If my bike weighed 15lbs, instead of 20lbs, how much faster would I be.
wears long socks
Knowing my average speed and my average grade....
If I dropped 5lbs off of my bike, I would be .1 MPH faster.
If you wonder how much faster a lighter bike would make you and you know your average speed and grade (or power) you can use this calculator to get an approximation. Aero gains can't be calculated here. Just weight differences.
Bike Calculator
Bike Calculator
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
Thanks for sharing.
Edited to add something useful-
Bicycle Speed (Velocity) And Power Calculator
This one gives you all sorts of numbers and allows you to adjust rider drag, rolling resistance, elevation, ect.
Not sure how accurate it is, though. Says that, holding the same power (250 watts as an example) on a flat road, going from riding on my hoods to the drops would cause me to accelerate from 19.4 mph to 21.9. There are a lot of variables involved in that (drop depth, elbows bent/straight, back flat, saddle-bar drop, ect.) so I'd take any of these calculators with a huge grain of salt.
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
Ask a physics professor that is a cyclist. They might be able to explain to you how the question you are asking has too many variables to answer easily.
I would say at least 3a faster...if not 5q. Me? I ate a large lunch so I'd probably only be 2.6n faster.
Bikes: Valoria the Giro 20, and Edward the Bridgestone mountain bike.
(Not exactly a practical piece of advice though since you might swing out into traffic!)
Serious Cyclist
Bikes: Emonda SL6
Liked 261 Times
This is very true... For example, you can change your speed by .1 mph just by consistently riding on the painted stripe of the road. That little bit of extra smoothness created by the paint makes a difference you can actually feel.
Quoted: 2953 Post(s)
Liked 3,106 Times
Conduct an experiment. Take your current bike and add 5 pounds. (It's a lot easier to add weight than to subtract it, just use water in backpack). Ride around, collect data. Add another 5 pounds, ride around, collect data. Repeat. Graph out your findings, draw conclusions. I bet you could win a ribbon at the middle school science fair.
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 678 Post(s)
Liked 431 Times
Duh! You'd be 5 lbs faster!
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Serious Cyclist
Bikes: Emonda SL6
Liked 261 Times
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 454 Post(s)
Liked 164 Times
FWIW, I wrote an Excel based bike simulator simply to answer questions like this. The motivation was to understand how much, if any, performance improvement was available by doing stuff like new wheels, lighter bike, etc. It saved me some money :-)
Given my personal riding style/habits and the areas where I ride, dropping 5 pounds would net me less than a 0.1 mph improvement (according to the simulator). Why yes, I'd love to have another piece of chocolate cake :-)
dave
dave
Bikes: 2006 Raleigh Cadent 2.0, 2016 Trek Emonda ALR 6, 2015 Propel Advanced SL 2, 2000 K2 Zed SE
Quoted: 115 Post(s)
dave
dave
wears long socks
Using the dollar/gram weight weenie thumb rule (a grams weight savings is worth a dollar) I employed my calculator skills and concluded that for me...
A 1 mph gain would result in spending $22,680 and I would end up with a -30lb bike.
I guess you measure negative weight with lift, so I'm going to invent a wingset that will lift some of my weight off of the road.
Quoted: 22 Post(s)
Bike Calculator
Bike Calculator
