bike News, Reviews, and Photos I guess different manufacturers carbon will ride somewhat differently.
You could consider tyres that inflate to a lower psi, or a different frame geometry, if you want a more comfortable ride. You never know! Dit - you could even try stretching properly before/after your ride!
Bikes: SOMA Double Cross w/ BlackSheep Ti Fork, SOMA Grand Randonneur
To improve your ride quality choose a Steel or Ti frame that takes the widest possible tires. 32 minimum for 700c, 42 for 650b. Get a geometry that is comfortable for you. A Steel or Ti fork will further enhance your comfort.
- Wider, low-PSI tyres that smooth out a lot of the road roughness, which calls for sufficient frame and fork clearance. Lower tyre pressure can reduce energy losses from wheel bounce and from suspension effects in soft body tissue, so they're not necessarily slower.
- A frame that is not optimized for putting down a lot of power in sprint finishes (built very stiff) but feels a bit more springy and lively instead. Oversized, shorter tubing tends to make frames stiffer. Longer and/or smaller diameter tubing with thinner walls tends to be more springy.
- A longer head tube that makes it easier to raise your bar to offload your hands, arms and neck.
- A more relaxed geometry with less steep seat and head tube angles.
- Longer seat and chain stays. They will also help tyre clearances (see above).
- Longer wheelbase (partly a consequence of the previous item)).
To summarize, ride comfort is more a function of tyre choice and bike geometry than material. If your current carbon frame rides harshly it's not because it's a carbon frame but because it's probably built stiff and runs with narrow high pressure tyres. You can build a good long distance bike from any of the common materials (chromoly steel, titanium, carbon and even aluminium). Each of these materials has its advantages. Steel and Ti tend to make for the most long-lived (and repairable) frames, while carbon is cheaper to build light (until you crash it).
I share your interest in disk brakes for my next bike. If you you end up riding in the rain like I often do on long rides or around town, it seems they can make a lot of difference. I am currently looking at the Soma Cross Check Disc frame and a few other potential candidates for a long distance ride custom build.
Quoted: 4876 Post(s)
Liked 4,042 Times
I don't get it either. But then, I have spent maybe one mile on CF on well paved parking lots so I am no judge. My bikes are steel and ti. I have observed, almost as sure a clockwork, the Cycle Oregon CF riders slowing so abruptly upon hitting chip seal that I almost have to use my brakes. And sighs of relief when the chip seal is over. Those of us riding ti or steel just look at each other and shake our heads. (I often look forward to the chip seal because it has always felt to me to have lower rolling resistance.)
Ben
Ben
Ben
Ben
In my line of work, this is known as a negative sale. A negative sale is one that relies on the portrayal of a rival product as poor so that it makes an alternative seem strong. The "sale" doesn't require that the individual state anything positive about their own product or preference. The hope is that the listener will be so turned off by this portrayal that the alternative suggestion, empty of any claims, is elevated to a higher standing. Sound familiar?
Rhythm is rhythm
You can look at my pedal room if you want to see what bike I'm riding. I'm not a newb and know the differences between subtle changes in geometry as well as quality in materials.
I guess my question was kind of vague, but put simply; if two bikes were the same price, one titanium with campy parts, the other steel with SRAM apex and disc brakes, which would you rather ride over long distance?
multimodal commuter
Quoted: 1908 Post(s)
Liked 575 Times
Assuming the frames under consideration also have the same geometry and same tire clearance, and knowing nothing more than "titanium" and "steel" then I guess I'd go for the titanium. I don't know much about titanium but am curious about it. Steel could tempt me, depending on the specifics of the steel. The disc brakes do not tempt me; I'm sure they're fine, but... they're brakes.
www.rhmsaddles.com.
www.rhmsaddles.com.
OK, if you go for disk brakes you won't be able to re-use the Campy caliper brakes, but you could still use your existing Campy brifters with something like the Avid BB7 (mechanical) or TRP HY/RD (cable actuated hydraulic), along with cranks, derailleurs, etc.
Trouble is, for the price of a high quality factory-made Ti frame that won't suffer such problems you can get a very good custom built steel frame with perfect geometry and the best tubes for the purpose. The Ti frame may be a few hundred grams lighter but the steel frame will probably ride better for the same money.
Randomhead
Liked 3,789 Times
steel bikes break too. I am not convinced steel and discs go together that well. The problem is the fork has to be beefed up to be anything better than marginal
multimodal commuter
Liked 575 Times
Since I joined Bike Forums I have seen countless posts in which riders compared the ride qualities of frames. Steel frames, mostly; 531 of various kinds, Columbus of various kinds, and so on. At first these posts made no sense to me at all. I gradually began to realize that the guys writing these posts all weigh well over 200 lbs. Few guys my weight (165) have much to say about frame flex. The few that do are the ones who have sought out frames made from especially thin walled tubing. Not long ago @southpawboston (I think it was him, anyway) bought such a frame and found the fork on it too beefy, and had a lighter fork made.
www.rhmsaddles.com.
www.rhmsaddles.com.
Good for you. (with sincerity, please.)
