Does campagnono translate to...
Bikes: Trek Domane 4.5, Kona Jake, Centurion LeMans RS
"I will build things of odd sizes and that need special tools to work on them"? Evidence to date, and I am just beginning. 1. Delta brakes - cable release with a 3.5mm hex, not a 3 or a 4 (yes, the 9/64 worked, but I have made my point) 2. Headset - thanks to the mechanic at Billy Goat bikes, who had the wrench that fit the flats. 3. Freewheel - I have been to 4 different lbs, none of whom have the "special" 2 prong freewheel tool. 4. The seals over the wheel hubs that have the special tool to remove. 5. Axles that require 2 14mm cone wrenches, not 13 or 15, but 14.
GRRRR Bob
GRRRR Bob
Bikes: '92 22" Cannondale M2000, '92 Cannondale R1000 Tandem, another modern Canndondale tandem, Two Holy Grail '86 Cannondale ST800s 27" (68.5cm) Touring bike w/Superbe Pro components and Phil Wood hubs. A bunch of other 27" ST frames & bikes.
GRRRR Bob
GRRRR Bob
As to the other complaints, for a long time the Campagnolo headset wrenches were useful for many vintage headsets, save French.
The cone wrenches used to always come double ended two sizes, don't see a problem there.
The Corsa Record dust shield removing tool was clever, unique and worked, every decent shop in the mid 80's had one.
More elegant than taking dust caps off any other loose ball bearing hub, including the previous Campagnolo offerings.
As to the unique Allen key required for the Delta brake clamp, I agree completely, why not 4 mm or even 5 mm (maybe too much torque could be applied?)
You want awkward unique nobody hardly has tools? Think Mavic ensembles.
Still learning
Raleigh threading and bolt head size quirks, Campagnolo tool quirks, Swiss quirks, Italian quirks, Schwinn quirks, yet in this forum too many rants about French threading. Too many Sheldon Brown disciples if you ask me!
Bikes: '86 AMBROSI / C RECORD. PINARELLO MONTELLO / FRAME, FORK.
Shouldn't it go without saying: Those Mechanics who know what they are required to do have the Correct Tools,
whereas those "mechanics" who do not know what they are about to perform use "other tools"?
Case in point: (I not knowing whether this still holds true.)
The mechanic has just topped-up your Rolls-Royce's brake cylinder; if he didn't use Girling Brake Fluid,
your hydraulic system has just been destroyed.
An old axiom: "Use the right tools for the job, or go home."
Regards,
J T
Regards,
J T
I have that special Campy freewheel tool, freehub pawl retainer, 7mm crank Allen key, 3.5mm Delta wrench and at least 2 of every cone wrench size.
I even gave the ultra rare 6 prong Suntour Microlite freewheel tool.
GRRRR Bob
GRRRR Bob
All Campy All The Time
Bikes: Listed in my signature.
Liked 119 Times
The C-Record hub bearing dust shields can be easily removed with a gentle twist of an ordinary flat-tipped screwdriver. The beautiful Campy-supplied dust cover removal tool is elegant overkill. You don't need it.
My C&V Bikes:
1972 Bottecchia Professional, 1972 Legnano Olympiade Record,
1982 Colnago Super, 1987 Bottecchia Team C-Record,
1988 Pinarello Montello, 1990 Masi Nuova Strada Super Record,
1995 Bianchi Campione d'Italia, 1995 DeBernardi Thron
My C&V Bikes:
"Where can the problem be?"
Citoyen du Monde.
He forgot the Campy Corkscrew and cheese.
Regards,
J T
Citoyen du Monde.
Regards,
J T
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Liked 419 Times
I put some wine corks in as bar ends and now i need a campy corkscrew to take them out??? It's cheaper to just get new bars every time.
Let me try this again with a small addition:
He forgot the Campy Corkscrew and cheese to go with his wine. [whine]
Regards,
J T
Regards,
J T
Liked 681 Times
Yes, it is specific and of a neat design, the two prongs slowly twist, basically as you try to remove the freewheel the prongs engage more firmly. A good but unique solution.
Furthermore for the cone wrenches, Park has single-ended ones (more comfort, more leverage) in every millimeter size, at least 13, 14, 15, 16,17.
What I don't get? Use of Torx heads on bicycles. I can see dumping external hex, but what does Torx do that Allen doesn't?
Liked 681 Times
GRRRR Bob
GRRRR Bob
I totally agree with you on the Deltas. I'd like to try some, however. I tend to like finnicky machines as well(missed out on the Norton Commander and Vincent Black Shadow, however) and usually can tweak them into functionality.
Thing is, now you have the bike, right? You've sunk money into it. You either have to sit on it and not use it, make it work and see if you like it once it can move properly, ride it as-is for whatever condition its in, or sell it and get something more maintainable. What kind of frame is all this good stuff on?
Old fart
Liked 3,675 Times
Why Campagnolo didn't just use a splined tool like most other freewheel manufacturers were moving to remains a mystery.
the "Atom" spline, picked up by many over time was a pain until the Phil Wood remover. Atom's version required taking apart some or most of the axle to fit the removing tool. Some hubs were set up so the outer lock nut and spacer was independent of the hub bearing adjustment but many were not, so the Phil tool allowed in most cases for the axle to remain in place. Downside of that tool was the wall thickness. We had a mechanic at the shop who killed off more than one Phil tool where a freewheel was on too tight.
There were other spline patterns and diameters for sure, Campagnolo made the choice as they did to get all to fit. A good system. I think the error was as typical Campagnolo patented it, in this case it might have been better to not and let others copy to make the design more universal. It works quite well.
I have the tool in two versions, one as an insert that fits in the "Regina" style Campagnolo freewheel spanner and the other as a dedicated Campagnolo freewheel spanner. No Campagnolo freewheels, never could put the money down on one as I viewed them as consumables. They were and are finely crafted mechanisms though. (bought the tools with a Campagnolo tool case +, got all the threading options with it save Swiss) A big purchase with no regrets as it is such a pleasure to work with the tools.
Super Moderator
Liked 1,013 Times
GRRRR Bob
GRRRR Bob
Our team got a batch of those, so I put them in a milling machine and cut the flats down to the correct size.
"Campagnolo makes cheese? "
rootboy.
"Let me try this again with a small addition:
He forgot the Campy Corkscrew and cheese to go with his wine. [whine]"
Let me try this again with ANOTHER small addition:
He forgot the Campy Corkscrew and cheese to go with his wine. [WHINE]
As in "Do you want WHINE with that Cheese?"
Wine & Cheese; WHINE & CHEESE.
Now quit your Whining and eat your Cheese!
(And you do now know just what to do with that newly removed Cork!)
Regards,
J T
rootboy.
Regards,
J T
"Reference R-R brake fluid; he should be alright if he used GIRLING brake fluid."
keidal.
"The mechanic has just topped-up your Rolls-Royce's brake cylinder; if he didn't use Gerling Brake Fluid "
Error within spellin'; now Korrected on original. (Girling)
Regards,
J T
keidal.
Regards,
J T
"No, but they do cut it now and then. "
OldsCOOL.
Never forget the mustard!
(KEEN'S Mustard.)
Regards,
J T
OldsCOOL.
(KEEN'S Mustard.)
Regards,
J T
