How long does it take a bike shop mechanic to assemble a bike?
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
I know some of you out there have worked at a shop or own a shop, so my question is for you. During the spring stock up when the new bikes are coming in, how long does it take a mechanic to build up a bike to put on the floor? Obviously you want your shop mechanics building lots of bikes, but unlike wal-mart, you actually want them to work well.
I've been told that bikes are shipped to bike shops almost exactly like bikes direct bikes are shipped to people. (Handlebars turned to the side, no pedals installed, wheels off. If that's the case then assembling a bike is extremely simple. Bearings today are often sealed, (especially on decent bikes) so it's not like those have to be taken apart and greased. If this is how bikes are shipped to bike shops, I think I could have a bike assembled and tuned well in probably 20-40 minutes. (Possibly more if the wheels required truing, and even more if the head mechanic was really anal about spoke tension balancing.)
Anybody know how much time a bike assembly generally takes in a reputable bike shop?
Quoted: 7395 Post(s)
Liked 2,560 Times
Different shops take different approaches. I've worked in shops. Some adjust the brakes and gears, and that can take surprisingly long. Some go farther and make sure the bearings are not too tight (and they usually are), remove the tires from the wheels and true the wheels in a truing stand (which often involves adding tension too), grease the seatpost and stem, and lots of other things. It can take an hour to do everything.
Bare frame* Or partially assembled , shipped across the Ocean in a Box?
BITD * The famous Italian steel frames needed the Retailer to finish cutting the BB threads,
and prepping for Headset installation,
cutting the head tube and facing the crown race seat of the fork with thread cutting reaming and facing tools .
that , (with interruptions for walk in customer services ) was several hours..
got a stopwatch?
got a stopwatch?
Bikes: Trek Xcaliber 9, Diamond Back Ascent EX
My Trek came with a Race Face crank. Would this crank have been installed at the shop, or at the Trek factory?
Liked 2,560 Times
Cranks are installed at the factory.
but Race Face is CDN , some past owner put that on.
not the Trek Hired Contract factory they get components from that other side of the Pacific Rim ..
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12906 Post(s)
Liked 7,831 Times
Yep, specced with Raceface Ride cranks which are made in Taiwan, as are all their aluminum cranks. Trek surely has then dropshipped to their Asian assembly plants.
Crabon Raceface cranks are made in BC still.
Quoted: 175 Post(s)
Race Face has been making stuff in Taiwan for years now. I don't know if they still manufacture stuff in Canada. I also don't know what that has to do with anything. Cranks would be shipped to wherever the bicycle is assembled be it Taiwan, Wisconsin or China. Yes, it is cheaper to spec parts manufactured near the assembly facility, but is not a requirement. Shimano still makes some parts in Japan, they are still species on bikes assembled in Taiwan.
And Trek does spec Race Face cranks on some of their mountainbikes.
Bikes: everywhere
Liked 7,831 Times
As to the original question, most bike shop bikes are put together in about 15-20 minutes. Then they endure a bunch of test rides, so another 20 minutes is often spent on a bike at purchase time, before it leaves the store.
This is what I had suspected. My guess was that the bikes are essentially "thrown" together the first time around, then given a final tuneup before they go out the door. I've often ridden bikes from shops what weren't quite right. I've ridden bikes that didn't shift well, where the cranks hit the kickstand, where the brakes didn't work or squealed, or even bikes where the handlebars weren't aligned with the front wheel. Every time I've purchased a bike the shop always looked it over for 20 minutes or so.
People who make Everything wants lower costs , so get used to it all moving overseas..
Lots of Shimano stuff is fully Automated including putting it in the box ..
Quoted: 1062 Post(s)
Liked 665 Times
Importing a bike that needs to be completely refurbished before it can be sold, seems like a false economy. You're replacing cheap Chinese labor with expensive American labor, yet retaining the negative brand recognition associated with cheap production. I can see the point of folding the bars and removing the pedals so it can be shipped in a smaller box, but the wheels should be correctly built, and the bearings correctly set up.
Quoted: 1422 Post(s)
Liked 7 Times
I had to:
Put the front wheel on.
Turn the handlebars and tighten up the stem.
Wrap the bars
put the pedals on
put the seat on at max insert mark
check high and low stops on derailleurs and make sure it you could shift to through all gears
Put on all the damn reflectors that came in a separate package
Put on the pedals
Check the brakes
Took about 30 minutes
We'd double check everything when the bike was sold.
Bikes: everywhere
Liked 7,831 Times
Reflectors and bar tape? That's harsh!!!
Bikes: A hauler, a commuter, and a steamroller.
Quoted: 15 Post(s)
When I did this, bikes came in the box mostly assembled.
I had to:
Wrap the bars
put the pedals on
Put on the pedals
Check the brakes
I had to:
Wrap the bars
put the pedals on
Put on the pedals
Check the brakes
You said put on pedals twice. You must really like pedals.
Bikes: everywhere
Liked 7,831 Times
Bikes: Windsor Carrera Sport, Fuji Absolute 3.0, Cannondale H400
When I purchased a bicycle at Performance, They had to assemble one in my size (Fuji Absolute). I was ask to come back in an hour. The bike needed no further adjustment. I rode it for 18 months and when I took it back for a complete cleaning, the tech. told me my crank was loose. Other than that, It was fine.
When bikes are built at my shop, it will take about half an hour to two hours, depending on the complexity of the bike (e.g., hybrid vs. full-suspension MTB, high-end road bike with internal routing and Di2, triathlon bike, etc.). We install and adjust the stem, handlebar, seatpost/saddle, and fork in some cases, true both wheels and adjust the hubs on both, inflate the tires, install/adjust the brakes, install pedals, adjust front and rear shifting, double-check bolts, braze-ons, etc., test ride the bike, make further adjustments as necessary, and install any accessories needed before giving it one last final inspection before it rolls out the door. Some bikes do require that cranks, chains, and rear derailleurs be installed, as well. In any case, it does tend to involve more than simply "throwing it together" out of the box.
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
I've read four to five an hour. That sounds about right, not that I could do it. But someone with good dexterity could probably hold up that pace for a few hours assembling department/big box store bikes.
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Mine took 6 hours from opening the box to riding it.
But then, some things you can't rush.
