Which disc brake?
Which disc brake?
Old 04-24-05, 12:59 PM
lechu
Which disc brake?
Which of the following you'd recommend for xc riding:
Hayes hfx-9, Magura JULIE or shimano deore xt hydraulic disc brake? i think of julie (o've ridden hs33 for 3 years and i trust magura brand), and they're the cheapest? what do you think?
lechu
lechu is offline
Old 04-24-05, 01:09 PM
troie
:\ ping of death
troie's Avatar
Save the cash and get Avid BB7's?
troie is offline
Old 04-24-05, 01:18 PM
phantomcow2
la vache fantôme
phantomcow2's Avatar
well persoan lly i would just get avids
C://dos
C://dos.run
run.dos.run
phantomcow2 is offline
Old 04-24-05, 02:13 PM
monkey69
Bikes: 2005 hard rock pro
i got the bb;s 5 and i think they are great .i rode a few magura hydraulics and well sure they are somewhat more powerfull ,but not much of a difference.
monkey69 is offline
Old 04-24-05, 02:22 PM
PWRDbyTRD
Toyota Racing Dev.
PWRDbyTRD's Avatar
Bikes: 2004 Kona Hoss Dee-Lux
For normal purpose just pick up some BB7's Hayes Hydros are nice, and some incredible stopping power, but the BB7's will work just about the same for anyone under 250lb
PWRDbyTRD is offline
Old 04-24-05, 03:07 PM
lechu
what about shimano BR-M 765 (xt) brakes?
lechu is offline
Old 04-24-05, 03:20 PM
emptybeer
I've ridden Hayes and Avids. Go w/ the Avids.
emptybeer is offline
Old 04-24-05, 03:21 PM
Eros
Keep Right Except to Pass
I really dig my Julie's. I haven't put much mileage on them but so far they're great. I really like the fact that they use mineral oil instead of brake fluid.
Getting them set up perfectly centered took a little while and some elbow grease to make shims, but they've been hassle free since.
I haven't had to change pads yet but it looks like it will be a breeze.
I would hate to have to be adjusting the mechanicals all the time like I've heard.
Cheers
Eros is offline
Old 04-24-05, 03:24 PM
Dirtbike
Giggity giggity!
Dirtbike's Avatar
Bikes: Yeti DJ Custom build. X.9, Marzocchi, RaceFace, Gamut, DT, Truvativ, Michelin, Hope.
I vote Hope minis.
Dirtbike is offline
Old 04-24-05, 03:34 PM
sparks_219
sparks_219's Avatar
Bikes: Rocky Mountain Instinct, Cannondale Six13, Cervelo One
I just bought a set of XT hydros, and after my research, I think they are the best for MY needs. If you're on a tight budget, and dont worry too much about weight, then the Avid BB7s should work perfectly fine.
I wanted something for cross country racing, so weight was somewhat on top of my priority, and that is why I went with the XTs for the light weight, excellent modulation, and available spare parts.
Best of Luck
Ming
sparks_219 is offline
Old 04-24-05, 04:03 PM
monkey69
Cheers
what makes you think you would have to do that ?correct me if i am wrong but hydros and mech. disc brakes are pretty much the same thing except for the transfer of energy.
i adjusted mine once when i got it and they are fine ever since .
monkey69 is offline
Old 04-24-05, 05:45 PM
FreeFall
i think magura cuze they ahve awsome hydrolic stuff such as hydrlic clutches and their motorcycle brakes and lines flow really well. ive never had a problem with them. so im gunna assume they put the same qulity in their mtb brakes too
FreeFall is offline
Old 04-24-05, 05:49 PM
forum*rider
Work hard, Play hard
forum*rider's Avatar
Bikes: Cannondale super V 500, Bianchi Piaggio(hopefully getting a new road bike when I get some money)
My uncle runs the Magura Julies, great brakes. Not high maintenence at all, powerful, reliable.
forum*rider is offline
Old 04-24-05, 05:59 PM
Eros
That's why I said "I've heard". I thought you had to adjust for pad wear.
Eros is offline
Old 04-24-05, 06:16 PM
troie
:\ ping of death
troie's Avatar
The key word of the day is "proofread".
troie is offline
Old 04-24-05, 07:01 PM
em9ty
Originally Posted by Dirtbike
I vote Hope minis.
really?
em9ty is offline
Old 04-24-05, 07:04 PM
em9ty
hope minis do look though..quite powerfull...do they?
em9ty is offline
Old 04-24-05, 07:10 PM
Dirtbike
Giggity giggity!
Dirtbike's Avatar
They have extremely good modulation, and power when you need it. IMO, they also have the best lever feel of brakes I have used/tried (Hayes, avid mech and juicy, shimano) I have not tried maguras though.
Plus, they look trick!
Dirtbike is offline
Old 04-24-05, 08:01 PM
monkey69
well thats why i said correct me if i am wrong
could be that they have slightly higher pad wear ,but that should be insignificant .
monkey69 is offline
Old 04-24-05, 08:08 PM
nirvanaschains
Bikes: 2004 GT-Idrive 3.0
I've been looking into getting hydraulic discs. I was originally going to get Avid juicy 7's, but after reading reviews on mtbr.com i'm kind of scared.
After reading the reviews i was considering Hope mini's, though it sounded like they discontinued the good model and replaced it with Hope mono mini's. The reviews weren't as good for those.
Weight is a concern with me, i basically want something under 400g.
On mtbr.com it seems like most people have lots of problems with all the hydro's. But then again its usually the complainers that have the motivation to leave reviews.
I'm probably gonna end up asking my local shop what they recommend, but any suggestions would help.
nirvanaschains is offline
Old 04-24-05, 08:11 PM
arboc!
arboc!'s Avatar
Bikes: specialized p.1, redline single x
dont get the hfx... they have nothing but problems. the maguras are pretty nice. the shimanos are good to.
arboc! is offline
Old 04-24-05, 08:13 PM
arboc!
arboc!'s Avatar
the juicys are nice... dont let those assclowns ar mtbr tell you whats going down. lots of the people on there dont even have the things they review.
arboc! is offline
Old 04-24-05, 09:09 PM
forum*rider
Maelstrom is actually using the Juicy 7's for DH runs right now.
You might want to PM him.
Old 04-24-05, 09:18 PM
sparks_219
sparks_219's Avatar
The Juicy 7s fixed the chattering problem with the new rotor, so that isn't an issue anymore.
Brakes under 400g for the entire system:
1) Hope Mono Mini
2) Magura Marta SL / Marta
3) Shamino XT/XTR combo (XT is a bit more than XTR)
I went with option 3 because my LBS said they can get me any part I want for the Shimano system....
Old 04-24-05, 09:47 PM
Dirtbike
Giggity giggity!
Dirtbike's Avatar
Hope minis fo sho!
Dirtbike is offline
