old frame, want to fit octalink / compact cranks
Bikes: road: 1999 GT road:40Kmi+ // 2001 fuji finest AL:9Kmi+//1991 schwinn paramount ODG:0.1Kmi+
Quoted: 19 Post(s)
Liked 10 Times
so
old bike
gt road bike, probably an 'edge'
1998 or 1999
(EDIT - correction, the new cranks are not octalink, they are hollowtech..)
i acquired some compact cranks
shimano FC-R700
the BB is currently square taper
stats are
British I.S.O. 1.370" X 24 tpi
Shell Width /Standard 68 mm/O.S. 73 mm
what do i have to have and get and do, to put the new cranks in, or is it possible?
i don;t really see what would keep them centered
the crankset has 100mm of axle bare
then the BB shell is only 68mm wide, what takes up the other 32mm?
usually the BB includes the axle but these things have an axle but no bearing..
i am just too old school, help.. !
i;d like to have the things just work but that is looking less likely
thx
wle
old bike
1998 or 1999
shimano FC-R700
stats are
thx
wle
I don't believe you have an Octalink crank, you have a Hollowtech crank. You need to buy external cup bottom bracket to go with it. Something like this will likely work:
https://www.amazon.com/Shimano-SM-BB4...ywords=bb-4600
You'll need the tools to extract the old BB and install the new one.
Answer: The bearing cups.
Quoted: 19 Post(s)
Liked 10 Times
you are right, i will edit orig post...
wle
wle
Bikes: Lemond, Gios, Fuji, Trek, too many to write
Not sure If I understand the question. You have the cranks? And there is a BB installed on the frame? You can get any compact crank that will use an English BB. You can do current Shimano compact, Mega Exo, etc. You just need the correct English BB that will work with that crank.
OK. BTW don't worry your bottom bracket shell is extremely standard. It will work!
Without seeing your old setup, it's difficult to tell, but you'll likely need this tool to remove your old BB:
Amazon.com : Park Tool BBT-22 Shimano Sealed Cartridge Bottom Bracket Tool : Bike Hand Tools : Sports & Outdoors
and this tool to install your new one:
https://www.amazon.com/Park-Tool-BBT-...bracket+wrench
Quoted: 19 Post(s)
Liked 10 Times
i think i also have to have the shell machined for flat/parallelness, right?
wle
wle
External Bearing Cranks would comed with the Bearing assemblies , in the Carton. But not the installation Tools .
Compact in road stuff now = 34-50t chain ring combinations .
Staying 'old school' .. the 110 BCD crank type will build up with the same chain ring Choices.. in square taper type.
Quoted: 19 Post(s)
Liked 10 Times
yeah i bought cranks used, is why i am confused
bearings prob stayed in a bike somewhere
it is 50/34T
wle
it is 50/34T
wle
Quoted: 19 Post(s)
Liked 10 Times
bike has old square taper BB as i listed, english 68mm
think i need
external BB for hollowtech
tool for hollowtech
face the BB shell
(already have tools to get old BB out)
wle
It may not be necessary, depending on the condition of the frame, but it certainly can't hurt. Likely as the frame wasn't built with external bottom bracket in mind, there will be paint on the outside edge of the BB shell, in which case facing will be needed.
Quoted: 19 Post(s)
Liked 10 Times
it is 50/34T
wle
Quoted: 19 Post(s)
Liked 10 Times
no paint, oddly the frame is naked aluminum, GT idea i guess
what would happen if i tried not getting it faced, and it actually needed to be...?
wle
If it's really bad, you'd notice that the bearing cups don't screw down flush to the end of the BB shell. I'd definitely get it faced in that case. IMHO if it looks good to the eye, I wouldn't bother, but others may have stronger opinions on this.
Ahh I see. Yah, as others noted, it'll be easy. Just need the correct English BB for the cranks. For your original octalink, you will need the splined tool. You will be all set and riding in no time!
Quoted: 1872 Post(s)
Liked 1,748 Times
If you just have the cranks you will need to buy the matching external bearing bottom bracket. Facing may or may not be necessary, many older square taper bottom brackets required that tha BB shell be faced to do a proper installation. Good news is that external bearing bottom brackets are relatively inexpensive, even the higher end ones
Quoted: 19 Post(s)
Liked 10 Times
right
ok
thanks everyone
tiagra BB for $15
BB tool from bikehand for $13
crankset used for $5
bonus, the BB and chainrings were worn anyway!
had 48,000 miles plus, on both
win - win
cheap cheap
also just got different back derailleur [ancient shimano 600] that i believe can handle the extra chain range
will try it without refacing the shell, of course, first
wle
ok
thanks everyone
tiagra BB for $15
win - win
cheap cheap
wle
Quoted: 19 Post(s)
Liked 10 Times
spacers, how do i know if i need them?
wle
wle
Quoted: 2026 Post(s)
Liked 1,097 Times
Spacers are needed if you have a crank meant for a 73 mm (typically on an MTB) bottom bracket shell but are installing it on a 68 mm. You have a road crank so no spacers should be needed.
BTW, Hollowtech (plain Hollowtech, no numbers) did indeed use an Octalink bottom bracket. The newer Hollowtech II cranks use the external bottom bracket bearings and have the spindle built into the drive side crank arm.
My criteria for crank alignment with Hollowtech II cranks is does the spindle slip through both installed bearing cups with no forcing or bending? If it does, your shell is adequately parallel. If you have to force it into line, even a little, have the shell faced.
Quoted: 19 Post(s)
Liked 10 Times
thanks, exactly what i needed to know, plus wanted to hear
wle
wle
Latif
4
06-12-19 11:15 AM
TechKnowGN
Bicycle Mechanics
9
12-09-10 12:58 PM
