XTR versus XT (for 2005)
Hi all.
I've done the search, etc - and had indeed found a good amount of stuff that relates to the title.
However - it's come past the second quarter of 2005 now - and I'm after your opinions on XTR versus XT. I'm thinking mainly in terms of rear derailleurs, gear-shifters, and hydraulic braking.
1) Is it still your collective opinion that XTR is less durable/long-lasting/rugged/able to take abuse than XT (because XTR is race-bred, with all that that means, in terms of compromises)?
2) Speaking of the M525 hydraulic brakes - what advantage(s) would the XT brakes have over these, if one only ever does XC-riding? I understand four-pots is one difference at least?
Additionally - does anyone have any advice on which brand of pads to go for?! I hear so many conflicting things about 'big' brand names, e.g. EBC or Shimano.
P.s. I have noticed a lot of anti-Shimano sentiment out there - but please do respond to this post as asked. I'm only interested in the types and brands mentioned.
Thanks in advance to all of you for your responses!!
Arif
Arif
Giggity giggity!
Bikes: Yeti DJ Custom build. X.9, Marzocchi, RaceFace, Gamut, DT, Truvativ, Michelin, Hope.
Screw shimano. Go SRAM X.0
I dont think that the money for XTR is worth it, mostly because I will destroy a derailluer before it is all worn out. SRAM also shifts alot better. The SRAM 1:1 allows for a firmer return spring that shifts way better in muddy, sandy conditions.
As for pads, I would just go with stock pads. As for brakes, I recommend Hope Mono Minis.
The 525 are OEM brakes, and arent very good. The XT set is alot more powerful.
My new build is going to have Hope minis, sram x.9 med cage derailluer, and x.7 shifter
Bikes: Rocky Mountain Instinct, Cannondale Six13, Cervelo One
Other than brakes, I feel there is too much price difference to justify the minimal performance gain (if any). That's why I went with XT dual control levers myself.
I personally went with a Shimano setup because my LBS told me they can get parts much easier for Shimano and Hayes brakes, where as replacement parts are almost non-existant with Hope Mono Minis.
Hope this helps
Ming
Ohh such constructive posting.
IS XTR worth it over XT?
Depends on what you want. Do you want the best shifting, braking performance, the stiffest cranks and the lightest dual control shifters? Yes, then XTR is your group.
If you want a groupset that has most of the performance benefits at a lower price due to different manufacturing and higher production volume, then get XT. For most people the differences aren;t that marked but for a XC racer the 300-400gr saving is definaltey worth it.
BR 525 are ok brakes. They work. However XT is certainly in another league.
For 95% of the riders ou there, XT is the best groupset in the price performance ratio.
SRAM is good but not as good as people make it out. Because it's different and American everyone thinks it must be brilliant, but just like the Hand made in America slogan has been successful in achieving the perception that that's better, the truth is usually not what everyone wants to hear. and that is that the stuff from japan, taiwan and china is usually of better quality and lower cost..
I think there is not much difference between XT and XTR components in terms of their mechanisms, and their durability. You should also consider that XTR is built for XC racing, and too much abusing may not be good at all. If you have the money it is worth getting the XTR only for the extra weight savings. I used the XT760 components, and I didn't have any durability problems, except the derailleur pulleys seemed to be wearing fast, and I loved the dual-control shifters. Then I replaced them to SRAM, however i won't go into that since you are not interested.
