Counter Steering - When to Use?
Quoted: 401 Post(s)
So I've been experimenting with counter steering. See https://www.youtube.com/watch?v=D2P6_NRG0Ro or https://www.youtube.com/watch?v=C848R9xWrjc
It all makes sense on paper and I can do it in practice, but why would I want to? If I do the regular lean and then turn handle bars I can turn quite sharply and safely.
Who would have though turning a bike would be so involved.
Farmer tan
The counter steer is subtle and starts the lean. You just don't notice it.
Steering a 1 liter sportbike into a sweeping turn requires more counter steer than it does on a lightweight, twitchy road bike.
I recall having to put pressure on the inner bar. Not so much on a bicycle.
Quoted: 401 Post(s)
Bikes: various strays, mongrels, and old junk.
Don't overthink it ... if you are going around corners, and you are not high siding (that is, falling over to the outside of the turn), then you are countersteering. Those are your two choices. You may not know that's what you are doing, but that is what you are doing.
Surf Bum
Bikes: Lapierre Pulsium 500 FdJ, Ritchey breakaway cyclocross, vintage trek mtb.
Quoted: 13 Post(s)
Liked 5 Times
You (OP) may think that, but you're mistaken.
edit: auldgeunquers beat me to it!
Thirst is stronger than the rules. - Stars and Watercarriers, 1974
Quoted: 1186 Post(s)
Liked 289 Times
Randomhead
Liked 3,762 Times
I saw a reference to a cyclist countersteering, and thought that I never do that. But as it turns out, your bike does it for you. Turn normally and watch the bars on a turn where you don't really have to pay that much attention. You'll see the bars countersteer for you. A motorcycle has so much momentum that the rider has to upset it a little to get it to turn.
RacingBear
Don't fool yourself you are doing it even if you just "lean". Bicycle is super light and it doesn't take much. When you lean you are putting pressure on the bars, even if you don't realize it. Above certain speed counter steering is the only way to turn a two wheel vehicle. It's not about whether you need it, but it's the only way.
Bikes: Fitz randonneuse, Trek Superfly/AL, Tsunami SS, Bacchetta, HPV Speed Machine, Rans Screamer
Quoted: 100 Post(s)
A contious understanding and application of counter-steering is beneficial in emergency maneuvers and mountain biking. It is a skill that should be practiced regularly.
SuperGimp
Quoted: 6556 Post(s)
Liked 58 Times
Countersteering simply starts the bike falling in the direction you want it to go. E.g. steering slightly right leans the bike to the left for a left hand turn. When you recenter the bars, the left turn is completed. Countersteering makes it possible to turn more sharply and at higher speed than just using your weight to lean the bike in the direction you want it to go. If you try to turn the bike with the handlebars by direct steering, you will go the wrong way. Sheldon Brown makes it clear that this is the way essentially all two wheel (wheels in tandem) vehicles are turned. Sheldon Brown's Bicycle Glossary Cn - Cz
Super Moderator
Quoted: 1174 Post(s)
Liked 935 Times
I think some of these videos make it more confusing, rather than less. Go ride a bike and cornering will come naturally. I never heard the term coutersteering until after I had been ripping through corners in races for years. I would probably have been slower if I tried to decide when to countersteer.
Quoted: 1096 Post(s)
Seriously. The only time it's ever worth talking about counter steering is when one is first learning to ride. When starting out and going quite slow, the front wheel has to be pointed directly into the turn, often quite sharply. But to go any faster, one has to learn that that no longer works, and is in fact counter productive. Beyond that, it's no longer anything to think about.
Now can we talk about trail braking?
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1108 Post(s)
Liked 218 Times
Even when leaning on the bike, without hands on the bars, the bike will counter steer on its own.
Works exactly the same on a bicycle. Around 2:40 is where it shows counter steer happening without hands - just leaning:
Lets talk about backin' it in instead! Safe during a crit?
pan y agua
Quoted: 1465 Post(s)
Liked 743 Times
The useful thing that comes out of understanding countersteering is understanding how to alter your line in a turn.
Push down more on the inside handlebar, the line tightens. Let pressure off the inside handlebar the line widens. Once you get this, it's easy to alter your line in a turn.
If you don't (at least on a subconscious level) you can lock into one line that you picked on the entry of the turn and find it difficult to alter your line mid turn, which can be a serious problem.
You could get lost and die.
You could hit a tree and die.
Liked 289 Times
It seems to me that everyone just does this naturally. The only time I've ever thought about it was to experiment and confirm that countersteering occurs. I don't recall seeing anyone have a problem avoiding obstacles.
Expired Member
Quoted: 3763 Post(s)
Liked 5,709 Times
Ride more, read/post less....
Quoted: 2577 Post(s)
Liked 3,079 Times
Maybe I'm one of the only people on here who never owned a motorcycle, but I've never noticed or practiced countersteering on a bicycle in the last 50 years or riding and racing. Given that it's easy (if harrowing) to carve corners with hands off the bars at speed on downhills simply by leaning the bike sufficiently, the descriptions of the subtleties of countersteering sound unconvincing. But then, like all Virgos, I don't believe in astrology, either.
Liked 58 Times
Maybe I'm one of the only people on here who never owned a motorcycle, but I've never noticed or practiced countersteering on a bicycle in the last 50 years or riding and racing. Given that it's easy (if harrowing) to carve corners with hands off the bars at speed on downhills, the descriptions of the subtleties of countersteering sound unconvincing. But then, like all Virgos, I don't believe in astrology, either.
pan y agua
Liked 743 Times
I've seen it a number of times, and a number of various stories on BF result from it.
I think riders fall in 3 basic groups in this regard 1) riders who are adept at altering their line in a curve, intuitively,
2) riders who are adept at altering their line in a curve because they understand the dynamics of countersteeering,
3) riders who have difficulty cornering at speed and altering their line mid turn.
Riders in category 1 don't need to worry about it. My suggestion is that riders in Category 3, can improve their handling by giving countersteering a little thought, and more importantly, playing with it, altering their line by altering pressure on the inside bar.
